Old 06-02-2007, 05:50 PM   #1
Cloud9
Cloud9's Avatar
Cloud9 is making a name for him/her selfCloud9 is making a name for him/her self
SR20DET loosing power
I just finished my swap and when i get to 5500 rpms it feels like it stops pulling almost if its having a hard time going faster? The whistle from the turbo is louder than normal as well, it sounds like the bov is leaking causing the noise but if there was a boost leak the car would bog before 5500, the car doesnt bog. I checked shaft play before install the turbo and it was good. Any ideas, the car stalls alot but only when coming to a stop and i dont think that has much to do with the current problem but idk. Any help is appreciated thanks.
FOR SALE
Cloud9 is offline   Reply With Quote
Old 06-02-2007, 07:22 PM   #2
Garage Battle
Garage Battle is an unknown quantity at this point
I would suggest making a block-off plate for the BOV, or if its a stock style then getting a freezer plug to block the BOV off. (bottom line is, remove the bov, and completely seal the hole). also plug the vacuum line to the BOV.
then just take it for a drive. if the problem dissapears completely then its your BOV leaking under boost. try that first.
Garage Battle is offline   Reply With Quote
Old 06-02-2007, 08:35 PM   #3
Slidin240Wayz
Slidin240Wayz's Avatar
boooost leak
Old 06-02-2007, 08:40 PM   #4
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
he's baannnnnnnneeddddd
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 06-02-2007, 10:07 PM   #5
wonkuuzenki
wonkuuzenki's Avatar
wonkuuzenki is making his/her stupidity well-knownwonkuuzenki is making his/her stupidity well-knownwonkuuzenki is making his/her stupidity well-knownwonkuuzenki is making his/her stupidity well-knownwonkuuzenki is making his/her stupidity well-known
AAAAAAAAAHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHh
people should use the search button.
Function. Form.
Step Up Drift Club/Upper Limit!
wonkuuzenki is offline   Reply With Quote
Old 06-02-2007, 10:21 PM   #6
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Luvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of light
Feedback Score: 81 reviews
A stock SR's powerband usually loses power after 5500 Rpm...
Luvs2slide is offline   Reply With Quote
Old 06-03-2007, 06:33 AM   #7
Cloud9
Cloud9's Avatar
And search for what, if i knew the problem i wouldnt ask!
I know the powerband drops off around there but it feels as if the car just completely stop going, the rpms clime still but slow as hell. Would the boost leak start when i hit boost
FOR SALE
