sr20 build words of wisdom??
So I need to replace my turbo and tranny on my sr so i am going to do a build. looking for 300-350 to the wheels. any advise on parts to buy or what to build to make that power? Here is the specs of the car:
thanks! Engine: Redtop sr20det w/30,000mi.(roughly) New Headgasket, front and rear main seals, intake, ehaust, and valve cover gaskets Spitfire Triple Platinum Spark Plugs T28 turbo from an s14 blacktop hks divorced chamber turbo elbow 3" downpipe and exhuast all the way back with Megan Racing Test Pipe Stainless header with support bracket (SS Autochrome) Custom turbo charge pipe HKS style BOV Greddy VSPL Intercooler Kit Koyo Aluminum Radiator New Radiator Hoses New Water Pump New oil pan, 300zx fuel filter SARD 550cc fuel injectors Universal O2 sensor New Optima Red Top Battery re-located to the back (gel cell battery can be mounted in any direction and wont spill) Walbro Fuel Pump New cross drilled Magnum rotors Axis Ceramic brake pads Phase 2 Motor sports rocker arm stoppers Phase 2 sub-frame spacers Suspension: Suspension Techniques front and rear sway bars energy suspension bushing front and back also Tanabe GF210 Springs KYB Gr-2 Struts Front and rear megan racing strut tower bars Drivetrain: KA24DE transmission with 60K miles still has original SR bell housing Stock 91 240sx open differential with Phantom Grip LSD installed Pilot Motor sports short shifter. Electronics: Pioneer head unit 10 inch sub Amp in trunk Apexi S-afc air fuel controller Apexi AVC-R boost controller Apexi turbo timer Boost gauge Interior: Sparco sprint seat (passenger) Sparco circuit seat (driver) Custom 6 point roll cage Sparco 3inch 4 point harnesses |
![]() Join Date: May 2006
You'll need a bit bigger turbo to hit those numbers... even with cams, T28s are hard pressed to get 300whp. You could try cams + GT28RS, or just go with a GT2871 .64 and forget about the cams.
If you don't already have wheels/tires, I'd plan on doing that as well, and Z32 brakes. Coilovers wouldn't be a bad call either.
You might try to find a better manifold than an SS Autochrome. They're common but still not the greatest build quality; you might end up replacing it, or repairing it, sooner than you think. Decent manifolds (i.e. not Ebay/SSAC/Megan) are usually pricey, but you could probably look around and find some sort of deal.
I'd advise against an HKS "style" BOV, you can find a BOV from a legit company for a decent price. You shouldn't need a new oil pan, unless the factory one is dented. Unless you meant a larger aftermarket pan, which is always a good idea for an SR. Universal O2 sensor, eh, why not get an OEM one? =) Cross-drilled rotors won't have any benefit for you, unless you'll be tracking the car and heating up the brakes a lot. If it's just a street car, I'd say just go with quality blank rotors. I'd advise you to spend an extra $150-200 and get KYB AGX shocks. They're adjustable and more suited to sport springs; the GR-2s won't last as long on a lowered car. Also, Taka turbo lines (or Circuit Sports, or whatever other brand makes braided stainless lines) will make your life a LOT easier if you ever remove/install the turbo, especially if the engine's in the car. You don't want to have to deal with the stock lines. ![]()
My seller review thread |
![]() Join Date: Dec 2006
some ppl throw in a metal head gasket for good measure, but it all depends on how much boost your running..for 300-350 hp..the stock one should hold up.
if you plan on upgrading the cams, pay attention to not just the duration, but also the lift...if its more on the aggressive side, they may advise you to swap out the valve springs for a little stiffer ones.
