Old 05-10-2009, 04:44 PM   #1
BoostedAuto
BoostedAuto is an unknown quantity at this point
Questions reguarding my S13..=(
Im getting ready to kill this new 240!!!
Car wont start and or crank.
1.) Problem Bleeding the clutch.
~Previous owner never told me there was a 5-spd swap in the works. Bought an Agency steel braided clutch line. Been trying to bleed the system for the past 2 days, still nothing. Bench Bled the Clutch Master Cylinder, Bled again nothing.
2.) Engine Body Harness.
~Removed it to re-paint my engine bay. After I Installed it theres one connector I have no clue where it goes. Its a white connector that goes through the firewall on the passenger side. Theres 3 connectors at the end of the harness. Been fishing my hand around inside, cant see or find anything.
3.) No Crank, No Start.
~Swapped over my SR from my old S13. Pretty sure its due to problem #2 but if not, ill be bitching
4.) Reverse Lights not working:
~I finished the 5-speed swap but Im kind of iffy on it. I used How To: 5 Speed Swap in Convertibles (and other S13s): 240SX Convertible Forum: Nissan Forums / Infiniti Forums - NICOclub as refrence and after completion, still nothing. I didn't connect the brn/ylw wire to the grn/blu wire due to the fact I believe that is for convertable's to make the top function. Correct me if Im wrong.
5.) Pass rear wheel unable to move.
~I did a 5-lug swap since I upgraded to Z32 brakes. The night I put it on, wheel spun freely, next day it doesn't budge. I haven't pulled it apart yet. Possibly be the z32 backing plate be slightly off??
Pretty sure that covers most of it....Any help would be greatly appreciated!
BoostedAuto is offline   Reply With Quote
