Old 11-05-2006, 06:50 PM   #1
nissantfsx
nissantfsx's Avatar
nissantfsx is an unknown quantity at this point
Send a message via AIM to nissantfsx
B&M short shifter?
Has anyone here experienced grinding when they shift with the B&M short shifter for s13?
I currently have a aftermarket(dono what brand) short shifter on...and it grinds occasionally when i shift into 1st, 2nd and reverse...i am sure its the short shifter because when i put the stock one back on...it doesnt grind...So i happened to take out the aftermarket short shifter today and found out the bushing was broken into 2 pieces...
heres a pic of what the short shifter has done...
i donno if this is normal wear...Right now, I am just thinking about replacing that crappy short shifter that I have with a B&M one.
nissantfsx is offline   Reply With Quote
Old 11-06-2006, 04:04 AM   #2
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
I have the B&M waiting to be put on. I tried to install it but the 2 bolts in front of she shifter plate wont come off so I plan to put it in when i put in my other tranny. It looks like a nice unit as far as I can tell.
Are you talking about the white cap that goes to the bottom of the shifter that is broken?
Jung918 is offline   Reply With Quote
Old 11-06-2006, 12:48 PM   #3
nsany(atl)
nsany(atl) is an unknown quantity at this point
I have it, it's great cost mor but is worth it. you can get to the t front bolts by dropping the trans crossmember and removing them from the top
'92 C-West Sil/80 SR ***SOLD***
'95 Track car
nsany(atl) is offline   Reply With Quote
Old 11-06-2006, 01:40 PM   #4
soreballz
soreballz's Avatar
Trader Rating: (22)
Feedback Score: 22 reviews
Well, if that white cap (bushing) is busted, thats PROBABLY why its grinding into certain gears. Go to the local Nissan dealer and spend the 5 bucks on a new one, and see if that solves your problem.
-Kyle
Old 11-07-2006, 12:03 AM   #5
nissantfsx
nissantfsx's Avatar
yes...
thnx for the installation tips...
Thnx, but i have tried to put my stock shifter's bushing on the aftermarket shifter...and what happened was that I couldnt even shift into first gear... =(
just to clarify on the part where i think the short shifter is wearing down...(colored in red)
Old 11-07-2006, 03:42 AM   #6
soreballz
soreballz's Avatar
Trader Rating: (22)
Yeah, that wear is definately NOT normal. Even my 140K+ mile tranny still looks brand new.
-Kyle
Old 11-07-2006, 08:38 PM   #7
94cc0rd
94cc0rd's Avatar
I have a B&M short shifter in my s14 and it grindes from 2nd to 3rd once in a while... and its tough to get into 1st and reverse sometimes...
might be the same problem
94cc0rd is offline   Reply With Quote
Old 11-08-2006, 01:25 AM   #8
nissantfsx
nissantfsx's Avatar
have u have any other aftermarket shortshifter installed before the B&M? I dont think its the B&M thats causing the problems...
well, what i do is i would try to go into a few gears first (like 3rd and 4th...) everytime before i hit reverse...and the funny thing is that you will be able to shift into reverse smoothly without grinds.
I just hope that it is not a major problem... =(
Old 11-08-2006, 04:30 AM   #9
Vatche
Vatche's Avatar
Trader Rating: (289)
Vatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfectionVatche is close to perfection
Feedback Score: 289 reviews
the white bushing costs 1.27 cents. lol.
I dub thy the socal zilvia slut.
The Ultimate For Sale Thread <> Review Thread
Vatche is offline   Reply With Quote
Old 11-08-2006, 10:52 AM   #10
Slidin240Wayz
Slidin240Wayz's Avatar
He mentioned the OEM one won't work.
If you white bushing cracked, that mean the grinding down you see is caused by the metal on metal contact.
You might also have problems with the gears in your tranny.
Carlos
Old 11-08-2006, 11:51 AM   #11
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
yea your synco's are probably on their way out, its a common problem with 240's
Slip Gypsies Blog
not sure if you realize this
Old 11-08-2006, 07:03 PM   #12
kandyflip445
kandyflip445's Avatar
It's a common problem with all high mileage transmissions. Not just 240's.
I have a B&M knock-off and it's been working good for about 2 years now I think. I would try changing the fluid in your tranny at the same time. It does wonders for shifting if the fluid in there is old.
My 240 vBgarage
Old 11-08-2006, 09:37 PM   #13
nissantfsx
nissantfsx's Avatar
anyways...thnx for the feedbacks guys!
