Old 09-06-2006, 05:19 PM   #1
khilgers
khilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond repute
removing clutch dampner, any negative side effects?
I am starting on my swap soon and I had some concerns about removing the clutch dampner. I have all the parts here, I'm just wondering if there are any side effects to removing it. I know the positive side of removing it is becuase it tends to trap air bubbles in the system, rendering the clutch so it doens't engage. Are there any bad sides to removing it, pedal feel, proper engagement? Help me out if you can.
khilgers is offline   Reply With Quote
Old 09-06-2006, 06:23 PM   #2
Slidin240Wayz
Slidin240Wayz's Avatar
Only positive side effects. Do it!
Carlos
Old 09-06-2006, 06:47 PM   #3
g6civcx
g6civcx's Avatar
There is no problem with engagement. If anything, it helps the engagement since there is less line to go through and less likely to trap air.
I prefer the feel. It feels a little more solid. With the damper it's just sloppy, but apparently the guy in the other thread doesn't like it. It's all preference.
Old 09-06-2006, 06:48 PM   #4
speedstar01
speedstar01's Avatar
speedstar01 is a jewel in the roughspeedstar01 is a jewel in the roughspeedstar01 is a jewel in the roughspeedstar01 is a jewel in the roughspeedstar01 is a jewel in the roughspeedstar01 is a jewel in the roughspeedstar01 is a jewel in the rough
just do it...nike
but seriously carlos is correct do away with that dampaner!
speedstar01 is offline   Reply With Quote
Old 09-06-2006, 08:10 PM   #5
drifter808
drifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of light
again all personal preferance
drifter808 is offline   Reply With Quote
Old 09-06-2006, 08:21 PM   #6
Irukandji
take it out. easy to bleed, better pedal feel, takes 5 minutes.
Old 09-06-2006, 11:09 PM   #7
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
Clutch pedal response will be stiffer and vibrate somewhat more.
Whether that's a good or bad thing is subjective.
I like the feel better. Plus, it makes bleeding the clutch a hell of a lot easier. Well worth it, in my opinion.
HalveBlue is offline   Reply With Quote
Old 09-06-2006, 11:49 PM   #8
trsilvias13
side effect is if you do not know how to do it right. You have to bend the hardline back toward the slave and if you mess up.. sucks...
just buy a ss line from m/c to slave from taka. It is pretty cheap already.
Old 09-07-2006, 12:39 AM   #9
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
You might feel a little pedal vibration at higher RPMs. Thats about it. Nissan put the dampner in just to eliminate the chance of pedal vibration from the clutch at higher rpm shifts. There are no negative side effects and it makes the clutch system a hell of a lot easier to bleed without it. I prefer it taken out as well.
New Video
Buy my mounts!
Old 09-07-2006, 05:04 AM   #10
khilgers
I already have the new hardline and a stainless nismo soft line. Any suggestions for bending? I read a write up about it and the guy used a couple open end wrenches. Are there any type of pipe benders out there specifically for this, just to lessen the chance of kinking the hard line?
Old 09-07-2006, 07:52 AM   #11
FinalDrive
FinalDrive's Avatar
FinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud of
Use flare nut wrenches, not open ends since they are made for jobs like this. I doubt there are any special pipe benders
FinalDrive is offline   Reply With Quote
Old 09-07-2006, 08:00 AM   #12
broken240sx
broken240sx is on the path to ruinbroken240sx is on the path to ruin
The stock lines are pretty strong, I bent them into submission with my fingers and never had a problem (and the clutch line got a lil bent out of shape when I pulled it from its original home too). I think there are small pipe benders out there, try a hardware store. And definitely lose the damper for simplicity's sake.
Also, you might replace the slave while at it (27$ at pep boys). Mr. slave can leave you stranded...
For bleeding-- I use the tube and cup brake bleeder kit from the auto parts shop. I've been able to bleed the clutch alone without a speed bleeder, just follow your FSM -- and definitely go and buy a 10mm flare wrench, otherwise you will strip the fittings and have to use a vicegrip to get them unthreaded...
broken240sx is offline   Reply With Quote
Old 10-11-2006, 06:25 AM   #13
fromxtor
fromxtor's Avatar
fromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfectionfromxtor is close to perfection
Send a message via AIM to fromxtor Send a message via Yahoo to fromxtor
Btw heres the walkthrough fro doing it http://garage.projectraine.com/ goto garage guides page 2 its there.
Seller feedback>>http://www.zilvia.net/f/showthread.p...light=fromxtor
fromxtor is offline   Reply With Quote
Old 10-11-2006, 10:33 AM   #14
!Zar!
!Zar!'s Avatar
There isn't a need for a pipe bender. Just curve it in multiple spots. The only part that is annoying is attempting to get the hardline lined up to screw it in.
Takes about ten minutes, and that's including jack+stands.
Once installed, bleed your clutch through the slave cylinder.
Took me about a week to get use to the vibration. Because I kept thinking I had air in my lines.
Old 10-11-2006, 11:03 AM   #15
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
I use a pipe bender at work. We only use it to get the general shape and then just tweak it with our hands to fit the fittings.
Jung918 is offline   Reply With Quote
Old 10-11-2006, 12:19 PM   #16
Nuisance Crew
Nuisance Crew is an unknown quantity at this point
Just use a 10mm union in place of the dampner, done.
Nuisance Crew is offline   Reply With Quote
Old 10-12-2006, 05:04 AM   #17
g6civcx
g6civcx's Avatar
Use a Taka Motorsports line and throw away all the stock parts.
Old 11-25-2006, 06:00 PM   #18
bigflip
bigflip is an unknown quantity at this point
I would like to say thanks to Zilvia forum it help me fix my clutch problem.Also thanks to projectraine.com for a picture detail on how to do it.I like to see the project at task before i mess something up.
bigflip is offline   Reply With Quote
