Old 08-31-2007, 09:33 PM   #1
george marrero
george marrero is not welcome here anymoregeorge marrero is not welcome here anymoregeorge marrero is not welcome here anymoregeorge marrero is not welcome here anymoregeorge marrero is not welcome here anymoregeorge marrero is not welcome here anymoregeorge marrero is not welcome here anymoregeorge marrero is not welcome here anymoregeorge marrero is not welcome here anymoregeorge marrero is not welcome here anymoregeorge marrero is not welcome here anymore
s13 rim ,tire and alignment
hey i was woundering what are the best off set numbers for this rim size front 17 by 8, rear 17 by 9 and also what about tire size and then a good 4 wheel alignment spec for a s13
george marrero is offline   Reply With Quote
Old 08-31-2007, 09:37 PM   #2
projekt_s13
projekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfection
Send a message via AIM to projekt_s13
-67 looks so good. And put some 185/20/17 on them
projekt_s13 is offline   Reply With Quote
Old 09-01-2007, 09:20 PM   #3
Drifterxxl180
Drifterxxl180's Avatar
Drifterxxl180 is on a distinguished road
Keep the offset on the front below +30 or will rub coilovers. On the rear +10 looks good if you want a real stretched tire 215/40 17 slight stretch 225/40 17
Drifterxxl180 is offline   Reply With Quote
Old 09-01-2007, 10:12 PM   #4
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
205-45-17 thats what i run on my 9"
Originally Posted by drift freaq View Post
I suggest you shut the fuck up.
Sir is offline   Reply With Quote
