Old 02-06-2008, 04:39 PM   #1
tv188m
tv188m is not welcome here anymoretv188m is not welcome here anymoretv188m is not welcome here anymoretv188m is not welcome here anymoretv188m is not welcome here anymoretv188m is not welcome here anymoretv188m is not welcome here anymoretv188m is not welcome here anymoretv188m is not welcome here anymoretv188m is not welcome here anymore
Exclamation CraShed! whats wrong?
so the other day i was messin round like a dumbass on the way to work and decided to drift the off ramp... bad decision... long story short curbed it will full force bout 35 mph with a miss perceived counter steer... wheel was bent in from the bottom.. bent lower control arm.. replaced it but the ball joint didnt fit to the end of the axle where the brake is as smoothly as i thought it should.. took some beating in.. the sway bar didnt fit either... some other parts could be bent but what else do you guys think i f'd up/ any chance the subframe bent???
thanks
tv188m is offline   Reply With Quote
Old 02-06-2008, 04:44 PM   #2
panama DRIFT
panama DRIFT's Avatar
panama DRIFT is an unknown quantity at this point
Send a message via AIM to panama DRIFT
posting things like this will get you neg repped fast (as well as clowned)
in other words "Zilvia dont take to kindly to that thur street drifting"
to answer your question yes i think you bent your sub-frame, im no auto-tech, but I think you fucked somthing up kinda BAD
Last edited by panama DRIFT; 02-06-2008 at 04:51 PM.. Reason: i guess im "hit-enter-to-soon-man" sbmail >187<
panama DRIFT is offline   Reply With Quote
Old 02-06-2008, 04:45 PM   #3
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
hard to say with out any pix.
iono if you talkin about the front or the rear. guessing rear because you said axle.
fS! vlsd ! slim fans ! hid kits ! lug nuts !
http://www.zilvia.net/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
Old 02-06-2008, 04:50 PM   #4
Fries
Fries's Avatar
Most people that learn that street drifting is not the way to go either
a) Fucked their car up someway doing it.
b) Saw someone else fuck their car up.
c) Thought about what could go wrong and decided not to do it.
Now that you learned your lesson, go get some pics up so we can try and tell you what you have to do.
Old 02-06-2008, 04:54 PM   #5
tv188m
aight well i did learn my lesson this shit it hassling me way to much... time to take racing off the streets damn im stupid haha
ill have pics up soon...
thnx
Old 02-06-2008, 05:24 PM   #6
tt99ol
tt99ol's Avatar
tt99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond repute
Send a message via AIM to tt99ol
its especially stupid because you are in california which has track time all the time, but i see where your coming from, any way the frame is probably bent if its in the front or the subframe is tweaked
tt99ol is offline   Reply With Quote
Old 02-06-2008, 05:29 PM   #7
samplesurf
samplesurf's Avatar
samplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to all
i hit a curb once, bent the lower control arm, tore the subframe where the control arm bent up into it and busted my axle but you couldnt tell just from looking at it, it actually pushed the u joint through the metal casing under the boot so i had to replace everything, was a good time to upgrade
samplesurf is offline   Reply With Quote
Old 02-06-2008, 05:30 PM   #8
ryguy
ryguy's Avatar
ryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfection
Just get under there and compare it to the side that isnt bent. You should be able to spot a bent frame easily if that's what it is (providing it's bent enough), I had a car 2 years ago that had a bent frame and I could tell just by looking. You're lucky if its the rear instead of the front though, at least its replaceable. Then you have the opportunity to put new subframe bushings in.
ryguy is offline   Reply With Quote
Old 02-06-2008, 05:37 PM   #9
DaPCWiz
DaPCWiz's Avatar
DaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond repute
Send a message via AIM to DaPCWiz Send a message via MSN to DaPCWiz Send a message via Yahoo to DaPCWiz
mmm I railed in a curb at ~20 mph (at impact) a few months ago, but it was the front. Ended up with minor rim damage, fucked up caster, and really fucked up steering rack. Ended up having to get a new steering rack and everything else aligned back into place without a problem at the shop.
Like everyone else said, jack up the car and look around at everything connected to the wheel that you hit. If the rear subframe is bent, you can get another one and replace it.
http://blog.dapcwiz.com
DaPCWiz is offline   Reply With Quote
Old 02-06-2008, 06:33 PM   #10
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
good work man! take some pictures
WheelsDirty
Old 02-06-2008, 07:33 PM   #11
jackjack
jackjack's Avatar
could be a number of things. NO way to tell. dont bother posting pics unless they are going to be SUPER detailed. just take it to a shop and get an estimate. go from there. if you want, get the parts and fix it yourself after they tell you what you need.
Old 02-07-2008, 02:30 AM   #12
tv188m
thanks for the help...
Old 02-07-2008, 02:32 AM   #13
tv188m
subframe
so how much did you end up spending on dat stuff?
Old 02-07-2008, 03:22 AM   #14
samplesurf
samplesurf's Avatar
spent like a 100 bucks at the junkyard for a subframe and control arm, got another axle from my buddy for free and then upgraded to rucas and toe rods, and did subframe collars while i was at it
Old 02-07-2008, 03:30 AM   #15
mnmax
mnmax's Avatar
mnmax is making a name for him/her selfmnmax is making a name for him/her self
$500... that will get you a complete rear subframe off an r32 that will bolt right up. also gives you a viscous lsd and 5-lug hubs and rotors. same brake setup as a z32
GIGGITY GIGGITY GIGGITY GOOOO!!!!
mnmax is offline   Reply With Quote
Old 02-07-2008, 11:12 AM   #16
jackjack
jackjack's Avatar
if you're strapped for cash at the moment, junkyard is the way to go. you'll find everything you need for dirt cheap. i had to replace some stuff on my passenger side, after my car decided to kiss the curb. new parts are costly.
Old 02-07-2008, 11:34 AM   #17
jeffsm3
jeffsm3's Avatar
jeffsm3 has a reputation beyond reputejeffsm3 has a reputation beyond reputejeffsm3 has a reputation beyond reputejeffsm3 has a reputation beyond reputejeffsm3 has a reputation beyond reputejeffsm3 has a reputation beyond reputejeffsm3 has a reputation beyond reputejeffsm3 has a reputation beyond reputejeffsm3 has a reputation beyond reputejeffsm3 has a reputation beyond reputejeffsm3 has a reputation beyond repute
[quote=tv188m;1819105]hey guys thanks for the help... and for those with negetive feed back common!! havent had much experience with 240s and dont know to much bout track events
you said it best right there.... If you dont have much experience that must mean you really dont know much about drifting.. in turn which means you shouldnt have tried to drift.. especially on the off ramp of a FREEWAY!
i also see that you were probly on zilvia before this accident.. There is events posted all over the place.. how you dont see them i dont know. Now for some old man fatherly advice.. dont drift in so cal on offramps to the freeway.. your gonna hurt somone or yourself..
if you want to learn more about events.. contact jack or jxn or any of the 626 or touke guys.. im sure they would be more then happy to explain how all the fun drifting stuff takes place..
TEAM SUS*PECT
jeffsm3 is offline   Reply With Quote
Old 02-07-2008, 11:40 AM   #18
DisEpyon
DisEpyon's Avatar
DisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to beholdDisEpyon is a splendid one to behold
Send a message via AIM to DisEpyon
post up pic's man, hate when people say they will post some and never do.
Be the first person to post up pics of their own mistake,
DisEpyon is offline   Reply With Quote
Old 02-07-2008, 11:53 AM   #19
Dream240
Dream240's Avatar
This says it all. You fucked something up bad, well something other than your ego.
And to the OP, judging from your initial post, I have no idea which wheel you're talking about.
Ball joints fitting into axles...? hpmh. Now I'm getting just as confused as you are. Take some pics man, cause really this thread is just meant for bashing you for being such a dumbass without pics.
If it's the front end you're referring to then, the easiest things to bend are the control arm, inner tie rod, rim, strut, pillow mount, and lastly subframe.
On the rear end, the parts that can be bent/damaged are the lower control arm, traction rod, toe adjusting arm, shock, rim, and lastly the subframe. Sometimes you can be real lucky and crack the actual subframe from the force of the impact, or the driveaxle can become damaged. Also check your tranny mount & tranny crossmember for damage, also your diff mounting bushings for cracks, sheared bolts, etc.
Just a little piece of advice, STOP DRIVING RWD CARS. You're obviously too stupid to realize that you lack the skill to control the car at anytime besides driving straight. So sell the 240, get a civic/integra, and start redlight racing until you get busted by Johnny Law. Then after about $3000 in fines, 6-18 months license suspension, skyrocketed ins. rates, community service/jail time, and a couple other surprises, see if you want to get back behind the wheel. Best of luck to you in your future endeavors.
Old 02-07-2008, 03:38 PM   #20
Saucy240
Saucy240's Avatar
Saucy240 is an unknown quantity at this point
thanks
dont be to upset about it, life happens everyday, just learn from your experience. These forums are notorious for ethugs and perfect drivers who never make mistakes. Good luck getting the car back on track.
Saucy240 is offline   Reply With Quote
Old 02-08-2008, 12:03 AM   #21
DataXUnknown
Trader Rating: (30)
DataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfection
Feedback Score: 30 reviews
Troy, I couldn't PM you for (probably because of all the neg. rep or somthing) but you can see if the parts car down in Costa Mesa has what you need. Just let me know exactly what you f'ed up so I can check to see if it has all that. I can probably help you on install. You still have your tiburon right? Hopefully you do hahah.
PM me your phone number or somthing if you need anything.
(Nvm just read your engine blew up on your tib. damn that thing was clean and nice. Sounded sick, hopefully you can get everything together man)
DataXUnknown is offline   Reply With Quote
