Old 11-27-2007, 03:53 PM   #1
rocksteady_racer
rocksteady_racer is making a name for him/her selfrocksteady_racer is making a name for him/her selfrocksteady_racer is making a name for him/her self
Send a message via AIM to rocksteady_racer Send a message via Yahoo to rocksteady_racer
s13 Quick Tire Question
I have a set of Buddy Club Rims 17x9s, Offset +37 I'm going to be running on the back of my '91 240sx Hatch. I'm doing a 5 lug swap with 300zx brakes and the 300z e-brake. There are 275/35 tires on there right now. Would I be able to fit a 275/40 on? I can't find any tires in the 275/35 size that I can order quickly. Or will a 255/35 or 255/40 fit on these also? I'd rather have a little smaller tire also if that is possible but I don't know if a 255 would fit on a 9 inch wide rim. Also with this offset will I need a spacer? I don't want to tear apart the whole rear end and put the hub on only to realize that I need to get a spacer to put the rim(ie when I put my front 5 lug conversion with 17x8s I needed a 15mm spacer.) I have stock suspension also. I need to swap out the brakes soon because the stock rears are really annoying (my third 240). Thanks in advance for the help.
rocksteady_racer is offline   Reply With Quote
Old 11-27-2007, 04:07 PM   #2
tt99ol
tt99ol's Avatar
tt99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond repute
Send a message via AIM to tt99ol
yeah you need a spacer, check the wheel whore fitment thread for the size
tt99ol is offline   Reply With Quote
Old 11-27-2007, 04:07 PM   #3
CusCo_S14
CusCo_S14's Avatar
CusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud ofCusCo_S14 has much to be proud of
that tire size seems a little to big for that wheel.
u should probably put a 235-255/40-17
on my s14 im running 18*9 225/40-18 18*10 245/40-18
CusCo_S14 is offline   Reply With Quote
Old 11-28-2007, 03:26 PM   #4
chester_ff7
chester_ff7's Avatar
chester_ff7 will become famous soon enoughchester_ff7 will become famous soon enoughchester_ff7 will become famous soon enough
Send a message via AIM to chester_ff7
well i run 255/35 on my 9.5 rims... 275 on 9s may be a bit big... i think 255/35 is your best bet.
chester_ff7 is offline   Reply With Quote
Old 11-28-2007, 03:33 PM   #5
i need tires
i need tires's Avatar
i need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to all
Send a message via AIM to i need tires
i run 225s on my 17x9s... i would run 235s
JadeCantDrift Blogspot
i need tires is offline   Reply With Quote
Old 11-28-2007, 10:48 PM   #6
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Depending on the tire you are going to use you can use 275's on a 9" wheel. Some tires have different min rim width specs than others though so do the research if that is the width that you want. All that spec really means is that the tire is designed to function normally at that rim width, you can go outside the range but you may end up hurting the tire's performance. That width tire on that rim width will have drawbacks though. You will not be able to space your wheel out to have the "flush" look. You will end up with a little sidewall flex, however most high performance tires have sidewalls that are stiff enough so that it will not be a problem. It all really depends on what you like. If you like stretch and super flush wheel fitment, then use skinnier tires. If you want max contact patch then use the widest tires possible.
Old 02-10-2008, 05:31 PM   #7
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
i've got 245/40's they look meaty, would rather have 235/40
SoguRacing is offline   Reply With Quote
Old 02-10-2008, 08:50 PM   #8
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
205/45 on my 9
going with 235/40 on the 9.5's
275 is crazy to me.
Originally Posted by drift freaq View Post
I suggest you shut the fuck up.
Sir is offline   Reply With Quote
Old 02-10-2008, 09:25 PM   #9
racepar1
racepar1's Avatar
I'm sorry but 205's on a 9" wheel is a waste of wheel. You could fit that on a 7"wheel. 275 is the maximum reccomended tire width for a 9"wheel. 235 is the smallest I think anyone should go with a 9" wheel. My .02......again!
Old 02-10-2008, 09:51 PM   #10
ALEXTHESUS*PECT
ALEXTHESUS*PECT's Avatar
wow. lots of peeps, myself included, run 215/45 tires on my 17x9 +12 wheels.
for the OP i would run 255/45
TEAM SUS*PECT
Old 02-10-2008, 09:56 PM   #11
racepar1
racepar1's Avatar
I know stretched tires are supposedly cool looking and are definitely very popular, but I just dislike them. Probably because I am a strictly grip guy, for now, when I finally decide to start drifting maybe my opinions may change. The main reason that people stretch the hell out of their tires for is super flush wheel fitment without flaring the hell out of their fenders. I just think they're dumb looking and I see no verified performance benefits. There's a lot of opinions on how they affect performance, but I have seen no real data or comparison tests. Besides I think that super wide tires look fuckin sick! Sicker than super flush wheels in my opinion.
Old 02-11-2008, 08:50 AM   #12
KA24DESOneThree
KA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfection
First, what's the car's use?
Second, what kind of tires are you looking at?
Third, what kind of power are you putting down?
Fourth, why the hell are you still a 4x4?
KA24DESOneThree is offline   Reply With Quote
Old 02-11-2008, 09:21 AM   #13
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
ahahahahahahahah yeah depending on what your doing with your car will really dictate the size of your tire, also so will your ride height
Slip Gypsies Blog
not sure if you realize this
