Old 01-24-2008, 04:29 PM   #1
S13Boosts
S13Boosts's Avatar
S13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfection
Same OLD problem
until Not I still cant figure out whats wrong with my motor...i already tried everything from the old THREADS..okay here we go i really need help with my motor! the rpm flickers UP AND DOWN when my motor is @ normal temp BUT when its cold my motor drives just fine! i already changed the spark plugs, wires, Maf is still good, Injectors fine, idk what else could it be!!
i need Help real bad i ran out of ideas...
thanks
- s13boosts!
S13Boosts is offline   Reply With Quote
Old 01-24-2008, 04:31 PM   #2
skylindrftr
skylindrftr's Avatar
Trader Rating: (26)
skylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfectionskylindrftr is close to perfection
Feedback Score: 26 reviews
put down what you have tried so far in your post so people can better help you
skylindrftr is offline   Reply With Quote
Old 01-24-2008, 04:35 PM   #3
S13Boosts
S13Boosts's Avatar
i replaced my spark plugs, new wires, check them already, Maf is still good, my timing is fine, i ran sea foam Incase my injectors were dirty but nothing was wrong with them in the first place.I also checked all my lines! Also my motor is a SOHC
Old 01-24-2008, 04:37 PM   #4
projectRDM
projectRDM's Avatar
Bad CTS. Swap it.
FORMERLY R240NA
Old 01-24-2008, 04:38 PM   #5
S13Boosts
S13Boosts's Avatar
Originally Posted by projectRDM View Post
Bad CTS. Swap it.
thanks! , something new ! thanks for the input +1 anymore?!
Old 01-24-2008, 04:42 PM   #6
projectRDM
projectRDM's Avatar
When the car warms up, it switches to a hot fuel map. With the CTS bad, it never does so, so the car runs rich, dumping fuel, and goes into open loop.
FORMERLY R240NA
Old 01-24-2008, 04:43 PM   #7
rlpinoy
rlpinoy has made poor choicesrlpinoy has made poor choicesrlpinoy has made poor choicesrlpinoy has made poor choicesrlpinoy has made poor choicesrlpinoy has made poor choicesrlpinoy has made poor choices
maybe bad Idle Control Valve?
FS Exhaust, Q45 ignitors, & MORE!
rlpinoy is offline   Reply With Quote
Old 01-24-2008, 04:44 PM   #8
S13Boosts
S13Boosts's Avatar
All this was started from a major bump on the road, shit was like a mutha, could it go bad cause of that?
Old 01-24-2008, 04:44 PM   #9
S13Boosts
S13Boosts's Avatar
it couldnt be cause i can smash on this car till it goes to normal temp lol, Plus my idle is just fine
Old 01-24-2008, 04:49 PM   #10
projectRDM
projectRDM's Avatar
There's no way to tell. The CTS is a simple device, but anything can cause it to go bad. Connection could be loose, the plug could be broken, one of the pins could have corroded through and broken off, check it and see. An air pocket could also have been trapped behind it for a while.
FORMERLY R240NA
Old 01-24-2008, 04:50 PM   #11
S13Boosts
S13Boosts's Avatar
alright thanks, ima go check on it right now!
Old 01-24-2008, 04:57 PM   #12
Rob's S14
Rob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfection
Send a message via AIM to Rob's S14
also, be sure to clean your throttle body. i had some gunk on mine and when the car would warm up it would melt that gunk and the throttle plate would stick while idling.
Rob's S14 is offline   Reply With Quote
Old 01-24-2008, 05:14 PM   #13
S13Boosts
S13Boosts's Avatar
will do+1
Old 01-24-2008, 05:36 PM   #14
kafanylovesme
kafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfection
Send a message via AIM to kafanylovesme
I had this same problem on my sohc, but it was throwing the EGR code, I believe it is 32? Just replaced the EGR and some other things and its running fine now. My car would also run fine up until it warmed up and then it would just die at around 2500 rpm's. Is your car throwing any codes bro?
kafanylovesme is offline   Reply With Quote
Old 01-24-2008, 05:47 PM   #15
S13Boosts
S13Boosts's Avatar
okay so i just started my hatch, i havnt drove it more than couple weeks due to this problem! i just cleaned my TB right now, everything sounded fine until it was reaching normal temp my rpm NOW its at 1250 way too high.....,no my car isnt throwing any codes someone while back told me a code 34 but how? single cams dont have knock sensors! so pretty much all i gotta do now is check my CTS hope thats it... more input please thanks!
Old 01-24-2008, 06:13 PM   #16
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
You forgot to mention your car would misfire every now and them.
Video record it. IMO your car sounds like shit. so let ppl with more expertise hear whats going on.
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 01-24-2008, 07:01 PM   #17
S13Boosts
S13Boosts's Avatar
oh yeah i forgot about that, LOL that flickering is the misfire, yeah ima go make a vid soon as the rain clears!
Old 01-24-2008, 07:13 PM   #18
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
I'd also check, if you haven't yet, cap and rotor as well as the intake.
Old 01-24-2008, 07:27 PM   #19
Xandy Boosts
Xandy Boosts's Avatar
Xandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfection
Send a message via AIM to Xandy Boosts
maybe it's his shitty exhaust. never heard the misfire from his car yet though.
it's a RUCKUS life
Xandy Boosts is offline   Reply With Quote
Old 01-24-2008, 07:39 PM   #20
Turtle
Turtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymore
I too have the same problem I idle at 1900 RPM it sucks, it misfires at idle and off of heavy throttle. Checked timing it lined up good but rpm went up, plugs get fouled easy after like 5 minutes of use. They're not oily or with gas, they're black and dry.
Turtle is offline   Reply With Quote
Old 01-24-2008, 07:42 PM   #21
S13Boosts
S13Boosts's Avatar
@ xandy hahah MY PIPING's BANGIN!!
and for turtle time to read up On this thread ur problem is my problem also, hahah im going to check my CTS tommrow thanks for the input guys!
Old 01-26-2008, 03:49 PM   #22
S13Boosts
S13Boosts's Avatar
NEW UPDATES**** i just changed my CTS! i got it from one of my extra sohc's, now when its cold it flickers..... so im guessing its a bad CTS? i dont want to buy a new one and same thing happens input please thanks!
Old 01-27-2008, 12:40 PM   #23
S13Boosts
S13Boosts's Avatar
so i changed both sensors for the CTS no luck anymore input lol i need help bad i needa sell this car ! thanks guys!
Old 01-27-2008, 12:54 PM   #24
270R
270R's Avatar
270R is a glorious beacon of light270R is a glorious beacon of light270R is a glorious beacon of light270R is a glorious beacon of light270R is a glorious beacon of light270R is a glorious beacon of light270R is a glorious beacon of light270R is a glorious beacon of light270R is a glorious beacon of light270R is a glorious beacon of light270R is a glorious beacon of light
sounds like your MAF may have crud built up on the actual sensor wire.
take some throttle body cleaner and spray but dont touch the wire on your Maf.
270R is offline   Reply With Quote
Old 01-27-2008, 12:56 PM   #25
S13Boosts
S13Boosts's Avatar
i cleaned the maf already, dude i tried soo much shit to this car, i ran outta ideas..
cliff notes***
changed spark plugs
new wires
changed CTS,came off old sohc tho?
timing is good,but now its way to high
cleaned maf
sounds like its mis firing?
cleaned TB
Old 01-27-2008, 01:17 PM   #26
S13Boosts
S13Boosts's Avatar
also i will be making a video soon!
Old 01-27-2008, 01:44 PM   #27
270R
270R's Avatar
if possible try swapping it with a known good maf. I had a truck with that problem. or could have an intake leak something could of gotten loose when you hit that bump . try misting your intake with something like starter fluid see if your get a reaction from your idle. just be carefull
my two cents good luck...
Old 01-27-2008, 02:03 PM   #28
S13Boosts
S13Boosts's Avatar
the maf is good, i dont think anythings leaking but ima try go see, im about to make a video as soon as the damn rains stops!
Old 01-27-2008, 02:24 PM   #29
nousablenames133
nousablenames133's Avatar
nousablenames133 is making a name for him/her selfnousablenames133 is making a name for him/her self
Bad or dirty IACV. I've had this problem. Cleaning it out with some carb/brake cleaner works as a temporary fix. There was a thread somewhere here on zilvia.com that showed exactly where to spray.
nousablenames133 is offline   Reply With Quote
Old 01-27-2008, 02:29 PM   #30
S13Boosts
S13Boosts's Avatar
for some reason i dont think it is,but for the hell of it ima just try it,thanks MORE INPUT PLEASE! +1 for everyone for helping!
