Old 06-10-2008, 08:54 PM   #1
LA_phantom_240
LA_phantom_240's Avatar
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
KA Dies after warming up
In the last stages of project "Get this fucking s13 running already, goddamnit!", we finally have my friend's s13 running on all four cylinders (Gasp!) with no fuel leaks (Double gasp!)... but when he starts it, it idles at 1500rpm until it comes up to operating temp, at which point the idle drops to about 500 and dies shortly after. What should we look for?
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 06-10-2008, 08:57 PM   #2
dori_sil8t
dori_sil8t's Avatar
dori_sil8t is making a name for him/her selfdori_sil8t is making a name for him/her self
coolant temp sensor.(ect) also O2 sensor. check them out
unionautoclub.com
dori_sil8t is offline   Reply With Quote
Old 06-10-2008, 08:59 PM   #3
LA_phantom_240
O2 sensor is brand new. Coolant temp sensor may be an issue... what about the TPS needing adjustment? Its only slightly off, but off nonetheless.
Old 06-10-2008, 09:01 PM   #4
Phlip
Yes, I look like that
Phlip's Avatar
Idle Air Control Valve as well
Weirdo
And I write too!
Old 06-10-2008, 09:31 PM   #5
projectRDM
projectRDM's Avatar
CTS for the win.
FORMERLY R240NA
Old 06-10-2008, 09:41 PM   #6
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
Did you set base idle and timing correctly? Sounds like once the IACV-Air Regulator closes the IACV-AAC valve isn't allowing enough air threw to maintain idle either because it is stuck closed and or the idle air control screw is improperly set.
Old 06-10-2008, 09:52 PM   #7
LA_phantom_240
Hmmm..... I gotta make sure that the IACV's vacuum hose is hooked up right. I have a feeling he capped it off by accident when we got rid of all the emissions devices lol.
Old 06-10-2008, 09:59 PM   #8
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
Unplug MAF and start car and see if problem goes away.
Then make sure the IACV is hooked up, and all that. Then seafoam it.
KA-T_240 is offline   Reply With Quote
Old 06-11-2008, 06:34 AM   #9
LA_phantom_240
Motor is freshly rebuilt. MAF was bad when we got the motor back, so we got another. It will rev past 2500 so its not bad.
Old 06-11-2008, 08:28 AM   #10
g6civcx
g6civcx's Avatar
Maybe not relevant to your problem, but if this were a Honda, I would immediately suspect the fuel injection relay. The relay fails when it gets warm.
If you've tried and nothing else makes sense, perhaps check your relays?
Old 06-11-2008, 11:28 AM   #11
LA_phantom_240
The car will stay running if you give it some gas, but won't idle on its own.
Old 06-11-2008, 11:35 AM   #12
renegade_ewok
renegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to behold
Definitely check the all the valves in the IAC system. If you open the throttle body it won't matter how much or how little air the idle valves let through since you are bypassing.
renegade_ewok is offline   Reply With Quote
Old 06-11-2008, 11:42 AM   #13
LA_phantom_240
Yeah, that's what I'm thinking.
