Old 11-26-2008, 10:55 AM   #1
veeates36
veeates36's Avatar
veeates36 has a reputation beyond reputeveeates36 has a reputation beyond reputeveeates36 has a reputation beyond reputeveeates36 has a reputation beyond reputeveeates36 has a reputation beyond reputeveeates36 has a reputation beyond reputeveeates36 has a reputation beyond reputeveeates36 has a reputation beyond reputeveeates36 has a reputation beyond reputeveeates36 has a reputation beyond reputeveeates36 has a reputation beyond repute
Send a message via AIM to veeates36
Wiper Fuse Keeps Blowing.. Please HEEEELLLPPP..
Ok so as the title states the Wiper Fuse feeps blowing in my '91 240SX.. I already replaced the fuses (A few times) and I even replaced the actual Wiper Motor which seemed to work for the drive home but not this morning.
I'm stuck and it's raining pretty hard over here in the 818, so if anyone can please help me out I'd appreciate it very much. Thank you
Zombi_Army... Coming Soon
veeates36 is offline   Reply With Quote
Old 11-26-2008, 11:33 AM   #2
codunc
codunc's Avatar
codunc is making a name for him/her selfcodunc is making a name for him/her self
i would inspect the wiring, it may be shorted out somewhere
codunc is offline   Reply With Quote
Old 11-26-2008, 12:01 PM   #3
mobilesuit818
mobilesuit818's Avatar
mobilesuit818 is an unknown quantity at this point
It looks like a short.
Do a battery pull test.
Quality is not expensive, its priceless.
mobilesuit818 is offline   Reply With Quote
Old 11-26-2008, 12:03 PM   #4
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Send a message via AIM to s13 @ fullboost
+1 battery pull test
s13 @ fullboost is offline   Reply With Quote
Old 11-26-2008, 12:16 PM   #5
veeates36
veeates36's Avatar
Battery Pull Test..? I'm sorry.. I dont what that is.
Old 11-26-2008, 03:28 PM   #6
veeates36
veeates36's Avatar
Any other tips..? Thank you all again
Old 11-26-2008, 03:39 PM   #7
s13Carlo
s13Carlo's Avatar
s13Carlo has a spectacular aura abouts13Carlo has a spectacular aura abouts13Carlo has a spectacular aura abouts13Carlo has a spectacular aura abouts13Carlo has a spectacular aura abouts13Carlo has a spectacular aura about
Send a message via AIM to s13Carlo
yea ok hes gonna do a pull test in the middle of rain with probably no equipment for it. its most likely a short, it could be a motor thats shorted out or maybe even your wiper switch or all the wire that runs from under the steering wheel column to the motor if you really need to get em working and if you wanna risk it you can by pass the fuse and just get a paper clip and put it in place of the fuse it will work, also check what amperage fuse your using because it might not be the correct resistance and thats why it keeps blowing out
s13Carlo is offline   Reply With Quote
Old 11-26-2008, 04:21 PM   #8
veeates36
veeates36's Avatar
Sounds good.. I just dont understand what made this happen.. It was working fine just a couple of weeks ago.. sigh
Old 11-27-2008, 12:39 AM   #9
idlafie
idlafie's Avatar
Electrical shorts can be due to various reasons. A loose wiring harness rubbing up against something, a bad ground wire, a heavy electrical load on the circuit, etc, etc, etc, Whatever the reason may be, you'll have to repair it if you want to continue to use your windshield wipers. Since the windshield wiper is a pretty simple electrical circuit to work on, your best bet is to use the SEARCH function here on Zilvia & see if you can locate a link to a Factory Service Manual for your model year car. Once you find that link, click on it & download the Factory Service Manual appropriate for your model year car.
After you've downloaded the FSM, go to the Body / Wiring section in the FSM and follow the instructions on how to troubleshoot your electrical short problem. You'll need a voltmeter / continuity tester to test the windshield wiper switch, your ground wires and the wiring between the motor & the switch. You should be able to figure out where your problem is and fix it. It's just going to take you time to isolate the problem. If you're not familiar with troubleshooting electrical problems, then you'll have to take your car in to a mechanic or automotive wiring specialist.
Anyhow, hope this helps....Good luck!!
ID
Old 11-27-2008, 12:41 AM   #10
TheSquidd
TheSquidd's Avatar
This happened to me.
My tire had rubbed through my left side fender harness. I would check that, especially if you have a lowered car.
TheSquidd is offline   Reply With Quote
Old 11-27-2008, 12:45 AM   #11
idlafie
idlafie's Avatar
Originally Posted by s13Carlo View Post
.... and if you wanna risk it you can by pass the fuse and just get a paper clip and put it in place of the fuse it will work,
Oh....before I forget.....
Unless you want to COMPLETELY fry your wiring harness and catch your car on fire, I would strongly recommend you NOT do this!!!
ID
Old 11-27-2008, 06:36 AM   #12
g6civcx
g6civcx's Avatar
This is correct. Never bypass a fuse. When the fuse is blowing, there is a reason why.
Most likely you have a faulty ground, or a short in the left front fender harness. Check those two first and look for broken wires.
A broken wiper motor would not break the fuse unless there is a short in the ground wire.
Old 12-03-2008, 05:16 PM   #13
veeates36
veeates36's Avatar
Thank you very much for all your help guys. Thank you
