Old 11-19-2007, 09:17 PM   #1
AzNCmB
AzNCmB's Avatar
AzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond reputeAzNCmB has a reputation beyond repute
Send a message via AIM to AzNCmB
FS: 210 BAR/ 3045 PSI High Press. Power Steering Line(s)
hey guys,
For sale, high pressure power steering lines. Unlike the factory line that leak over time, these lines would never break if installed correctly! Great for any type of driving/racing. I have a few of them and would sell them for $75 shipped or picked up each.
Features:
210 bar/3045psi High press. Eaton Aeroquip hosing
fittings and o-rings
factory replacment
all hardware included for installation
Benefits:
Withstands way more pressure than what stock ps can produce, meaning more full lock to full lock counter steering action!
No more leaks
same price as oem lines from napa, pretty sure they are cheaper than oem nissan
long lasting
eliminate the long loop of stock line, which gives better clearance if you're using e-fans such as altima or want a cleaner less cluttering engine bay.
right now, all i have is lines for dohc ka24de which is also compatible with sr20det motors.
disclaimer: these are for offroad use only, i am not liable for product failure wich includes but is not limited to mis use or improper installation. Also, these eliminate the factory ps pressure sensor.
reply here, or pm me if interested...
thanks in advance
payment method:
paypal or money order via snail mail or cash in hand(in person transaction)
paypal address will be up once i get someone interested...
installed pictures and installation below...
duh mah! wheels and suspension!
AzNCmB is offline   Reply With Quote
Old 11-19-2007, 09:38 PM   #2
ctm_motortrends
ctm_motortrends's Avatar
ctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfection
Can I get a pic of it installed ? Dibs on one.
ctm_motortrends is offline   Reply With Quote
Old 11-19-2007, 09:41 PM   #3
AzNCmB
AzNCmB's Avatar
yes, i will get a few pics of it installed on my s14 tomorrow when there's daylight. I will also include a short install instructions too.
thanks for your interest.
Old 11-20-2007, 09:56 AM   #4
AzNCmB
AzNCmB's Avatar
heres installed pictures: (no flash)
(flash)
^^ basic instructions^^
these come 17inches long, which imo is just about enough in length, but I can get them longer or shorter if you guys need it to clear more stuff.
When ordering, please specify custom length if needed, if you don't, then you would get the standard 17inch.
lmk
Old 11-20-2007, 12:21 PM   #5
sean350z
sean350z's Avatar
sean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of light
I may take one...what's the fitting/thread pitch size on the rack for the low pressure line?
Thanks,
Sean.
sean350z is offline   Reply With Quote
Old 11-20-2007, 12:30 PM   #6
AzNCmB
AzNCmB's Avatar
Thanks,
Sean.
i'm not %100 sure whats the size/thread pitch, since i reused the stock fitting and just bought new hoses...
judging from the picture, it looks similar to the high press. side that goes into the rack, so who know's, they both may be the same 14x1.25.
hope that helped...
bump!
Old 11-20-2007, 12:38 PM   #7
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
its 16mm, same as used for pump.
Originally Posted by drift freaq View Post
I suggest you shut the fuck up.
Sir is offline   Reply With Quote
Old 11-20-2007, 02:58 PM   #8
vutony
vutony's Avatar
Trader Rating: (145)
vutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfection
Feedback Score: 145 reviews
from the pics, the line looks stretched
interested if you have have it coupel inches longer
i have engine hoist for rent
i do SR wiring
vutony is offline   Reply With Quote
Old 11-20-2007, 03:50 PM   #9
AzNCmB
AzNCmB's Avatar
its not stretched at all, as much as you can try, physically, you cant stretched these lines...
and yes, i can get them longer if u need, just let me know the length, as stated in the previous post, these are perfect for me, no stretch or anything, clears the crossmember fine
Old 11-20-2007, 04:57 PM   #10
AzNCmB
AzNCmB's Avatar
pics of what i have so far...
i can get more to0...
bump, lmk!!! ready to ship!
paypal address is [email protected]
Old 11-20-2007, 11:42 PM   #11
AzNCmB
AzNCmB's Avatar
bump, paypal address up!
Old 11-21-2007, 01:11 AM   #12
vutony
vutony's Avatar
how long is it?
is it the same length as stock
intersted in any trades?
http://www.zilvia.net/f/showthread.php?t=165039
i do SR wiring
Old 11-21-2007, 07:04 AM   #13
sean350z
sean350z's Avatar
Bump paypal sent.
Old 11-21-2007, 07:52 AM   #14
statik
statik's Avatar
statik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond repute
Send a message via AIM to statik Send a message via MSN to statik
interesting, though I thought those double loop lines in the front were for some sort of cooling?
97 240sx esaarr | Current Status: SOLD
statik is offline   Reply With Quote
Old 11-21-2007, 09:07 AM   #15
AzNCmB
AzNCmB's Avatar
Originally Posted by vutony View Post
how long is it?
it is not the same length as stock, its around 16 or 17inchs long. The lines eliminate the stock loop that goes from the pump to the front(near the radiator) and then to the rack.
This line is straight point A to point B, Ps pump-----> steering rack, no loops, a small S bend, thats it.
the only thing im interested in your thread to trade is the nismo 740cc injectors, but Im sure u want cash+trade, right now I cant do that, but I'll let you know when I have funds available.
Bump paypal sent.
thanks! will be shipped ups today! i'll get u a tracking number...
hmmm...
i dont think so because the oem cooler is on the low pressure side, its a bunch of aluminum tubes that go from the driverside to the pass. side along the cross member.
Old 11-21-2007, 11:10 AM   #16
Skullavera
Skullavera's Avatar
Skullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfection
Send a message via AIM to Skullavera
Will the price be the same if the line is 20" long? I think that length would be perfect for me.
Reviews/Feedback!
Skullavera is offline   Reply With Quote
Old 11-21-2007, 11:24 AM   #17
grnappletree14
grnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfection
can u tell me the fitting sizez i have a aircraft place by my house that can make them lmk thanks
grnappletree14 is offline   Reply With Quote
Old 11-23-2007, 08:16 PM   #18
AzNCmB
AzNCmB's Avatar
^^bump^^bump^^^^bump^^^^
Old 11-25-2007, 03:01 AM   #19
AzNCmB
AzNCmB's Avatar
bump!!bump!!bump!!bump!!
Old 12-04-2007, 04:06 PM   #20
vutony
vutony's Avatar
ill take one line plsu cash for the 740cc whenver ur ready
i need line to be an inch or so longer
i do SR wiring
Old 12-04-2007, 06:39 PM   #21
Bushido
Bushido's Avatar
can you make a hose for the low pressure side too?
Old 12-05-2007, 01:14 AM   #22
AzNCmB
AzNCmB's Avatar
no,
i'd rather not, because the low pressure is fine with the stock line or a stock replacement hose...it doesnt seee much pressure, hence "low pressure"
Old 12-05-2007, 04:24 PM   #23
lbsam
lbsam's Avatar
lbsam is making a name for him/her selflbsam is making a name for him/her selflbsam is making a name for him/her self
you still have some of these left? I can't purchase until next friday.. (pay day.). JW if you still have some because im needing one.
lbsam is offline   Reply With Quote
Old 12-05-2007, 04:25 PM   #24
AzNCmB
AzNCmB's Avatar
yes, i have like 4 more left...
lmk
Old 12-05-2007, 08:34 PM   #25
dops13
dops13 is just really nicedops13 is just really nicedops13 is just really nicedops13 is just really nicedops13 is just really nicedops13 is just really nicedops13 is just really nicedops13 is just really nicedops13 is just really nicedops13 is just really nice
I sent you money. This is way cheap!!!
dops13 is offline   Reply With Quote
Old 12-05-2007, 09:53 PM   #26
AzNCmB
AzNCmB's Avatar
thanks guys, payments recieved...
will ship out 2morrow...
expect usps priority
Old 01-21-2009, 09:13 AM   #27
D.Bo
D.Bo's Avatar
D.Bo is an unknown quantity at this point
BUUMP!! just bought my second line for my other 240. ive had it on my s13 for over a year now and ive just got another one for my other s13. great product good seller
D.Bo is online now   Reply With Quote
