Old 09-16-2010, 05:56 AM   #1
Tidoxp
Tidoxp's Avatar
Tidoxp is an unknown quantity at this point
no fan on a koyo radiator?
two people told me it wasnt a big deal to have a radiator fan with a koyo high performance rad, since it cooled just fine for them. any experience with that?
and does anyone have any reviews on cx racing radiators for an s14 ka24?
Tidoxp is offline   Reply With Quote
Old 09-16-2010, 06:06 AM   #2
waxball88
waxball88 is an unknown quantity at this point
You should always use a fan on a radiator. Even with a high performance, thick radiator. Any time you stop....your radiator isn't cooling. I have a CXr rad and it works wonderfully.
waxball88 is offline   Reply With Quote
Old 09-16-2010, 06:07 AM   #3
ZX88
ZX88's Avatar
no. it might be ok for dding but as so as you go spirited driving your fucked.
Old 09-16-2010, 06:07 AM   #4
nippon240
nippon240's Avatar
nippon240 is an unknown quantity at this point
A friend of mine Lives there in SD,and he has only been running 1 fan on his CXracing radiator for a little over a year with no over heating problems at all. He has a Kouki Ka24de
nippon240 is offline   Reply With Quote
Old 09-16-2010, 06:07 AM   #5
bb4_96
bb4_96 is an unknown quantity at this point
Get a fan.
bb4_96 is offline   Reply With Quote
Old 09-16-2010, 06:13 AM   #6
Okinawandrifter87
Okinawandrifter87's Avatar
Trader Rating: (22)
Okinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfection
Feedback Score: 22 reviews
Don't be cheap get a fan. Even if its a clutch fan. Some debate that they even work better, it just takes up more space is all.
Driftphreak87
Okinawandrifter87 is offline   Reply With Quote
Old 09-16-2010, 06:25 AM   #7
irax
irax's Avatar
become a fan
irax is offline   Reply With Quote
Old 09-16-2010, 08:58 AM   #8
Sam_Well.13
Sam_Well.13 is an unknown quantity at this point
i experience this first hand. Before i deleted my clutch-fan, I did not have any problem of over-heating , let alone running a lil hotter than normal. Then i put in an E-fan and my temp would very slightly move above normal before going down to its running temp, it even gets worst when A/C is on.
I think it could be the coolant, wasnt bled right maybe after i change the fans and fluids.
Sam_Well.13 is offline   Reply With Quote
Old 09-16-2010, 09:03 AM   #9
Okinawandrifter87
Trader Rating: (22)
Before or after were you running a stock or nismo thermostat or no thermostat at all?
Driftphreak87
Old 09-16-2010, 09:05 AM   #10
Sam_Well.13
i was just running stock thermostat and everthing else.
Old 09-16-2010, 09:18 AM   #11
Sterlz
Sterlz's Avatar
Sterlz is an unknown quantity at this point
I have a CXR radiator with stock clutch fan and shroud, I had electric fans but I didn't want to deal with the wiring, car idles great, cools fine, just recently replaced the temp sensor for the gauge so I know it's accurate! And when I beat on it it's steady warm.
http://sterlz.wordpress.com/
Sterlz is offline   Reply With Quote
Old 09-16-2010, 09:23 AM   #12
Sileighty_85
Sileighty_85's Avatar
what gauge are you basing this off of?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 09-16-2010, 09:34 AM   #13
Okinawandrifter87
Trader Rating: (22)
I totally forgot to ask this question lol.
Driftphreak87
Old 09-16-2010, 09:35 AM   #14
Sam_Well.13
the cluster. HUD have a dot on the temp gauge where it should be at warm running temp. and i would slightly go over that.
Old 09-16-2010, 09:37 AM   #15
Okinawandrifter87
Trader Rating: (22)
Yeah but the cluster gauge is usually not that accurate if I'm not mistaken. I assumed you meant aftermarket.
Driftphreak87
Old 09-16-2010, 09:41 AM   #16
Sam_Well.13
No, i have no aftermarket gauge on my car.
but i see what you're saying, the thing is though, I never had a problem with the gauge needle going over its normal running temp when i had the OE A/C fan, and clutch fan along with the shroud. Now that i have a Ford escort/Taurus fan with its own shroud, my temp would slightly go above normal and gets even worst when A/C is on.
Old 09-16-2010, 09:43 AM   #17
Okinawandrifter87
Trader Rating: (22)
True I know what your saying. However it is only in the general vicinity if it is the oem gauge. You probably want to use an aftermarket of some kind if you want an accurate reading.
Driftphreak87
Old 09-16-2010, 09:46 AM   #18
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
i have a cxr radiatior on an big turbo sr with an electric fan ive never had a problem and most times in the summer drifting my temp doesnt break 190, ive never overheated or had any issue of the sort
NO HANDS IN PANTS!!
landins13 is offline   Reply With Quote
