Old 07-18-2008, 01:59 AM   #1
Go180sx
Go180sx is on the path to ruinGo180sx is on the path to ruin
s14 power window promb.
hey zilvia need help with my power window prom. Some reason the window doesn't go up. How do you know if your power window amp is bad. Casue only my driver side window doesn't wpork, and all ihear is clicking sound. Please help thanks
Go180sx is offline   Reply With Quote
Old 07-18-2008, 02:17 AM   #2
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
mine just craped out tonight too
i can hear it click
in for answers
importdude is offline   Reply With Quote
Old 07-18-2008, 02:24 AM   #3
Go180sx
Just driver side right cause my pass side works fine. Help please
Old 07-18-2008, 02:31 AM   #4
nokiafan88
nokiafan88 is an unknown quantity at this point
might be the power window motor and regulator....
nokiafan88 is offline   Reply With Quote
Old 07-18-2008, 02:32 AM   #5
importdude
importdude's Avatar
yep just driverside
i been searching and it says window amp
also 1995 ONLY (out of all s14's) have window amp
96+ has window amp built in the switch
is yours a 1995? mine is
Old 07-18-2008, 03:05 AM   #6
kaboomwoom
kaboomwoom is an unknown quantity at this point
it's the power window amplifier. happened to me already. ~$70 at the dealer.
kaboomwoom is offline   Reply With Quote
Old 07-18-2008, 07:26 AM   #7
WIKID S4TEEN
WIKID S4TEEN's Avatar
WIKID S4TEEN is making a name for him/her selfWIKID S4TEEN is making a name for him/her self
Yeah you need this...
http://www.courtesyparts.com/Merchan...e=28515-S14AMP
Rock wha U jock and don't talk if U ain't got!!
WIKID S4TEEN is offline   Reply With Quote
Old 07-18-2008, 09:36 AM   #8
Dream240
Dream240's Avatar
I got lucky and snagged one off ebay for 35 bucks.
And yes that part is your problem. 100%
Old 07-18-2008, 09:40 AM   #9
onehundredoctane
onehundredoctane's Avatar
onehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfection
if you know anything about electronics or circuitry I'd look at repairing the problem yourself, or atleast making it less likely to become the problem again.
onehundredoctane is offline   Reply With Quote
Old 07-18-2008, 09:57 AM   #10
Dream240
Dream240's Avatar
Well the problem with this is that these window amps notoriously go bad. They just give out over time. There's really nothing to fix. Just replace it. Done.
In about 10-12 years it'll prolly go bad again....just replace. done.
Old 07-18-2008, 09:59 AM   #11
garbury
garbury is making a name for him/her selfgarbury is making a name for him/her self
Just to chime in, it's not always 100% the little white amp box. In my case the window motor just died completely.
garbury is offline   Reply With Quote
Old 07-18-2008, 10:22 AM   #12
slidingsky
slidingsky's Avatar
slidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfection
Good point but if you own a 95 then it is about 98% of the time the problem
slidingsky is offline   Reply With Quote
Old 07-18-2008, 10:44 AM   #13
codunc
codunc's Avatar
codunc is making a name for him/her selfcodunc is making a name for him/her self
there's one circuit in them that fails most of the time, and its an easy fix. happened to me.
http://www.nicoclub.com/articles.php?id=245266
codunc is offline   Reply With Quote
Old 07-18-2008, 10:56 AM   #14
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
... well since most of that info was useless, I'll go ahead and post.
Unplug the window motor. Wire it directly to the battery with some lone wire. 1 to pos, 1 to neg.. to power the motor directly, and reverse. the wires you're plugging into the motor connector. If the motor is fine, borrow a buddies amp and window switches.. I replaced my amp, and bam it stopped working again.. turned out the window switches were fucked up. So before you go replacing shit.. make sure it will actually fix the problem first. If I find the amp I had (1 week old), you can have it.
-Bart
DJ_Sunrise is offline   Reply With Quote
Old 07-18-2008, 11:44 AM   #15
Dream240
Dream240's Avatar
If you've got a clicking noise and no worky for the window, it's 99.999999999999999% of the time the window amp.
There's always going to be exceptions to the rules....but I like my odds.
Oh and DJ Sunrise, you may want to keep that amp. The second you get rid of it.....well you know.
Old 07-18-2008, 11:51 AM   #16
slidingsky
slidingsky's Avatar
I lol'd at that.
Old 07-18-2008, 03:47 PM   #17
Go180sx
thank codunc. I'm going to try fixing it first and if that doesn't work I guess I have to buy new one. (I'm broke) thanks peepo
Old 07-18-2008, 03:56 PM   #18
importdude
importdude's Avatar
right now im gonna try fixing /determining the problem
hopefully its just the amp
update-
i went out and the window started working on its own again?
gonna try it again tonight
Old 07-19-2008, 02:18 PM   #19
Go180sx
Ok I tried to fix it but I don't see any broken connection.so is my amp bad or what? I don't get. I don't want to spend 75 and find out that it's not my amp.
Old 07-19-2008, 05:18 PM   #20
chituntang
chituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nicechituntang is just really nice
Did you check your motor before you go any further? My amp is gone, but the motor was done also. The wire got caught at the gear, which overdrive the amp and burned the motor in my case. Now when I plug a new motor in, it will run for 2 secs then die again.
chituntang is offline   Reply With Quote
Old 07-19-2008, 05:29 PM   #21
jjjjjjjjjjjjjjjjjjjjjjjjj
jjjjjjjjjjjjjjjjjjjjjjjjj is just really nicejjjjjjjjjjjjjjjjjjjjjjjjj is just really nicejjjjjjjjjjjjjjjjjjjjjjjjj is just really nicejjjjjjjjjjjjjjjjjjjjjjjjj is just really nicejjjjjjjjjjjjjjjjjjjjjjjjj is just really nicejjjjjjjjjjjjjjjjjjjjjjjjj is just really nicejjjjjjjjjjjjjjjjjjjjjjjjj is just really nicejjjjjjjjjjjjjjjjjjjjjjjjj is just really nicejjjjjjjjjjjjjjjjjjjjjjjjj is just really nice
well if youre not too anal about things then mostly all nissans and infinitys use the same amp/connector. the only differance is the mounting points.
i used my friends 14 for a day and just my luck as soon as i roll down the window i had the same problem so i used my m30s one first. when i had a chance i swapped it out with an s13 one and still works fine to this day. only other problem he had was his drivers side switches went out a couple months later. usually thats the problem with 96s though (i think the amp is built in to the switch).
m30 guys had the same problem and said they used j30 and maxima amps so im pretty sure most of the amps are the same. just gotta ziptie it up or make a custom bracket if you need it mounted that badly.
that should save you some money so you dont have to go out and buy a brand new one.
jjjjjjjjjjjjjjjjjjjjjjjjj is offline   Reply With Quote
Old 07-19-2008, 05:31 PM   #22
projectRDM
projectRDM's Avatar
J30, Maxima, and Altima do not use external amps. You can use M30, Q45, or G20 though. Same piece, different bracket.
FORMERLY R240NA
Old 07-19-2008, 05:55 PM   #23
aahhhh it must have been a q45 or g20 then. my bad i just read what they posted on that
Old 07-19-2008, 09:37 PM   #24
oscarsx
oscarsx's Avatar
oscarsx is making his/her stupidity well-knownoscarsx is making his/her stupidity well-knownoscarsx is making his/her stupidity well-known
gawd i just got the same problem in my s14, driver side.. but i guess i will give that repairing thing a try, if not then ill just buy my self a new one:/
IG: @ozc2jz
oscarsx is offline   Reply With Quote
Old 07-19-2008, 11:01 PM   #25
importdude
importdude's Avatar
well here it goes
today it wont roll up
did all the stupid fsm stuff
cant figure it out
so i had to park in my cousins garage for the night
early tomarro i will have to goto the junkyard to get a new amp to see if that fixes it, and then go look at my used door i bought hopefully it has the regulator on it so i can swap if it is indeed bad
oh i cant repair mine b/c i cant see any solder points that are broken
Old 07-20-2008, 08:04 AM   #26
Dream240
Dream240's Avatar
update-
That's the amp talking. You've got a short in it. Did you try taking off the door panel and playing with the switch to see if you could get it to work? Try it. Take the panel off, plug the window switch back in, turn your car to the on position. Then wiggle the connector at the amp, does it work intermittently? If it does, replace amp.
Or you can try to 'repair' the amp, I have no idea how to do this because I've never tried it. Mainly because you can find used amps for 40 online, or new for 75. If you don't have the cash for it, just leave it up and don't go through any drive-thrus for a while.
Good luck.
Old 07-20-2008, 11:27 AM   #27
importdude
importdude's Avatar
Good luck.
yah i took off the door panel trying to work stuff
i even gave the regulator power directly and it wont move
going right now to get an amp
Old 07-21-2008, 02:38 AM   #28
importdude
importdude's Avatar
got a amp off a g20 today,
same thing
my cousin opened the window motor and found out the "black voltage regulator" was the problem
we made a little wire jumper and bypassed it, then it WORKED!
so i just used it to reinstall window up
now to find a new motor
or that little chip
Old 07-21-2008, 06:39 AM   #29
slidingsky
slidingsky's Avatar
I was gonna post as well that I pulled an amp from a 1990 G20 and although it has different part numbers, it does work.
Old 07-21-2008, 08:32 AM   #30
projectRDM
projectRDM's Avatar
Part numbers are different because the bracket is different.
FORMERLY R240NA
