Old 03-04-2013, 10:28 AM   #1
OutlawLui
OutlawLui's Avatar
OutlawLui is a well-known jackass
(*)(*)sr20det help!!(*)(*)
I noticed my SR RedTop had the wrong O2 sensor
-Instead of the Titania (Skinny) o2, it had a Fat o2
So i got the correct skinny o2, but wiring looks off;;;
[[[UPDATE]]]].......................................
Correct wiring for 62 ecu and skinny o2 is;
harness------skinny o2
Brown--------red
White---------black
Black---------white
OutlawLui is offline   Reply With Quote
Old 03-04-2013, 10:53 AM   #2
OutlawLui
OutlawLui's Avatar
I know someone has to know something..Zilvians !!!!!!!!!!!
Old 03-04-2013, 11:36 AM   #3
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
Last I did this, I thought the polarity doesn't matter. Find the signal wire and connect that first, then wire the other two which ever way.
*I think.
di-devol is offline   Reply With Quote
Old 03-04-2013, 04:55 PM   #4
OutlawLui
OutlawLui's Avatar
Come on guys, i need me 02 to work correctly..
Old 03-04-2013, 05:17 PM   #5
di-devol
http://zilvia.net/f/engine-tech/4479...o2-sensor.html
http://zilvia.net/f/tech-talk/192763...agram-s13.html
ECU's & Harnesses Differs With 02 Sensor Wiring!!!!! & Running Rich Explained!! - SR20 Forum
Quick search.
Old 03-04-2013, 05:26 PM   #6
OutlawLui
OutlawLui's Avatar
yea but these are all guessing....
1st. thread says that the White on sensor is signal
2nd thread says that the black is the sensor signal..
Thanks anyway
Old 03-04-2013, 05:56 PM   #7
ReLiC
ReLiC is an unknown quantity at this point
*I think.
I did something along these lines.
I had a hard time looking for this info as well. I'll check my wiring whenever i get a chance and post pics.
ReLiC is offline   Reply With Quote
Old 03-05-2013, 02:42 PM   #8
OutlawLui
OutlawLui's Avatar
Can anyone post pictures of there redtop o2 plug and sensor wire colors?
Old 03-29-2013, 01:05 AM   #9
ReLiC
did you figure it out? i'm trying to wire mine up as well.
Where are you grabbing the 12v from? Is it ok to just grab it from the maf power?
Old 03-29-2013, 08:29 AM   #10
OutlawLui
OutlawLui's Avatar
Yea the pic is correct
On the red top sr its
Brown--------red
White---------black
Black---------white
The brown harness wire is the 12v sourse
*on the skinny o2 sensor the black wire is the signal wire and white is ground
Old 03-29-2013, 06:20 PM   #11
Kingtal0n
Kingtal0n's Avatar
heres what I usually do. Go to pep boys and look through the oxygen sensor boxes until you find all the 1-wire oxygen sensors. Buy the cheapest one, usually $12 or $14.
Now, you know exactly which wire is the signal since there is only 1 wire. Install using the single signal wire and never worry about this again. If you put a voltmeter on the wire, it will flip from 0.005Volt - 0.985+Volt when working properly.
tinyurl.com/4l80er
Old 03-29-2013, 06:45 PM   #12
OutlawLui
OutlawLui's Avatar
Im pretty sure pepboys doesn't have a large selection of titania o2's
02 sensor, sr20det, tech, wiring
