Old 05-17-2014, 06:35 AM   #1
Boostage
Boostage is making his/her stupidity well-knownBoostage is making his/her stupidity well-knownBoostage is making his/her stupidity well-knownBoostage is making his/her stupidity well-knownBoostage is making his/her stupidity well-known
Those of you using the s15 HLSD
What 6 bolt axles are you using? I assume its 1995+ j30, but is it one driver/passenger? or is it two of one side?
Boostage is offline   Reply With Quote
Old 05-17-2014, 09:51 AM   #2
Boostage
Ok, well just found out j30 and s14 axles are the same length.
Old 05-17-2014, 12:47 PM   #3
jr_ss
I'm using the factory S14 axles... They are identical to the S15 axles. S13 6bolts will work too. Apparently you haven't done as much homework as you thought, this is basic knowledge.
Old 05-17-2014, 03:55 PM   #4
dudermagee
dudermagee's Avatar
dudermagee is an unknown quantity at this point
you just need the s15 output shafts
Originally Posted by DC Dan MAX USA View Post
Don't wuss out on me.
dudermagee is offline   Reply With Quote
Old 05-17-2014, 08:22 PM   #5
Boostage
So then what car had 5x1 axles?
Old 05-18-2014, 12:35 AM   #6
Chayans14
Chayans14's Avatar
Chayans14 is an unknown quantity at this point
I have to install 2 driver axel on both side
Chayans14 is offline   Reply With Quote
Old 05-18-2014, 01:55 PM   #7
jr_ss
Early J30's, Z32's, R-chassis and some JDM S-chassis had the 5bolts.
Old 05-19-2014, 12:03 PM   #8
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
im using my stock S13 axles, no reason to change them. they mate to the OEM S15 output shafts just fine.
but keep in mind with the S15 HLSD, you MUST use OEM S15 output shafts as they are 29 spline... all other nissan output shafts are 28 spline which ARE NOT compatable. the only car the 29 spline shafts came in was the S15 i believe (i dont think nissan used HLSDs in anything else)
Old 05-19-2014, 12:40 PM   #9
jr_ss
Some R-chassis had helicals as well.
Old 05-19-2014, 12:48 PM   #10
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
IF they came in the GTRs (which im fairly sure only came with VLSD units), then theyre 5 bolt output shafts and will require different axles. OEM S15 output shafts bolt directly up to OEM 6 bolt S13 and S14 axles.
