Old 01-27-2008, 07:23 PM   #1
noname7198
noname7198's Avatar
noname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to beholdnoname7198 is a splendid one to behold
My friend and I are building a 89 240sx coupe track car. The car will be used for drifting and maybe some autoX. The purpose of this thread is to give people some ideas for building their cars and for people to give us their ideas and constructive criticism on this build.
Here's the basic plan:
strip and stich weld the chassis
install a 6 point cage, fire wall, fuel cell, fiberglass dash, gauges and seats
install coilovers, 2-way diff, 5 lug, bushings, RUCA's & tension rods
install sr20det (basically stock for now), v-mount, 3" exhaust
silvia front end, some light body work, and paint
As of right now we have stripped most of the car. I already have the following parts:
silk road coilovers
kaaz 2 way lsd
front & rear 5 lug
180sx front brakes
ES polyurathane bushings
silvia front end (we still need a hood)
Corbeau racing seats
fn01r-c wheels 17x8 & 17x9
sr20det (need to be rebuilt)
apexi power fc
I also have a gt2871r, but I'm waiting for more $$ and more seat time before that goes on.
What I still need to get:
RUCA's
toe arms
Traction rods
tension rods
spl subframe bushings
fuel cell and plumbing
piping for exhaust, cage and IC
We spent this weekend taking the car apart. I now live 306 miles from my friends house where the car is, so updates to this thread and the car will probably only come 1 or 2 times a month. On the next work weekend we will finish stripping and start cleaning and preping the chassis for seam welding.
The budget recently got a little tighter, but I still would like to get spl tie rod ends and possibly sway bars and traction rods. To the people who track their cars, do you have or think I need bigger sway bars? Let me know what you think and why.
This is the car last week when we towed it home. It was not running and cost $550.
So I open the door before we move the car into the garage and this happens:
anyone have a door handle for sale?
Here's friday Pictures:
Saturday:
Sunday:
and just for fun:
Originally Posted by PoorMans180SX View Post
180SX brakes are Maxima brakes, just to let you know
Go to www.splparts.com and order 17x9+20 FN's for the front and rear. No reason to run an 8 inch wide wheel on the front a track car.
Looks pretty good. Looks like what I did to my fastback, hahaha. Just make sure you're organized. I totally have one of those heater-on-the-propane-tank things too.
I know the brakes are the same, but they actually came from a 180sx and they were only $20! I'm going to use these wheels while on the stock turbo. Then next fall or winter when the gt2871r goes on I'd like to get 17x10 rear and 17x9 fronts.
The heater's nice when you stand next to it, but no insulation and openings between the roof and the wall keep it about 30 degrees in there!
I finally got a long weekend to go down and work on the car. First problem, one of the sub-frame bushings froze to the stud. I cut the bushing out while it was on the car so we could drop the sub-frame, but now the inner metal sleeve is still stuck on the stud. Does anyone have any ideas for getting that off? I'll try to get a picture of it, I forgot before I left.
So we dropped the subframe, took all the suspension off of it and sand blasted so it's ready for paint.
We also took out the front corssmember and started cleaning the engine bay for seam welding and paint.
We also removed the sound deadening. That was a bitch. We used dry ice,
which helped a bit for the big flat sections, but it took a lot of work to get that out. We still have to clean it up some more and then we can stich weld and install the custom cage.
Then came the fun part. We took out the windshield. We tried to take it out in 1 piece so we could put it back in. It broke, that was fun. Then we started cutting out extra metal. We cut out the spare tire well. We are going to square off the cut and weld in a flat piece of sheet metal to mount the fuel cell to. We also cut out the rear seat suports, that will give us more room for the cage and rear firewall that's going in next.
Over the next 2 weeks my friend is going to start seam welding and also take the block to the machine shop. Next time I go down we will start some of the fabrication. Now that we're done ripping it apart we can start putting it back together.
For the rust in the engine bay, it's just surface rust so we're gonna grind the rust off, then prime and paint. We have a couple spots on the floor where it's rusted through. For that, you want to cut out all the rust, then weld in a patch pannel (cut a piece of sheet metal to fit the hole in the floor then weld it in place).
If yours is rusted through and you don't have a welder, just take the car to a body shop and see how much they want to fix it for you, probably won't be too expensive.
My friend and his buddy (a professional welder) stich welded the chassis this weekend and started filling holes in the engine bay.
This guy is awsome:
It took us about a day to get everything prepped and another day to get most of the welding done. Then my friend has been working on it an hour or 2 a day after work here and there. We're going to prime it this weekend, then hopefully get it painted in march.
Originally Posted by Landers View Post
Excellent build, do you plan on racing any scca events at all in the northeast??? Stitch welds look amazing BTW
Right now we're just focusing on getting the car done. I'm going to start looking for events once it's ready to drive.
noname7198 is offline   Reply With Quote
Old 01-27-2008, 07:33 PM   #2
greddyguy
greddyguy has made poor choicesgreddyguy has made poor choicesgreddyguy has made poor choicesgreddyguy has made poor choicesgreddyguy has made poor choicesgreddyguy has made poor choices
needs mo pics!!!
greddyguy is offline   Reply With Quote
Old 01-28-2008, 07:19 AM   #3
ByeByeSti
Banned from the Marketplace
ByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant futureByeByeSti has a brilliant future
good start bro. im doing the same with my s14 at the moment, i have it stripped down to what you do but wokring on tubs and what not for the enigne bay since i messed up at the first set. but keep up the good work and post more pics when you make more progress please
ByeByeSti is offline   Reply With Quote
Old 01-28-2008, 04:08 PM   #4
Rusker
Rusker's Avatar
Rusker is on a distinguished road
Looking good so far.
1990 S13/SR20
Rusker is offline   Reply With Quote
Old 01-28-2008, 04:43 PM   #5
unicoladron
unicoladron's Avatar
unicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choices
i love build threads. noname, i suggest you look at Gavster's and CursedGTR's builds for ideas/insparation. their builds are effing awesome.
550 is steal for a chassis in such good condition. have fun with the build!!
1993 KA24DE for sale with 180k..running when pulled.... need to get rid of ASAP...i'm moving
unicoladron is offline   Reply With Quote
Old 01-28-2008, 04:23 PM   #6
alindeman1989
alindeman1989's Avatar
alindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to all
Send a message via AIM to alindeman1989
good start, keep us updated
alindeman1989 is offline   Reply With Quote
Old 01-28-2008, 04:34 PM   #7
PoorMans180SX
PoorMans180SX's Avatar
180sx front brakes
Old 01-28-2008, 08:31 PM   #8
PoorMans180SX
Oh, nice price!
I take it you already bought the wheels. Too bad.
Old 01-28-2008, 09:08 PM   #9
weagle
weagle's Avatar
weagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant future
Broken door handle = weight savings. Just tie a string to the inside handle and hang it out the window. Ghetto shaved door handles
weagle is offline   Reply With Quote
Old 02-19-2008, 05:59 PM   #10
IcedOutSoulja13
IcedOutSoulja13 will become famous soon enoughIcedOutSoulja13 will become famous soon enoughIcedOutSoulja13 will become famous soon enoughIcedOutSoulja13 will become famous soon enoughIcedOutSoulja13 will become famous soon enough
Send a message via AIM to IcedOutSoulja13
dont forget toe links in ur set up...if u plan on getting a good alignment ull be stuck with only a limit of toe adjustability due to the stock restrictions..i only say this because once u put on aftermarket RUCAs the toe can only be corrected with aftermarket toe links...
as for sway bars i personally have tanabe and noticed a significant difference but alot of guys on the forums say that the stock ones are beefy enough and have just enough play to make the car handle well...maybe just get some sway bar endlinks and main bushings?
IcedOutSoulja13 is offline   Reply With Quote
Old 02-19-2008, 06:02 PM   #11
ALEXTHESUS*PECT
ALEXTHESUS*PECT's Avatar
good job so far. almost looks like a hatch from this view:
TEAM SUS*PECT
Old 02-19-2008, 06:14 PM   #12
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
great start man! are you planning on selling the intake ? if so, let me know!
WheelsDirty
Old 02-19-2008, 07:07 PM   #13
s13.dark1
s13.dark1's Avatar
s13.dark1 is making a name for him/her selfs13.dark1 is making a name for him/her self
very nice looks real good keep posting put dates and them pics to go along wit.
s13.dark1 is offline   Reply With Quote
Old 02-19-2008, 07:23 PM   #14
BoostedCoupe
BoostedCoupe's Avatar
BoostedCoupe can only hope to improve
We also removed the sound deadening. This was a bitch. We used dry ice,
Hey i see u have rust exactly were i do (on the left of the pic on the strut tower). ho do you plain on fixing this and when you do can you please go into good detail because i plain on fixing mine soon to but i cant find any threads where people fix it they basically just get a new chassis in stead. also i have rust down on where the brake line comes therw the body on the pass side. how would you go about fixing that or do you even think its worth it. thanks and nice project its nice to see someone restoring a car instead of getting a new one.
92 vert converted 5speed and other little things
BoostedCoupe is offline   Reply With Quote
Old 02-19-2008, 07:25 PM   #15
wantboost@ga
wantboost@ga is a well-known jackass
looks like a fun project, the only advise i have for auto-x is do your research on where the 240 is most competitive and make sure a mod that you really don't need doesn't bump you up to a higher class.
wantboost@ga is offline   Reply With Quote
Old 03-05-2008, 11:34 PM   #16
kognition
kognition's Avatar
kognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfectionkognition is close to perfection
Looks like a good project car for 500 bucks.
Off the top of my head:
FIBERGLASS DASH" Don't get overly exotic making one. Pre Fabbed flat panels are the way to go for good weight loss. I think my dash is 3lb's.
FUEL CELL: Not necessary right now until you start running race gas and need to control your weight (racing and TA anyway) But a good upgrade.
2 WAY DIFF: For drifting is fine. Not for racing or TA. For that you should stick with a Helical like a Quaife Helical LSD if you are serious about racing.
SWAY BAR: For drifting you want a good rigid setup front and back. For race and TA you want a rigid setup in the front, and softer setup (stock) in the rear.
WEIGHT REDUCTION: Plenty to be had starting with that sound deadening (30lb's) on that alone.
Good luck and keep us updated.
kognition is offline   Reply With Quote
Old 02-19-2008, 09:51 PM   #17
BoostedCoupe
yeah im not doing it. i jusy need some motivation that it can be repaired.
Old 02-25-2008, 12:25 PM   #18
Tops*
Tops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfection
Wow, this is like looking at my future (this year's) build.
Stitch welds look good. How long did it take total to clean, grind, and stitch everything?
I'm fucking subscribing to this build for sure.
MADE IN JAPAN
Tops* is offline   Reply With Quote
Old 02-25-2008, 12:39 PM   #19
PuffinPuffer
PuffinPuffer's Avatar
Trader Rating: (-1)
PuffinPuffer is an unknown quantity at this point
Feedback Score: -1 reviews
great build, keep all of us updated! have fun!
PuffinPuffer is offline   Reply With Quote
Old 02-25-2008, 12:41 PM   #20
joshchewuhh
joshchewuhh's Avatar
Trader Rating: (56)
joshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfection
Feedback Score: 56 reviews
Send a message via AIM to joshchewuhh
coming real nice so far!
i wanna stitch weld my chassis also i to would like to know how long it took your guy?
joshchewuhh is offline   Reply With Quote
Old 02-25-2008, 12:53 PM   #21
unicoladron
now that is some badass stich welding. the best i've seen yet! love the build so far man, can't wait to see some more progress!
what are you gonna use to protect the welds from surface rust?
Old 02-25-2008, 02:10 PM   #22
an_orange_s2k
an_orange_s2k's Avatar
an_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond reputean_orange_s2k has a reputation beyond repute
so many builds going on
an_orange_s2k is offline   Reply With Quote
Old 02-25-2008, 06:27 PM   #23
turboh224g
turboh224g is making a name for him/her selfturboh224g is making a name for him/her self
build
I am the other guy working on this build. I have to say that the professional welder, Brad, who helped us really did a great job of stitch welding. He welds for a fab shop that makes exhaust for exotics. So stepping down to weld on a 240 chasis is great for us. I finished up when he had to leave and mine may look ok and be functional but he spent half as much time as me. JKP
turboh224g is offline   Reply With Quote
Old 02-26-2008, 05:54 PM   #24
Enjin
Enjin's Avatar
Enjin will become famous soon enoughEnjin will become famous soon enoughEnjin will become famous soon enoughEnjin will become famous soon enoughEnjin will become famous soon enough
Send a message via AIM to Enjin Send a message via Yahoo to Enjin
I am doing the same thing. wondering about all of the tar that still remains after removing the sound deadening. how do you get that out? it looks so stupid haha. need that clean look.
1991 Nissan 240sx
www.tractionoptional.com
Enjin is offline   Reply With Quote
Old 02-26-2008, 07:49 PM   #25
whowutwut
whowutwut is an unknown quantity at this point
Send a message via AIM to whowutwut
When I did mine, it took forever!! but i finally removed all that tar and it looked clean... used all different types of adhesive removers and lots of rags and elbow grease..
whowutwut is offline   Reply With Quote
Old 02-26-2008, 08:26 PM   #26
Landers
Landers has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond reputeLanders has a reputation beyond repute
d-faction.com
Landers is offline   Reply With Quote
Old 02-27-2008, 06:09 PM   #27
turboh224g
sound deadening
I guess I should be commenting a bit more on exactly how we are doing things. Most people know that dry ice works well to remove the bulk of the sounddeadening on the flat surfaces. I used 5 lbs. Elbow grease is definately another part of it. There are also aircraft strippers that work well for that last bit of tar but I wanted something a little less toxic and user friendly. I used Klean Strip Premium stripper, it worked great. Very fast acting, aerosal can, and turns that tar into an easily removable jelly. I just used a paint scraper and very little effort. I also let it sit overnite on the tar patches on the back of the rear fender wells and it softened the adhesive to the point that a dull chisel scraped it right off with very little residue. There is also the issue of all the caulk in the seams. For this I used a wire twist wheel on a 7 inch angle grinder. A little scarry but very effective. Bothe the wire wheel and the stripper were purchased at Lowes. JKP
Old 02-27-2008, 06:13 PM   #28
joshchewuhh
Trader Rating: (56)
bravo!
a lot of work
im keeping watch of this thread!
Old 02-27-2008, 07:54 PM   #29
floodo1
floodo1 will become famous soon enoughfloodo1 will become famous soon enoughfloodo1 will become famous soon enough
man super clean out the engine bay..i mean fill ALL the extra holes and shape it a bit...then you can compete with the honduh guys for cleanest engine bay
l8tz
josh
Buy the best, none other compares!
floodo1 is offline   Reply With Quote
Old 03-04-2008, 05:37 PM   #30
noname7198
noname7198's Avatar
We spent last weekend getting the new trunk floor and rear fire wall fitted and welded in.
Then started on the cage. Our pipe bender didn't really work (it crushed the pipe) so I had to pay a shop to make the bends. It doesn't fit as perfect as I would like, but it's coming together nicely.
I started to prep the engine bay for paint. We welded over all the unused holes, ground them down, then used filler to smooth them out. It's still a work in progress, but it's starting to look better.
And since I don't have any money left over for adjustable traction rods, this will have to work for now.
no ac or heat or any other luxury's for that matter. It's a track car, so nothing extra.
I'm not sure about the welder, it's not mine.
The cage is just tacked in right now to make sure everything fits. It'll be a little closer when it's all done. It looks worse in the pictures than it really is. More pics will come as we get more done.
Do you have pics of your dash? I was planning to mold the stock one (just the top part). Then add flat pieces on the sides around the cage.
The cars main purpose is drifting, so that's why the 2 way.
I'm looking for a hicas rear sway bar, and thinking I'll keep the stock front for now. I'll try that out and see how I like it.
As for weight reduction, all the sound deadening is gone, pretty much everything is gone at this point. Is there anything else you can see in the pictures that you would remove?
We got some more done last week. Still finishing up the cage. Put the subframe back together and back on the car. I'm almost finished prepping the engine bay for paint. I painted under the new trunk and primed the inside of it. We also cut out and adjusted the floor for the fuel cell sump. Here are a couple new pics. I'll post more when my friend puts them up on photobucket.
engine bay almost ready for paint:
fuel cell:
Under trunk floor:
Trunk ready for paint:
Trunk lid:
Our custom knock off nismo brace:
Sub-frame ready to go back in:
Roll cage:
Apperently Jason doesn't sleep and just works on the car. Last weekend he finished the cage and fabbed the new radiator support.
He's gonna finish prepping and prime the interior so we'll be ready for paint this weekend. Then all we have to do is fit the front end, re-install the front crossmember, make a dash and door pannels, plumb the fuel system, rebuild the motor, fix the harness and a whole lot of wiring and hope it runs. Then a shit ton of body work and some suspension tuning and we're done... For now.
We fabbed up the new seat brackets. Here are some pics of the seats bolted into place.
We painted the trunk, interior and engine bay this weekend.
Painting around the cage was a huge pain in the ass, but it turned out really nice.
and the eninge bay:
We also started fitting the front end:
The exterior is going to be blue. I'm leaning toward Daytona Blue (factory 350z color) or maybe something a little more metallic.
