Old 02-19-2013, 12:06 AM   #1
1slowsilvia
1slowsilvia is an unknown quantity at this point
Exclamation Apexi Power FC question???
So I bought a S14 SR20DET and it had S14 Tomei Poncams, HKS 740s and a 2871R.
Now I was on a budget so I had the poncams taken out, replaced with Stock S15 Cams (I'm pretty sure they are same as S14) 740s replaced with S15 440s, and GT2871R replaced with Stock S15 Spec R turbo (I checked its the real deal).
My question the engine was set to run with the 1st set up on a Apexi Power FC ecu (Standalone) I now have the power FC and trying to figure out can I detune the ECU and have it put to my setup or do I have to pay someone to do it? can someone please shed some light on this?
1slowsilvia is offline   Reply With Quote
Old 02-19-2013, 06:46 AM   #2
MADE
MADE's Avatar
MADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant futureMADE has a brilliant future
Wait.......what??
You removed all the parts for S15 stock parts but you don't have the stock ECU? Is the PFC the same one that was originally tune for the car, or you brought it from someone else.
Reinitialize the tune, make inj corrections drive to tuner, since its an S14 model. Save your money and pay for a good tuner, with good reviews. Believe it or not they're hard to find. Save up and do your research.
MADE is offline   Reply With Quote
Old 02-20-2013, 08:19 PM   #3
Magnoliarichj
Magnoliarichj is an unknown quantity at this point
contact steve shadows..... shadow works
he has helped me tremendously and is super nice and knowledgeable... very inexpensive but not cheap!
tell him magnoliarichj referred you hes also on facebook
Magnoliarichj is offline   Reply With Quote
Old 02-20-2013, 08:26 PM   #4
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
Uhhhhhh................................. yea you need a whole new tune.
Old 02-20-2013, 08:58 PM   #5
SlideOrDie831
SlideOrDie831 is an unknown quantity at this point
find a factory ecu or get it retuned.
SlideOrDie831 is offline   Reply With Quote
Old 02-20-2013, 09:16 PM   #6
Casfhey
Casfhey is an unknown quantity at this point
Casfhey is offline   Reply With Quote
Old 02-24-2013, 01:29 PM   #7
steve shadows
steve shadows's Avatar
You need the map tuned back down for another setup correct?
I can do this for you remotely and I'll knock off a bit for you to save some money for the help. I can probably redraft the map to you same day for you. I'll include instructions on how to install the new settings using the commander and some instructions to synch the CAS to the PFC which most tuning shops don't even remember to do but it is required to get the motor to run best with the unit. Please email me [email protected] to inquire for more help.
PS. Thanks for the kind words Magnoliarichj!
Like Me on FaceBook !
Old 02-24-2013, 02:51 PM   #8
oni jake
oni jake is an unknown quantity at this point
LOL?
You can reset your Power F/C to factory settings in the menu on the commander. Its called "initialize" or something similar. (I'm not near my car to tell you the exact label)
When every motor upgrade is back to being at least somewhat close to stock settings, a reset should be fine. I would just double check the size differences between S14 and S15 injectors. If they are different, do some math and modify the injector duty cycles to suit your needs. If modified, change your MAF settings as well.
Stock Power F/C tune is very reliable and safe to drive around. No need to pay for a re-tune if your hurting for cash.
oni jake is offline   Reply With Quote
Old 04-30-2013, 03:08 PM   #9
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
Originally Posted by oni jake View Post
LOL?
I wouldn't initialize/factory reset the FC. What Steve said was basically is what needed. TBH sell the FC find factory ECU.
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 04-30-2013, 06:13 PM   #10
inopsey
actually all that is needed is to adjust for the different injectors...............
Old 04-30-2013, 08:24 PM   #11
smartoss
smartoss is an unknown quantity at this point
Read over this, it will give you some insight how to adjust your power fc.
and how to adjust for your larger injectors
http://paulr33.com/powerfc-faq/powerfc-faq.htm
smartoss is offline   Reply With Quote
Old 05-01-2013, 01:51 AM   #12
MrChow
MrChow's Avatar
True if it was just injectors. He changed cams too.
Guys he's gotten all the info he needs.
Old 04-30-2013, 12:58 PM   #13
Jdmsilivias13
Jdmsilivias13 is an unknown quantity at this point
Call MA-Motorsports. those guys are great and are a power fc excel dealer. they will be able to help you with what ever you need 410-593-7080
Jdmsilivias13 is offline   Reply With Quote
