Old 10-20-2006, 05:14 PM   #1
TurbLu
TurbLu is making his/her stupidity well-knownTurbLu is making his/her stupidity well-knownTurbLu is making his/her stupidity well-known
Any tricks for geting the engine mounts to line up???
Ok guys any tricks for getting the engine mounts to line up? Should I drop the engine in with the mounts on the engine or the mounts on the chassis still? Im thinking its easier to mount it with the mounts still on the engine but I could be wrong....
TurbLu is offline   Reply With Quote
Old 10-20-2006, 05:35 PM   #2
trsilvias13
I usually put the mounts on the motor and drop in. Work since the first day I did a swap, worked two weeks ago too.
Old 10-20-2006, 05:56 PM   #3
TurbLu
Ding Ding Ding - 100 times easier like that... thanks... took me 2 minutes to drop it in...
Old 10-20-2006, 06:53 PM   #4
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
http://profile.myspace.com/index.cfm...riendid=228016
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 10-20-2006, 07:05 PM   #5
Flybert
I usually put the driver side mount on the motor and leave the passenger side off. Once you get it in. Lift up the passenger side of the motor and put that motor mount in. That way usually works best for me. With my way you don't have to worry too much about stripping the studs on the mount and it's faster in my opinion. I've never used a leveler so maybe it is easy with that but without it, I've always had trouble getting both in at the same time.
Old 10-20-2006, 11:03 PM   #6
Slidin240Wayz
Slidin240Wayz's Avatar
With EM on.
Carlos
