Old 12-06-2006, 10:22 PM   #1
weagle
weagle's Avatar
weagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant futureweagle has a brilliant future
Subframe swap
I drive a 1993 240sx. The current rear sub frame is cracked right where it bolts up to the differential. I had it welded when I found out about it. Week later it started to make the noise that the welds broke. Found a new one and I would like to swap it out myself and not pay somebody a lot of money to swap it for me. Figured since I need to swap the sub frame I would also do new sub frame spacers and new nuts and bolts.
1. Any other parts I should think about replacing?
2. Anybody ever done this?
3. What tools am I going to need? Other than the obvious.
4. Maybe I am wrong maybe it won't cost a lot should I take it to a shop?
5. Any input is good input even if its negative.
I have searched all over for answers and couldn't find anything sorry if I missed the thread I was looking for.
weagle is offline   Reply With Quote
Old 12-06-2006, 11:28 PM   #2
silverarrow27
silverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud of
Easy job with basic tools, a couple jacks, and cheater bars.
I'm a 5'7" 140 lb guy and did it with no issues. It's about 6-10 bolts to drop the subframe only. Very straight forward, but use common sense as you're dropping the rear subframe out so I wouldn't lift the whole car up on jack stands; the rear end only.
1989 240sx XE|2002 Frontier SC CC LB 4wd|2011 Pathfinder LE V8 4wd
silverarrow27 is offline   Reply With Quote
Old 12-07-2006, 07:44 AM   #3
Ninjabread
Ninjabread's Avatar
I might be doing the same when i take out my HICAS subframe... Only basic hand tools needed and while you are at it, you could replace all the busings and get some subframe spacers.
613DriftWerks.ca
Ninjabread is offline   Reply With Quote
Old 12-07-2006, 08:00 AM   #4
Dousan_PG
Dousan_PG's Avatar
shit is SUPER easy
remove and replace
done!
Aaron
Pink GodziRa
Old 12-07-2006, 08:15 AM   #5
tchenku
tchenku is making a name for him/her selftchenku is making a name for him/her selftchenku is making a name for him/her self
Send a message via AIM to tchenku
oh, and don't forget to detach the e-brake lines from the subframe.
tchenku is offline   Reply With Quote
Old 12-07-2006, 11:46 AM   #6
weagle
weagle's Avatar
I destroyed my e-brake lines in a little accident in Indiana, so I guess I don't have to worry about that step in the process.
Old 12-07-2006, 11:33 PM   #7
Rayne
Rayne's Avatar
Rayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfection
Take a look at the subframe and differiental bushings and replace if they looked cracked or falling apart.
Rayne is offline   Reply With Quote
Old 12-09-2006, 01:14 AM   #8
gotta240
gotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfectiongotta240 is close to perfection
while the entire subframe is out...... REPLACE THE FUCKING BUSHINGS if you are doing any serious driving or hear clunking in the rear.
If ever, now is the time.
gotta240 is offline   Reply With Quote
Old 12-09-2006, 03:57 PM   #9
samplesurf
samplesurf's Avatar
samplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to allsamplesurf is a name known to all
+1 or at least get the collars
samplesurf is offline   Reply With Quote
Old 12-09-2006, 05:03 PM   #10
gotta240
fuck collars. If you need collars, get new bushings while its out..
collars are semi-half assed... a GREAT alternative if you dont want to remove the subframe..but if out..do it!
Old 12-09-2006, 05:26 PM   #11
drftwerks
full aluminum from spl thats what have, feel great
giantroboteyes.wordpress.com/
Old 01-19-2007, 04:07 PM   #12
S13 Charlie
S13 Charlie's Avatar
S13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura aboutS13 Charlie has a spectacular aura about
Send a message via AIM to S13 Charlie
I know this thread is a couple months old, but what's the norm for removing old subframe bushings? I remember seeing a how-to on torching them out, but can it be done with the proper sized drift and a BFH?
cheers,
Charlie
S13 Charlie is offline   Reply With Quote
Old 01-19-2007, 05:18 PM   #13
Flybert
On FA in the advanced section, they have a good writeup on it right now. It might be on the second page by now.
Old 01-19-2007, 07:13 PM   #14
longdy
longdy's Avatar
longdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud oflongdy has much to be proud of
Send a message via AIM to longdy
dang bro this is an easy ass job to do!!!... just un-bolt and pop them right in and bolt it right up!!..lol
good luck on it!
longdy is offline   Reply With Quote
Old 01-20-2007, 01:21 AM   #15
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
I have done this...... Well sort of. I found a subframe for 40 bux, had to take it out myself though. I went to the u pull it place with some 17's 15's....... (just bring all the big ones out) I also got yelled at for having a torch. But I guarantee you I would not have gotten it off without a torch. and I replaced all bushings. It is worth it. really messy and gave me a toxic headache... again that damn torch. I stripped a stud trying to get my old one off the car so project sits in my garage but all the hard work is done. I think I would have a shop do the stud though. anyway hope some of this helps. get alignment obviously.
I was going to, but I can not think of a sig less than 75 characters.
mjjstang is offline   Reply With Quote
Old 01-20-2007, 01:34 AM   #16
airsoft
airsoft is a glorious beacon of lightairsoft is a glorious beacon of lightairsoft is a glorious beacon of lightairsoft is a glorious beacon of lightairsoft is a glorious beacon of lightairsoft is a glorious beacon of lightairsoft is a glorious beacon of lightairsoft is a glorious beacon of lightairsoft is a glorious beacon of lightairsoft is a glorious beacon of lightairsoft is a glorious beacon of light
Remember to twist the bolts in by hand first to avoid cross threading. You'll really kick yourself in the ass if you decide to cross thread bolts.
airsoft is offline   Reply With Quote
Old 01-20-2007, 07:04 AM   #17
Slidin240Wayz
Slidin240Wayz's Avatar
r32 subframes fits on the s13 chassis...
Carlos
