![]() Join Date: Aug 2005
Problems with Ichiba front hubs
I took the 4 lug hub off, put the Ichiba right on and when I tighten the axle nut, the new hub does not spin. Am I doing something wrong?
![]() Join Date: Jun 2004
Location: so cal - 626, 909, 562 and 949. 818 if i feel like running away
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
make sure the slotted washer in the middle is sitting correctly before you try to bolt down the hub.
edit: if this isnt the problem, have you tried to spin the bearing freely in the hub before actaully attemping to install the unit onto the axle? |
I greased it a little. The washer was in the right spot and Yes the bearing spun before installation. I've put the 4 lugger back on for now and it is still spinning fine. I'm confused. I did 5 lug on my S14 with brand new OEM hubs and had zero problems.
yes i had the same problem when installing mine the nut does not have to be super tight pretty much snug and while tighening the nut spin the wheel assembly to set the bearings properly once the rotor stops while tightening the nut then back it of and just lightly snut the nut again this check to make sure the hub spins freely then cotter pin it this is what i did anyways good luck!!!
#8 | |
![]() Join Date: Dec 2002
#9 | |
oh boy, the nut shoot be torqued down to spec, not "back it of and just lighly snut the nut" haha
u should have a snap ring. tho ive never dealt with ichiba hubs, i remember back in the day there was a problem with peak performance hubs where the wrong snap rings were used. this might be the problem. of course, why would you be the only person with this problem? go figure =T |
#17 |
Well, I just read on Northwest Nissans that you have to replace the Ichiba retainer (left) with the OEM one off of the 4 lug hubs (right)
![]() Gonna give it a try tomorrow and I'll update. Thanks for the help everyone! |
#18 | |
![]() Join Date: Mar 2004
![]() Im willing to put good money that changing the snap ring will solve your problem, its ridiculous how much the tabs stick up on the ichiba one. |
#19 |
![]() Join Date: Feb 2006
Trader Rating: (47)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 47 reviews
Ichiba doesn't sell S14 front 5 lug conversions. And your suppose to leave the snap ring intact and not touch it. this is going into an s13 right? pm me directly if you have anymore questions.
#21 |
![]() Join Date: Jun 2006
im about 2 start my front 2morrow. i will let u know how mine turns out. im also using ichiba on s13. rears went on fine, just need rotors and wheels now :P
lexus baby |
#22 |
i am also havin the same problem as u. the washer does not seat fully like stock. it sits out a bit further. wen tightenin it down, the whole hub will not move. any ideas any1?
lexus baby |
#25 |
i just swapped the rings over and it seems it does work. the hub spins freely now, even wen the nut is tightened down
lexus baby |
#27 |
yep i finished my 5lug conversion. took me 24 hours to complete
![]() fronts were a bit harder than usual cuz i had 2 swap the rings
lexus baby |
