Old 06-05-2007, 04:35 AM   #1
blu2fourty
blu2fourty is just really niceblu2fourty is just really niceblu2fourty is just really niceblu2fourty is just really niceblu2fourty is just really niceblu2fourty is just really niceblu2fourty is just really niceblu2fourty is just really niceblu2fourty is just really niceblu2fourty is just really nice
will 18x9.5 +30 or +12 fit s14 fronts ?
im about to order a pair of wheels and dont want to go stagger set up. just want to know if anyone tried fitting a 18x9.5 + 30 or +12 on the front of a s14. i know tire will play a role also and was thinking 235/35-40/18 tires. i'm currently running 18x8.5 +25 w/ 225/40/18 the rims come very close to my coilovers too close infact but still cleared and no rubbage. any input would be great.
i have a feeling the +30 wouldn't clear the coilover but a spacer can fix that just more worried about rubage.
thanks,
jon
-94 green civic h/b(sold)
-90 Blue 240sx f/b (sold)
-90 Red Rx7 gxl (sold)
-95 gold 240sx (sold)
-95 white 240sx le (scrapped)
-95 black 240sx le w/sr (parting out)
-95 purple 240sx le
blu2fourty is offline   Reply With Quote
Old 06-05-2007, 05:42 AM   #2
300hp owen
300hp owen's Avatar
300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future300hp owen has a brilliant future
you would need +12 to clear without any other tricks or mods.
an 8.5 +25 is one inch off center, so it has about 5.25 inches of backspace.
a 9.5 +30 is more than one inch off center (30mm=1.2inch) and with the wheel being wider you end up with almost 6 inches of backspace, thats 3/4" closer to your coilovers than your current setup.
cardomain.com/id/LS1T56FC = my crazy ls1 v8 rx7 = sold
300hp owen is offline   Reply With Quote
Old 06-05-2007, 07:32 AM   #3
Slidin240Wayz
Slidin240Wayz's Avatar
go with the +12
have a torch and mallet ready for the lip
make sure you take the fender liner screws out
Old 06-05-2007, 08:11 AM   #4
Mathetai
Mathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to all
Agreed. I have 18x9 +12 with 225's in front - clears Z brakes with no headaches. GL dude.
Mathetai is offline   Reply With Quote
Old 06-05-2007, 01:33 PM   #5
blu2fourty
well im more concerned about rubbage while turning. looking at my old wheels 9'' wide w/ 235/45/17 they where too close to the fender liner.
i mite go w/ 18x9.5 +30 w/ a 15mm spacer. since +12 in the front and +30 in the rears will look funny due to the difference in concave. the wheels i want are lmgt4's and getting the better sizes are in japan which take too long and and a decent amount of $$.
any tire size recommendation? so 18x9.5+30 w/ a 15mm spacer should be good. worst case ill go w/ a 17x9 +22(also size is only avail in jap)
i dont like the non concave ones i have right now 18x8.5 +25 thats why i want to push it and put a 9.5 wide set
here is a pic of my current set up
thanks for the input guys
-95 purple 240sx le
Old 06-05-2007, 01:43 PM   #6
chmercer
chmercer's Avatar
yeah 18x9.5 fits fine
dont get the high offset and space it thats queer
get the lower one and run more camber if you need to
chmercer is offline   Reply With Quote
Old 06-05-2007, 01:47 PM   #7
khmerguy618
khmerguy618's Avatar
khmerguy618 is close to perfectionkhmerguy618 is close to perfectionkhmerguy618 is close to perfectionkhmerguy618 is close to perfectionkhmerguy618 is close to perfectionkhmerguy618 is close to perfectionkhmerguy618 is close to perfectionkhmerguy618 is close to perfectionkhmerguy618 is close to perfectionkhmerguy618 is close to perfectionkhmerguy618 is close to perfection
Send a message via AIM to khmerguy618
ahahaha
u can run 9.5 0 w/ camber and it fits fine.
Go with the lower offset.
just don't forget to relocate ur wiring harness.
Watch speed channel 12/9 @7.30PM for drifting at HIN!
[email protected]
IF you bought stuff from me write me a review HERE
||VEXMOTORSPORTS || DMAX-USA || RPS CLUTCH || BAB AUTOBODY||
khmerguy618 is offline   Reply With Quote
Old 06-05-2007, 02:13 PM   #8
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
im running a 9.5 +12, fits perfecto, even before i rolled my fenders if i remember correctly in the front. 225/40/18 tire, ive got decent clearance all around inside and outside
parking lot pimpin...
Seller Feedback here:
http://www.zilvia.net/f/showthread.p...ight=pbcstylez
pbcstylez is offline   Reply With Quote
Old 06-05-2007, 02:45 PM   #9
revat619
Retired General
revat619's Avatar
revat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfection
First off, get rid of your fender liner. Its useless. Plus, if you plan on going any lower you're going to have to get rid of it anyway. Also, i'd recommend relocating your wiring harness or atleast tucking it up higher.
Anyway, I have these wheels. 9.5 front and 10.5 rear. Run the + 12 if you can get it or just run the +30 with a 15mm spacer and run 225/40. 235/40/18s are too big for the front, but for the rear they're fine.
FYI, the 9.5s all concave the same, its only the back pad that changes.
www.Jspec.com
www.SpeedAlliance.com
www.PoweredByMax.net
Instagram: @rjsladerade
revat619 is offline   Reply With Quote
