Old 06-09-2007, 08:17 PM   #1
s14hayame
s14hayame is an unknown quantity at this point
s14 lsd into s13
hey guys i want to know beside switching the lsd cover is there anything else that i have to do. please help me out on this thanks guys
s14hayame is offline   Reply With Quote
Old 06-09-2007, 11:50 PM   #2
Agent_S13
Agent_S13's Avatar
Agent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to allAgent_S13 is a name known to all
Replace the bushings in the front of the carrier and get the shorter bolts that hold in place.
I bought ES diff carrier bushings (easy to install) and OEM bolts from the dealership. Don't forget the washers when installing the bolts.
Other than that, intall is the same as the removal.
-Aaron
'91 240sx coupe
Agent_S13 is offline   Reply With Quote
Old 06-09-2007, 11:54 PM   #3
dopeassjackson
dopeassjackson is a well-known jackass
if you have ABS you need an ABS diff
dopeassjackson is offline   Reply With Quote
Old 06-09-2007, 11:54 PM   #4
DOOK
DOOK's Avatar
he's lying, nobody has ever done it before
<------ Grumpy Old Asshole
DOOK is offline   Reply With Quote
Old 06-10-2007, 10:41 AM   #5
s14hayame
na i dont have abs, the thing is i have a s14 and im switching platform to s13, i would love to get me a real lsd but $$ is not on my side :\ . now what type of spacer do i need to use just any spacer that will fit from auto parts store or i need something special, and as far a the bushing is concern do i use the s13 bushing or the s14 bushing. thanks again guys
Old 06-11-2007, 03:04 PM   #6
Agent_S13
Agent_S13's Avatar
S13 differentials don't have bushings in the front, its metal w/ mounting holes. I don't have the part #, but you can search one of my old threads as I did this swap (well J30 VLSD to S13).
I also had no problem w/ my current non-ABS driveshaft. The extra 1/2" or so in the front for the ABS sensor (mine is still in, wires just cut) is negated by the fact that you use the S13 rear cover which is not as deep -- its easier to explain w/ pictures, but you'll see when you swap covers.
Washers are just because the bolt heads seem "small" compared to the differential hole. Just put 'em on both sides of the mounting holes and your'e set.
-Aaron
'91 240sx coupe
Old 06-12-2007, 10:16 AM   #7
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
if hes putting s14 diff, he'll need longer bolts, not shorter.
Originally Posted by drift freaq View Post
I suggest you shut the fuck up.
Sir is offline   Reply With Quote
