300zx Master Cylinder in S14---bending lines.
Hey guys, I have been doing some research and it seems like the only way to install the 300zx MC is to bend the brake lines to fit. I was wondering if there any thing i can buy or is there any way out of bending it to make it work? i know it fits in the S13 with no bending, can i swap the S13 lines into the S14 to make it work? Any help would be great. Thanks
-Kim |
![]() Join Date: Feb 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
buy a tube bender from Advance Auto or whomever. I used a manual one, but they have several styles for many gauges of tubing. Pick one and TAKE YOUR TIME!!!!! If you rush it and crimp a line, then you get to flange and tack in another piece of line...no fun. I took my time and had no problems. There is a write-up on this....search "The Definitive 300ZX Brake Swap" in Google. That write-up is a good visual for where to bend the lines, i did it to the "T" and it worked perfectly!! Good luck bud!!
Best help I can give you:
http://importnut.net/300zxbrakeswap.htm Read and read again before you get started. The hardline is soft enough you can bend it with your hands. Don't try to turn it too tight... diameter of your wrist or so. Get a bubble flare tool to make fittings on the hardlines. If you don't, you'll have to cut up one of the connectors on your stock 240SX MC and steal one of the removable fittings out of it, which is tricky and kinda dangerous with a Dremel. Voice of experience... I'm pretty sure a bubble flair tool would be a lot less headache. (See pics on the guide I linked to.) You can put the 240SX MC fluid reservoir on the 300ZX MC. That way you don't have to splice any wires. (Again, check the guide.) |
just make sure you do not bent it too much in one location. Run along the tube making gradual bends.
Sale: Hello Kitty Horn Button S14 Rear Valences K.Y. Gordon the Thief (Tony Chen) |
I am with them. no tools needed. just a slow and steady hand. I did mine with no tool in less than 3 min.s and it looks great and works better. just a side note make sure you bench bleed the bmc. trust me it saves time.
Well fine then
![]() Join Date: Apr 2004
Another option is braided lines to replace the hardlines. I know a lot of people don't like it and for your application I don't think it's necessary, but it's an acceptable alternative if you have no other option.
Before you flame me, there is no way I could use hardlines on my engine due to the motor being moved back 3" and having a distributor sticking out on the firewall. So in some situations it's justified. |
#12 | |
That is the first valid argument I have heard for using full braided ss lines from bmc back. most people just want to do it for the cool factor not realizing that braided lines wear out at some point and must be changed. sounds expensive. How much was it if you don't mind me asking?
#13 | |
The real work is in routing the lines. I have mine going into the passenger compartment and running along where the hatch/fuel release is, and out near where the driver seatbelt bolts onto the car. I wanted to protect the rear line as much as possible, and make it easier to route to a hydro handbrake later on, but you don't have to route it inside the car. |
#15 |
![]() Join Date: May 2005
When I first put the Z32 BMC in my car I hand bent all the lines and it worked fine. A month or so back I got some flaring tools, a tubing cutter, and a tube bending tool. Everything looks a lot better now that I've shortened the lines and rebent them, even though it took a while to get everything to my liking the second time around.
#17 |
Trader Rating: (40)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 40 reviews
Has anyone looked into actually getting custom stainless steel lines made with the appropriate fittings to accomplish the re-connect (extension) to the master instead of bending ?
#18 | |
![]() Join Date: Dec 2002
S13 brake lines work almost perfect. The only PITA is the front passenger brake line. Removing the old is easy, but manipulating the new line around the AC lines is a bitch. Also you will need to straighten out the end of the line going to the rears and trim about 3 inches off of it so it fits perfectly into the rear brake line connector on the firewall heading under the car. Also you will need to flare that end after cutting so it will work. Really sounds like alot but it's freaking cake. I did this setup in my old 96' and it worked alot better than the re-bending method. Mainly due to the improved routing and the lines occupy less open space on the turbo side! Really just meant for easier engine bay work. And it looks cleaner. Your choice.
Don't mess with my monkey...he's loaded. |
#19 | |
Trader Rating: (40)
#21 | |
![]() Join Date: Jan 2005
Z32 Rear conversion line. ![]() |
#26 |
You can see my custom braided lines:
![]() The previous owner spray painted the entire car. You can see indentations on the firewall where the old lines used to run. There was no way to keep the hardline and move the motor back that far. One benefit was the ability to unbolt the master cylinder and move it around when working, like changing a booster. No need to bleed brakes when removing a master cylinder. It makes it much easier to service the car. |
