Same OLD problem
until Not I still cant figure out whats wrong with my motor...i already tried everything from the old THREADS..okay here we go i really need help with my motor!
![]() i need Help real bad i ran out of ideas... ![]() - s13boosts! |
i replaced my spark plugs, new wires, check them already, Maf is still good, my timing is fine, i ran sea foam Incase my injectors were dirty but nothing was wrong with them in the first place.I also checked all my lines! Also my motor is a SOHC
![]() Join Date: Dec 2002
Bad CTS. Swap it.
When the car warms up, it switches to a hot fuel map. With the CTS bad, it never does so, so the car runs rich, dumping fuel, and goes into open loop.
would a bad CTS cause crappy idle as well?
i have the same problem. when my dohc starts bogging/hesitating the temp gauage shows that the motor's getting cooler. |
![]() Join Date: Jun 2006
also, be sure to clean your throttle body. i had some gunk on mine and when the car would warm up it would melt that gunk and the throttle plate would stick while idling.
![]() Join Date: Apr 2007
I had this same problem on my sohc, but it was throwing the EGR code, I believe it is 32? Just replaced the EGR and some other things and its running fine now. My car would also run fine up until it warmed up and then it would just die at around 2500 rpm's. Is your car throwing any codes bro?
#13 | |
okay so i just started my hatch, i havnt drove it more than couple weeks due to this problem! i just cleaned my TB right now, everything sounded fine until it was reaching normal temp my rpm NOW its at 1250 way too high.....,no my car isnt throwing any codes someone while back told me a code 34 but how? single cams dont have knock sensors! so pretty much all i gotta do now is check my CTS hope thats it... more input please thanks! |
#14 | |
![]() Join Date: Nov 2006
You forgot to mention your car would misfire every now and them.
Video record it. IMO your car sounds like shit. so let ppl with more expertise hear whats going on.
#15 | |
oh yeah i forgot about that, LOL that flickering is the misfire, yeah ima go make a vid soon as the rain clears! |
#18 |
![]() Join Date: Jul 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
I too have the same problem I idle at 1900 RPM it sucks, it misfires at idle and off of heavy throttle. Checked timing it lined up good but rpm went up, plugs get fouled easy after like 5 minutes of use. They're not oily or with gas, they're black and dry.
#19 | |
![]() and for turtle time to read up On this thread ur problem is my problem also, hahah im going to check my CTS tommrow thanks for the input guys! ![]() |
#20 |
NEW UPDATES**** i just changed my CTS! i got it from one of my extra sohc's, now when its cold it flickers..... so im guessing its a bad CTS? i dont want to buy a new one and same thing happens input please thanks!
#23 | |
i cleaned the maf already, dude i tried soo much shit to this car, i ran outta ideas.. ![]() cliff notes*** changed spark plugs new wires changed CTS,came off old sohc tho? timing is good,but now its way to high cleaned maf sounds like its mis firing? cleaned TB |
#25 |
![]() Join Date: Jul 2002
if possible try swapping it with a known good maf. I had a truck with that problem. or could have an intake leak something could of gotten loose when you hit that bump . try misting your intake with something like starter fluid see if your get a reaction from your idle. just be carefull
my two cents good luck... |
#26 | |
the maf is good, i dont think anythings leaking but ima try go see, im about to make a video as soon as the damn rains stops! ![]() |
#27 |
Bad or dirty IACV. I've had this problem. Cleaning it out with some carb/brake cleaner works as a temporary fix. There was a thread somewhere here on zilvia.com that showed exactly where to spray.
#28 | |
for some reason i dont think it is,but for the hell of it ima just try it,thanks MORE INPUT PLEASE! +1 for everyone for helping! ![]() |
#30 |
