Old 03-20-2008, 07:53 PM   #1
916S14
916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known
SR sr valve cover T thing
The little T thing that goes from the valve cover to the catch can broke off on my sr, so i was wondering if there is some way to like glue it back in there and what type of material would be useful. Something high heat. Just want to get some opinions. Thanks.
916S14 is offline   Reply With Quote
Old 03-20-2008, 08:16 PM   #2
jspaeth
jspaeth's Avatar
Glue???
You are kidding right? Just get the old one out, and buy a new one to put in.
Daily driven
Old 03-20-2008, 08:18 PM   #3
GSXRJJordan
GSXRJJordan's Avatar
Yeah, it's threaded. Get the old one (or what's left of it) out, and buy a new one, then thread it in.
Old 03-20-2008, 08:22 PM   #4
WilloW
WilloW's Avatar
WilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfection
Send a message via AIM to WilloW Send a message via Yahoo to WilloW
1. Clean the T and the hole real well
2. Mix some JBWeld
3. Coat the part of the T to be inserted back to the valves-cover as well as the hole on the valvecover with the the JB Weld
4. Insert T into hole one valve cover.
5. Let cure, and reinstall valves-cover (unless your valves-cover is still one the engine.
Atleast that's what I did and worked for me on the KA for the other valve- cover fitting. Mine just came loose but didn't break.
Edit: I didn't know that that part (the T) is threaded, sorry I couldn't help.
WilloW is offline   Reply With Quote
Old 03-20-2008, 09:01 PM   #5
916S14
wait what? its not threaded, its the T on the right side of the engine if you're looking straight at it. Mine is not threaded for sure. I shouldnt say it broke off, it more like just came out of there. I'll try the JB weld i have a lot left over from my crappy radiator.
Old 03-20-2008, 11:16 PM   #6
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
T is not threaded.
I took mine out and ran AN line to catch can.
Originally Posted by drift freaq View Post
I suggest you shut the fuck up.
Sir is offline   Reply With Quote
Old 03-20-2008, 11:27 PM   #7
JeremyR
JeremyR's Avatar
JeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the rough
Send a message via AIM to JeremyR
thats the pcv valve. there cheap. buy a new one.
JeremyR is offline   Reply With Quote
Old 03-21-2008, 06:43 AM   #8
rican_nick
rican_nick's Avatar
rican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfection
Send a message via AIM to rican_nick
the T fitting is just pressed in.
find another one and press it in.
or change it to -AN like many have done including me.
Nick O.
97 240sx
My Seller's Review Thread
rican_nick is offline   Reply With Quote
Old 03-21-2008, 07:01 AM   #9
g6civcx
g6civcx's Avatar
There is so much misinformation in this thread.
On SRs, the PCV is on the US passenger side.
The T is part of the PCV system. Open up an FSM and see.
The black canister near the turbo is not a catchcan; it's the air-oil separator. The other side of the T goes to the intake.
The T is not threaded.
