Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Specific Topics > Polls
Polls Post All Polls in Here.
View Poll Results: "Stealth Black" or Chrome Finish
"Stealth Black" 117 79.05%
Chrome 31 20.95%
Voters: 148. You may not vote on this poll
Old 05-30-2008, 09:39 AM   #1
[email protected]
kuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond reputekuah@splparts.com has a reputation beyond repute
SPL PARTS version 3 arms - new adjuster info and poll
This is our new adjuster design, a hybrid clamp and jam nut combination. This design uses a billet aluminum clamp on the rod end side and a jam nut on the arm side, to lock down your alignment setting.
We are using the clamp design for several reasons: with the old jam nut design, when tightening the jam nut on the rod end, that has a tendency to rotate the rod end. This makes it difficult to hold the alignment setting, as the rod end threads in/out combined with the jam nut stretching the thread, the alignment can shift 1/16" or more. It also makes it difficult to keep the spherical bearing centered to prevent binding under suspension travel. To get an accurate alignment while keeping the bearing centered becomes a tricky juggling act. The clamp design solves all these problems, allowing the alignment to be set without moving the rod end.
We continue to use a jam nut on the arm side because I have found that because of its size, it can be tightened without moving the adjuster or changing the length of the arm.
FWIW the new adjuster drives up our production cost on each pair of arm by $10-15. It is much more expensive than a 20cent jam nut. But for now we are keeping prices unchanged. All our v2 arms can be upgraded to the new adjuster, I will put up the upgrade information later this month.
Here is a picture of all our rear arms equipped with the new adjuster:
I need to poll you guys about using a different finish on our suspension arms. We have been using chrome since the beginning because of its high chip resistance and cosmetic appearance. However chrome being a tough finish, develops micro-cracks and pinholes, which are usually not visible, but can cause small rust bubbles to develop over a long period of time, in certain climates.
I have been looking into different finishing possibilities. I wanted to avoid powdercoating because once chipped, powdercoat tends to come off in chunks. Also it creates problems with threaded parts. The finish I came up with is Cadmium w/ Black Chromate plating, followed by baking to reduce hydrogen embrittlement. Cadmium plating has better corrosion resistance compared to chrome, it will also prevent long term galvanic corrosion of the steel arm if the arm gets exposed to any salt. And because we can get these baked after plating, it will actually make the parts a little stronger (less hydrogen embrittlement). The downside is that it is not as good looking as chrome...
To compare, this is our chromed rear upper arms:
Here is the new "Stealth Black" rear upper arms:
The poll question is: if only the "Stealth Black" finish was available, would that otherwise deter you from buying the product? ie. You would buy the chromed product, but not the "Stealth Black".
It would be too difficult for me to try to stock both finishes, so I have to decide whether to switch everything to "Stealth Black", or keep the chrome.
kuah@splparts.com is offline
Old 05-30-2008, 09:43 AM   #2
tacotacotaco
tacotacotaco's Avatar
tacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfectiontacotacotaco is close to perfection
Send a message via AIM to tacotacotaco
Stealth black!
tacotacotaco is offline
Old 05-30-2008, 09:45 AM   #3
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Edit: Read the thread thoroughly this time and the stealth black is an improvement on an already improved item so that's a big yes to Stealth Black then. Are those arms for both the s13 and s14?
- Jimmy
Wanted:
TBD
For Sale:
TBD
DreamN is offline
Old 05-30-2008, 09:54 AM   #4
[email protected]
Yup all 3 arms fit S13 and S14 chassis. Our toe arms come with 2 sets of bushings (not shown) that allows it to fit both chassis. The traction rod is common to both. The rear upper arm is also designed to fit on both chassis.
Old 05-30-2008, 09:45 AM   #5
ILoveMyRHS13
ILoveMyRHS13's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
I love the stealth black!
ILoveMyRHS13 is offline
Old 05-30-2008, 09:49 AM   #6
cgtdream
cgtdream's Avatar
cgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond reputecgtdream has a reputation beyond repute
The stealth black is lookin good...I would def. buy those over the chromed ones...
Juicy slayin aint easy, but dammit somebody has to do it!!!
cgtdream is offline
Old 05-30-2008, 09:46 AM   #7
sumfknguy
sumfknguy is an unknown quantity at this point
Send a message via AIM to sumfknguy Send a message via Yahoo to sumfknguy
stealth black ftw!
i <3 boobies
sumfknguy is offline
Old 05-30-2008, 09:55 AM   #8
240trainee
240trainee's Avatar
240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection
Send a message via AIM to 240trainee
Stealth black looks good to me.
I need to pick up some shit in the near future from you too.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
240trainee is offline
Old 05-30-2008, 09:55 AM   #9
MrD
MrD is a name known to allMrD is a name known to allMrD is a name known to allMrD is a name known to allMrD is a name known to allMrD is a name known to allMrD is a name known to allMrD is a name known to allMrD is a name known to allMrD is a name known to allMrD is a name known to all
stealth black please!
MrD is offline
Old 05-30-2008, 09:56 AM   #10
IStop4NoMan
IStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant futureIStop4NoMan has a brilliant future
i agree with stealth black.
Its great how you guys are looking to improve your designs. i do notice with the MR arms i have that the rod ends do twist a lot when trying to lock the jam nut. also the rod end does swivel making it hard to get the rod length correct. keep up the good work.
i wish i had gone with real arms to begin with like SPL
IStop4NoMan is offline
Old 05-30-2008, 10:00 AM   #11
DreamN
DreamN's Avatar
Trader Rating: (54)
Kuah, add a poll to the thread so you don't have to be counting each vote lol
- Jimmy
Wanted:
TBD
For Sale:
TBD
DreamN is offline
Old 05-30-2008, 10:02 AM   #12
exitspeed
aWingThing.com
exitspeed's Avatar
I don't think he can now. Kuah, Let me know if you can't and I'll add it for you.
EDIT: Actually I don't see how to do it either.
exitspeed is offline
Old 05-30-2008, 10:01 AM   #13
exitspeed
aWingThing.com
exitspeed's Avatar
Stealthy Black for the win.
Old 05-30-2008, 10:10 AM   #14
gprb25
gprb25's Avatar
gprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of light
Stealth black FTW.
Lookin good SPL...keep it up
gprb25 is offline
Old 05-30-2008, 10:12 AM   #15
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
stealth black ftw!
blueshark123 is offline
Old 05-30-2008, 10:12 AM   #16
ROUGE180
ROUGE180's Avatar
ROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfection
Send a message via AIM to ROUGE180 Send a message via Yahoo to ROUGE180
STEALTH DAWKKKNESSSSS!!
msglngth
ROUGE180 is offline
Old 05-30-2008, 10:15 AM   #17
CAPoweredS14
CAPoweredS14 is just really niceCAPoweredS14 is just really niceCAPoweredS14 is just really niceCAPoweredS14 is just really niceCAPoweredS14 is just really niceCAPoweredS14 is just really niceCAPoweredS14 is just really niceCAPoweredS14 is just really niceCAPoweredS14 is just really nice
msglngth
YES +1 on the Charlie Murphy!!
CAPoweredS14 is offline
Old 05-30-2008, 10:14 AM   #18
CAPoweredS14
I say add the poll I wanna vote on Stealth Black. I only wish SPL tagged their products.
Old 05-30-2008, 10:18 AM   #19
highoctane
highoctane is on a distinguished road
stealth black ftw
highoctane is offline
Old 05-30-2008, 10:23 AM   #20
azndoc
azndoc's Avatar
Trader Rating: (47)
Feedback Score: 47 reviews
I like the bling bling, but the stealth black looks cool.
Like sema flat black is what I call it.
As long as it works, I wouldn't care if it was in pink with white strips.
azndoc is offline
Old 05-30-2008, 10:29 AM   #21
240trainee
240trainee's Avatar
My main concern would be the hex screws that you are using on the collar, I have night mares about those things and how they have a tendency to strip out.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
Old 05-30-2008, 10:35 AM   #22
ellisonrox
ellisonrox's Avatar
ellisonrox has a reputation beyond reputeellisonrox has a reputation beyond reputeellisonrox has a reputation beyond reputeellisonrox has a reputation beyond reputeellisonrox has a reputation beyond reputeellisonrox has a reputation beyond reputeellisonrox has a reputation beyond reputeellisonrox has a reputation beyond reputeellisonrox has a reputation beyond reputeellisonrox has a reputation beyond reputeellisonrox has a reputation beyond repute
when's v3 due to be out?
looks awesome
ellisonrox is offline
Old 05-30-2008, 10:39 AM   #23
Slidin240Wayz
Slidin240Wayz's Avatar
+1.
Make sure you put which size allen key to you.
Stealth black = YES!
Slidin240Wayz is offline
Old 05-30-2008, 10:46 AM   #24
[email protected]
If they strip, just slip off the collar and use a worm gear hose/band clamp while you wait on a new collar from us But not to worry, it doesn't take much torque to lock down the collar, so chances of that happening is slim unless you get overzealous torquing it down.
Old 05-30-2008, 10:57 AM   #25
!Zar!
!Zar!'s Avatar
THIS is why I fucking love SPL parts. You won't find customer service like this anywhere else!
I have had all the chrome arms and didn't really experience any rust bubbles. Maybe because I'm in cali?
I like the Stealth black. And honestly, function over form.
The black looks sick imo. I'm going to need to order a new set because I still haven't upgraded to the v3 stuff.
Now I have even more incentive to. hahah.
Most of the time they strip because people use those crappy, "L" key allen wrenches. And most of the time it's not even the nut that strips, it's the key that wears down. If you buy a real hardened allen set along with using a sufficient amount of blue threadlock, you're fine.
!Zar! is offline
Old 05-30-2008, 11:27 AM   #26
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
Also, dont ever use ball point hex keys.
Kuah,
How about gold chromate(Gold iridite/Zinc DiChromate) finish? It's corrosion properties are pretty good for almost all climates.
parking lot pimpin...
Seller Feedback here:
http://www.zilvia.net/f/showthread.p...ight=pbcstylez
pbcstylez is offline
Old 05-30-2008, 11:38 AM   #27
[email protected]
Zinc DiChromate is basically Zinc plating followed by yellow/gold chromate. Ours is Cadmium plate followed by black chromate. They are fairly similar, the color/type of the chromate conversion doesn't change the corrosion properties IIRC. However, Cadmium is preferred over Zinc for corrosion resistance.
Old 05-30-2008, 02:02 PM   #28
steve shadows
steve shadows's Avatar
Amazing, I could be watching the transformation of this market in front of my eyes
Like Me on FaceBook !
steve shadows is offline
Old 05-30-2008, 10:35 AM   #29
Harbe
Harbe is not welcome here anymoreHarbe is not welcome here anymoreHarbe is not welcome here anymoreHarbe is not welcome here anymoreHarbe is not welcome here anymoreHarbe is not welcome here anymoreHarbe is not welcome here anymoreHarbe is not welcome here anymoreHarbe is not welcome here anymoreHarbe is not welcome here anymoreHarbe is not welcome here anymore
your suspension arms rust with the chrome, when do the stealth black rucas come available to buy my vote for the stealth black
how much for whats seen in the pic black rucas
Harbe is offline
Old 05-30-2008, 10:40 AM   #30
Trion
Trion will become famous soon enoughTrion will become famous soon enoughTrion will become famous soon enoughTrion will become famous soon enoughTrion will become famous soon enough
Impressed by your research, regarding stress/crevice corrosion. This makes me really consider buying a set of arms! Would choose the black, due to it's benefits!
Trion is offline
