Old 08-21-2009, 01:47 AM   #1
josephin510
josephin510's Avatar
josephin510 is an unknown quantity at this point
Parasitic drain
Ok i have an 92 s13 it has a major parasitic drain i cant find were at. I relocated the battery to the back then one night of spirited driving my tool box opened up hit the battery then grounded out the battery. I bought a new batt my car fired right up one time now my fuel pump doesnt prime i checked all the fuses and changed all the relays. I checked my engine harness its good i checked the engine bay/headlight harness it seems to be the interior harness.????? Has anyone had this prob there battery grounding out then there car had a drain. HELP 240sx GURUs YEs STUPID i DiDnT HavE A bATt BoX I WaNteD to DRIVE thAt nIGht BeForE FinIShINg WhAt i StaRtED
Trade my Rb25 for some wheels.
Buy my Sc300.
josephin510 is offline   Reply With Quote
Old 08-21-2009, 01:52 AM   #2
wow-thats-a-cool-car
wow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfection
Send a message via AIM to wow-thats-a-cool-car
your ecu is dead
go buy a new one
wow-thats-a-cool-car is offline   Reply With Quote
Old 08-21-2009, 02:32 AM   #3
stealthsr20
stealthsr20's Avatar
stealthsr20 is an unknown quantity at this point
yup. make sure that your chech engine lights up when you turn the key on and if it doesn't the new ecu for you
stealthsr20 is offline   Reply With Quote
Old 08-21-2009, 12:51 PM   #4
josephin510
Your talking bout the check engine light it does it started this morning when i gave the fuel pump 12v.
Buy my Sc300.
Old 08-21-2009, 04:42 AM   #5
mxexux
mxexux's Avatar
mxexux is an unknown quantity at this point
that's not a parasitic drain...
mxexux is offline   Reply With Quote
Old 08-21-2009, 12:54 PM   #6
josephin510
When the car is started the battery drains. Then car dies.
Buy my Sc300.
Old 08-21-2009, 09:02 AM   #7
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
sounds like an ECU problem to me
but i also seen a bad CAS cause the fuel pump not to prime.. car still cranked over just fine.
Chrischeezer is offline   Reply With Quote
Old 08-21-2009, 03:32 PM   #8
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
Impossible,
your talking about the CPS? camshaft position sensor?
I tossed my CAS in the garbage.
The ECU has nothing to do with a fuel pump relay. There could be a burn in any one of your harnesses, and you would almost have to strip the insulation to find it. Follow the FSM, your fuel pump relay/harness is fried, or your fried your fuel pump. I know you didnt change your fuel pump relay, did you order all new OEM relays from nissan? thats alot of money to throw at your car like that, so im assuming you didnt even check the relay;
Take a 10ga wire, attaching it to the + side of the batt, and the other side to the 12v side of the fuel pump harness, no prime, fuel pump or solders in the fuel pump retaining housing. Primes, your relay is bad or your harness.
Simple as that, ECU is fine
Check the FSM, it will walk you through how to trace where the break is, there is a connector on the alternator, and also a 12v ring connection that you can have go directly to your battery (fused I hope)
Bigsyke is offline   Reply With Quote
Old 08-22-2009, 09:12 PM   #9
josephin510
Found the prob there was melted wires in my interior harness.
Buy my Sc300.
Old 08-21-2009, 04:58 PM   #10
Veracity84
Veracity84 is an unknown quantity at this point
How about the alternator is dead?
What gauge wires you running for the relocation? 18 gauge? lol. Double ott 0/0 would suffice. Give the 12v straight to the pump and so you did,
Check Ignition switch fuse/relay as well as fuel pump 15amp fuse. Pretty much check that fuses/relays in your engine bay. Since the fuel pump doesn't prime on ignition and does on straight 12v, you're looking at the circuit isn't continuous, IE, power, ground, signal, fuse, relays.
Does the car crank over?
Veracity84 is offline   Reply With Quote
