Old 12-14-2006, 01:16 PM   #1
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Luvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of light
Feedback Score: 81 reviews
R33 Lsd
Hello, I'm about to install this lsd in my S13 coupe and was wondering if the fluids for this are the same as my stock open diff? Also is the weights and viscosity the same as well? And is it still 1.5 quarts? Thanks for any help
Luvs2slide is offline   Reply With Quote
Old 12-14-2006, 01:24 PM   #2
CA18_S13
CA18_S13's Avatar
CA18_S13 is a well-known jackass
NO you need diff oil that is for lsd's but i am pretty sure its the same weight and same amount.
CA18_S13 is offline   Reply With Quote
Old 12-14-2006, 01:30 PM   #3
LB.Motoring
LB.Motoring's Avatar
thicker oil and remember to buy the tube of the LSD additive.
Robby Leuer
Old 12-14-2006, 02:00 PM   #4
Slidin240Wayz
Slidin240Wayz's Avatar
LB,
Can you be a little more specific?
Carlos
Old 12-14-2006, 11:37 PM   #5
Itchyfin
Itchyfin is on a distinguished road
Does it get thicker the higher the number goes? Example being from 75W90 to ssay...90w90 or something? Also the addictive; where can that be found and do you have a name?
Itchyfin is offline   Reply With Quote
Old 12-14-2006, 11:42 PM   #6
mistaanime
mistaanime's Avatar
mistaanime is making a name for him/her selfmistaanime is making a name for him/her self
Send a message via AIM to mistaanime
i had Penzoil Syncrmesh on a VLSD..made it whip pretty well...and for R33 lsd..you don't need addictive..but if anything..im thinking they are referring to something you can get at a GM dealer..some kinda frinction addictive..oh well..search it.
-Cherry Red 91 Silfourty-
mistaanime is offline   Reply With Quote
Old 12-15-2006, 12:33 AM   #7
Kahl
Kahl is an unknown quantity at this point
Use normal gearbox oil, you don't need anything fancy for a VLSD the viscous coupler thingee is sealed so effectivlely the rest of it is the same as an open diff, except heaps girlier.
Kahl is offline   Reply With Quote
Old 12-15-2006, 12:38 AM   #8
Anto
Anto's Avatar
Anto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfection
Equa-Torque, Trans-X, and there's one more. You can't use a synthetic oil in a clutch pack diff. KAZZ runs their diff oil (non synthetic) at 80w-90. If you run a synthetic oil (for anything OTHER than a clutch-pack), you don't need the tube of friction modifier (but adding it won't hurt anything).
The first number of the oil designation is the weight when cold, and the second part is the weight when it heats up.
If the R33 diff isn't a clutch pack, there is a company out there that makes some fucking BOMB ASS diff or tranny fluid.
http://specialtyformulations.netfirm...alog/index.php
They're closed for a short Christmas move, but their fluids are created with Group IV & Group V basestocks. I don't think you can even buy a Group V oil in a retail store..
Anto is offline   Reply With Quote
