Old 12-28-2006, 12:14 AM   #1
Delearious02
Delearious02 is an unknown quantity at this point
5 Bolt lsd vr 6bolt lsd
Hey all i have searched and have not found anything that says hey if you have a 5 bolt open diff and a 6 bolt lsd you need this to make it work... I am not sure what lsd i have off what car. it has 6 bolts on the pumkin and 5 bolts on the output shafts. So my question is i have a 90 240sx 5 bolt open diff. What do i have to do to make the new lsd work?
Delearious02 is offline   Reply With Quote
Old 12-28-2006, 02:28 AM   #2
juice.def
juice.def's Avatar
juice.def is on a distinguished road
search a little harder but if you have a pumpkin with six bolts then you would need half shafts with six bolts right... http://www.zilvia.net/f//showthread.php?t=53768
well what do you know theres info in the FAQ thread hmmm.
juice.def is offline   Reply With Quote
Old 12-28-2006, 04:33 AM   #3
DoriftoPnoy
DoriftoPnoy's Avatar
DoriftoPnoy is on a distinguished road
wow i cant use the damn search button.... lucky you guys... but yea as i think it would be common sense to think only a 6 bolt flange would hook up to something with six bolts and same goes for the 5 bolt...
DoriftoPnoy is offline   Reply With Quote
Old 12-28-2006, 10:31 AM   #4
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
thats just crazy talk right there, as no such thing exists
all 240sx diffs are 6bolts
Originally Posted by drift freaq View Post
I suggest you shut the fuck up.
Sir is offline   Reply With Quote
Old 12-28-2006, 11:59 PM   #5
Delearious02
you have not helped me at all... as i said i HAVE searched and i did come along that thread you linked but it does not answer my question...
Old 12-29-2006, 09:10 AM   #6
projectRDM
projectRDM's Avatar
Fuck man, did you really need to start a thread? You have a 5bolt diff, you need 5bolt axles. If you have a 6bolt diff, you need 6bolt axles. There's no other way to look at it unless you're planning on building some custom shit that we don't know about.
As far as which models you can get these axles from, you should already know that if you've searched. There's no reason to take this any further.
As far as the diff itself, a 4bolt cover is standard on S13s, 2bolt cover on all other models. Again, well discussed info that you should know already.
Old 12-29-2006, 11:00 AM   #7
waynehead05
waynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura about
Send a message via AIM to waynehead05
you can't put the triangle in the circle. and you can't put the rectangle in the triangle. it's a simple as that.
Who in their right mind would want to lead this nation of Me-First Right-Now Do Nothings??
waynehead05 is offline   Reply With Quote
Old 12-29-2006, 11:31 AM   #8
!Zar!
!Zar!'s Avatar
The jdm diffs have 5bolt output shafts.
Stop talking out your ass.
