Old 12-28-2006, 04:46 PM   #1
starkos14
starkos14 is an unknown quantity at this point
nico is stumped on this one(sr upgrades)
ok. i bought bigger injectors, z32 maf, and recently installed a t28. oh and a tuned ecu for the injectors and maf and turbo. so i install the injectors, install the maf. plug in the ecu and go to start.... does not turn over. fuel pump works, crank, starter. everything works but the injectors. i took a circuit tester to the injectors and no power to them. went to the ecu and nothing. i thought it was the ecu until i decided to plug in the stock ecu and the same test occured. no power to the injectors. and i tested directly from the ecu, so there is not problem with the wiring. the car was running fine before tune and the t28 installed. maf was wred correctly too. my sr swap guy who is local has no clue what the issue is. any help? its gotta be something that sends a signal back to the ecu to tell it to fire the injectors. otherwise how could i have fried both ecu's and only the injectors dont work.?
starkos14 is offline   Reply With Quote
Old 12-28-2006, 04:53 PM   #2
yokotas13
yokotas13's Avatar
you could have a grounding problem in the injector harness shoprting outt hat part of the ecu, or you could just be doing the troubleshooting wrong. either way im not 100% sure what it could be. Do a continuity check on your injector harness.
yokotas13 is offline   Reply With Quote
Old 12-28-2006, 06:38 PM   #3
starkos14
yeah but i checked directly from the ecu with a good ground inside the car. cant be the injector harness
Old 12-28-2006, 07:12 PM   #4
sliddinsil8o
sliddinsil8o's Avatar
sliddinsil8o will become famous soon enoughsliddinsil8o will become famous soon enoughsliddinsil8o will become famous soon enoughsliddinsil8o will become famous soon enough
Send a message via AIM to sliddinsil8o Send a message via Yahoo to sliddinsil8o
What I think yokotas13 is trying to say is you might have some sort of short or wiring problem around there. If the wire/s are shorted to chassis and you ck continuity from ecu to injector plug you will still get continuity even if there’s a short. You should look at the wiring diagram for the SR and look for wire signal from the ecu to injector and look for all ground and where they are suppose to be. If you ck your wiring using the wiring diagram make sure everything matches up.
****SIGNATURE EXCEEDS FORUM LIMITS....PLEASE READ THE RULES****
sliddinsil8o is offline   Reply With Quote
Old 12-28-2006, 07:31 PM   #5
ladiesman8527
ladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enough
bad CAS maybe?
ladiesman8527 is offline   Reply With Quote
Old 12-28-2006, 07:49 PM   #6
Chandler3115
Chandler3115's Avatar
Chandler3115 is an unknown quantity at this point
Send a message via AIM to Chandler3115 Send a message via Yahoo to Chandler3115
check for power at the injector, if no power exists, its not the ecu,it might be the fuse.... maybe
Chandler3115 is offline   Reply With Quote
Old 12-28-2006, 08:05 PM   #7
yokotas13
yokotas13's Avatar
he should have checked the fuse first
thast out of the equation unless he is an idiot
You need to check for continuity on your injector harnes. make sure you dont haev a short somewhere going throught he firewall, or a tire hitting your harness ertc etc
Old 12-29-2006, 12:33 AM   #8
reactor
reactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nicereactor is just really nice
Few things.
First the ECU provides GROUND to for the injectors, not power. So you need to turn the key on and check for voltage to all the injectors. If there is no voltage to the injectors you need to go to the main harness plug by the battery and check the pin that provides power to the injectors (unplug connectors, turn key on, and check the BODY harness side not the engine side).
Second is you need to check that they are getting a signal. A noid light is optimal. But you can use your multimeter and set it to voltage and put your leads into the injector connector. Crank the engine and you should see the multimeter jump really quickly (if your multimeter responds fast enough) between 12 and 0 volts.
Third there is the possibility that you fried your injector drivers (built into the ECU that provide the ground for the injectors). Make sure you have installed HIGH IMPEDANCE injectors and not LOW! If you don't know just check the resistance of just the injectors and post results on here.
reactor is offline   Reply With Quote
Old 12-29-2006, 08:45 AM   #9
starkos14
by the way guys, is there a fuse for the injectors? of course i looked, but didnt see one. ill have to get some guys out here to help me. it can be difficult learning everything on your own and from forums. thanks for the help, ill keep you guys posted.
Old 12-29-2006, 08:53 AM   #10
Slidin240Wayz
Slidin240Wayz's Avatar
There is a fuse for the fuel pump. Have you checked the FSM?
Carlos
Old 12-29-2006, 09:19 AM   #11
starkos14
fuel pump works, crank angle sensor is fine too. its everything but the injectors. i was just looking at the ecu pinout and saw some pins for injector ground, im thinking if they arent grounded, the ecu wont send out a signal to open the injectors, lets hope this is the case
Old 12-29-2006, 09:20 AM   #12
starkos14
by the way, im starting to enjoy this forum a lot more now. thanks guys!
Old 12-29-2006, 02:54 PM   #13
starkos14
ok, the continuity tests went fine.... ecu was tested on another car. its fine. i think its the injectors
Old 12-29-2006, 04:41 PM   #14
Eddie@Performance
Eddie@Performance's Avatar
Eddie@Performance is making a name for him/her selfEddie@Performance is making a name for him/her self
Send a message via AIM to Eddie@Performance
Does the coilpack fire? Check the PTU unit? Any fuel in the cylinder from attempted starts? You can check the inj by connecting 12volts to the each injector and hear them click.
Eddie@Performance is offline   Reply With Quote
Old 12-29-2006, 06:52 PM   #15
starkos14
coil pack fires
Old 12-29-2006, 06:54 PM   #16
starkos14
i have spark. fuel fills the rail, just the injectors wont open
Old 12-29-2006, 06:56 PM   #17
starkos14
injectors do work by the way.... the voltage coming from the injectors on the ecu is 200 millavolts! so not even 1 volt instead of 12.
Old 12-29-2006, 08:15 PM   #18
Eddie@Performance
Hmm... Does the SR have a fusible link for the injectors like the older Nissans? Ive heard of serveral intances in older Nissan that when this gets corroded it seizes to fire the injectors. Some Nissans have a fusible coming off the battery that is related to the injectors. Might want to check that.
Old 12-31-2006, 10:46 AM   #19
starkos14
egi fuse was defective. didnt look blown, but it was... how aout that. i cant even get a fuse to work right..... case closed. new problem, engine keeps running after i take out the key. turbo timer is uninstalled too
Old 12-31-2006, 11:17 AM   #20
Eddie@Performance
Was it related to anything i have mentioned?
Old 12-31-2006, 11:26 AM   #21
starkos14
i had the car towed to my sr guyy, told him what you said.. but it took him an hour to figure out the fuse was faulty. he checked them too
Old 12-31-2006, 11:27 AM   #22
starkos14
now i just need to figure out how to get my car to turn off, or the engine. the rest of the accessories turn off, just not the engine
Old 12-31-2006, 03:14 PM   #23
Eddie@Performance
Sounds like a solenoid problem...
Old 12-31-2006, 03:24 PM   #24
johngriff
johngriff's Avatar
Sounds like bad un-install of the turbo timer. Its not like a DIST car where it will keep charge and keep firing, once you cut circuit to ecu, thats it, game over.
[email protected]
Old 12-31-2006, 04:08 PM   #25
Eddie@Performance
Does the car turn off when you turn on your lights? (i know sounds funny) but there are numerous people i know that this happens after a alternator or inj install.
Old 12-31-2006, 04:38 PM   #26
The Riot Hero
Banned from the Marketplace
The Riot Hero is on a distinguished road
Send a message via AIM to The Riot Hero Send a message via Yahoo to The Riot Hero
sounds like a stuck realy now. smack it around a bit or replace it.
The Riot Hero is offline   Reply With Quote
Old 12-31-2006, 05:05 PM   #27
starkos14
hmm, well i take out the key and can still drive it around. everything else turns off in the car. im takin it to my sr guy on tues. there is clearly still power to the ecu for some reason
Old 12-31-2006, 05:14 PM   #28
Eddie@Performance
The ecu will always have power, thats how it stores the learning data, fault codes because constant power is being applied.
Old 12-31-2006, 06:47 PM   #29
mRclARK1
mRclARK1's Avatar
mRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfection
I'm betting that your relay is stuck is why it won't turn off... exact same thing was happening to me and that was the problem.
mRclARK1 is offline   Reply With Quote
Old 12-31-2006, 08:38 PM   #30
Eddie@Performance
if it is, its prolly part# 25230-C9980 those seem to go out quite frequently
