Old 01-19-2007, 03:19 PM   #1
khilgers
khilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond repute
adjusting suspension to fit 17x9.5 wheels
I am in the market for a set of wheels for my S14. One question I have though is how much adjustment will I have with my stock suspension?
I was planning on getting a set of 17x9.5 +12 but with only KTS coilovers, how well am I going to be able to adjust my camber and toe to accomidate the wider, low offset wheels.
The specs would be:
17x9.5 +12
235/40/17 tires
Z32 front brakes
KTS coilovers
F/R fenders rolled
khilgers is offline   Reply With Quote
Old 01-19-2007, 06:46 PM   #2
OptionZero
OptionZero's Avatar
stock suspension? good luck in the rear man, i used -3.5 to fit 17x9.5 +17 and i have full rear multilink
you're going to need RUCAs as the minimum
oh, and ride height matters, if you wanna go superlow...time for fender mods
OptionZero is offline   Reply With Quote
Old 01-19-2007, 07:06 PM   #3
khilgers
I know with my KTS coilovers that I can adjust the camber up front, but I was worried about the rear suspension. I'm assuming you can adjust camber a little with stock RUCA's but would it be enough to fit the +12's? As for fender mods I already did a roll on the front and rears, but now it looks like I either need to go the pussy route and go with a higher offest, or order up some RUCA's. Hmmmmm, which way to go......RUCA's.
Old 01-19-2007, 07:44 PM   #4
OptionZero
OptionZero's Avatar
hell fucking no
IIRC stock suspension lets you adjust less than 1 degree
dont get a higher offset, just get your fenders rolled and get some RUCAs
the zilvia way is to buy wheels and then make them fit
Old 01-19-2007, 08:24 PM   #5
Slidin240Wayz
Slidin240Wayz's Avatar
THE TROOF!
Carlos
Slidin240Wayz is offline   Reply With Quote
