#91 | |
#93 |
![]() Join Date: Sep 2005
how long does it take to get these shipped to cali 91764 my order number is 1120, and can i get a hipro stencil sent with mine so i wont have to tell people what kind of intercooler it is they can justread that mug!
#94 | |
#95 | |
#97 | |
![]() Join Date: Jan 2005
Carlos |
#98 | |
#99 |
Do you guys have hot-pipe for an S15 SR20 swap car? If you do I'll just order that with my FMIC kit for my S14, Thanks
Ryan These intercoolers are bar and plate style or fin? j/w Thanks |
#101 |
I was wondering if you guys offer black silicon couplers as an option? Also, on your new kits, does the silicon coupler make a 90 degree bend at the intercooler or is the piping a 90 degree with a straight silicon coupler at both ends of the fmic? I cant tell because your pics on the site show a 90 coupler while people's personal pics show a straight with 90 piping. Thanks!
#102 |
I just called them. Thank you for answering my questions. It looks like Blue is the only option and the new design does use 90 degree couplers at the intercooler. I like what i hear. Looks like i will go with one real soon.
#103 | |
#104 | |
#106 | |
#107 | |
Scott |
#109 |
hey. guys need your opinion..
do u think this kit is too much for a stock SR20?? on say most 12-14psi boost i mean.. later i would prob get a bigger turbo.. but for now stock |
#110 |
![]() Join Date: Oct 2005
Mine is going on a some what stock sr. My mods will be
S14 SR20 (T28 turbo) HDI FMIC Nismo 3" catback ProjectNissan downpipe and testpipe Blitz filter Walbro pump I'm sure your mods for "stock" would be close to that. I've seen people run a Greddy R-SPL on a "stock" sr. It just means it will cool better. Which is good even for stock. Btw...I got mine in and it looks great. Cant wait to get it on. |
#112 | |
#114 | |
#116 | |
#117 |
Mike, my core doesn't fit. I'm guessing I should just drill some holes and do it that way? On my zenki the 2 upper hole (for the headlights) are to high for the core and hit the bottom of the headlights if you try to mount it up that far. If you then try to use the holes next further down its to low and will scrape the road. So I'm guessing I should just drill holes as close up without hitting the headlights?
#118 | |
#119 |
I read the installation instructions and check the fitment a couple times and still came short.
I'm wonderng if the hole just under the headlight tabs (the whole you should use for mounting the core like seen on the installation instructions) if further up on Kouki's then Zenki's? I have a Zenki and my holes are not that far up as are the ones in the pics on the installation instructions. I can take pics if you would like to see what I'm talking about. |
#120 |
Ok I took some pics.
This is the core mounted in the existing holes. As you can see its alot lower than the ones in your installation instructions. The holes in your installation instructions are right under the headlight tabs. ![]() This is how much the intercooler hangs under the bumper with the core mounted in the same holes as above. ![]() This is with it mounted just under the headlight tabs. But it still hangs under the bumper about 1/8-1/2 inch which isn't right to me. Vise gripped. ![]() This is with mounting tabs under the headlight tabs. Here is about the best I can seem to do. Its still closer to the ground than I'd like it to be. Its flush with the bottom of the bumper (might I add with a lip). Vise gripped. ![]() This is the core mounted same place as above pic and showing close up of the tabs and how close it is to the bottom of the headlight. I could go up a little more but then I might run into trouble with the bumper support (actually the black piece the bumper bolts onto) and I dont want the core rubbing the light all the time. ![]() I dont have a problem with drilling holes...just was hoping the fitment was going to be easier and it wasn't so close to the ground. |
