will 18x9.5 +30 or +12 fit s14 fronts ?
im about to order a pair of wheels and dont want to go stagger set up. just want to know if anyone tried fitting a 18x9.5 + 30 or +12 on the front of a s14. i know tire will play a role also and was thinking 235/35-40/18 tires. i'm currently running 18x8.5 +25 w/ 225/40/18 the rims come very close to my coilovers too close infact but still cleared and no rubbage. any input would be great.
i have a feeling the +30 wouldn't clear the coilover but a spacer can fix that just more worried about rubage. thanks, jon
-94 green civic h/b(sold) -90 Blue 240sx f/b (sold) -90 Red Rx7 gxl (sold) -95 gold 240sx (sold) -95 white 240sx le (scrapped) -95 black 240sx le w/sr (parting out) -95 purple 240sx le |
![]() Join Date: Mar 2007
you would need +12 to clear without any other tricks or mods.
an 8.5 +25 is one inch off center, so it has about 5.25 inches of backspace. a 9.5 +30 is more than one inch off center (30mm=1.2inch) and with the wheel being wider you end up with almost 6 inches of backspace, thats 3/4" closer to your coilovers than your current setup.
cardomain.com/id/LS1T56FC = my crazy ls1 v8 rx7 = sold |
well im more concerned about rubbage while turning. looking at my old wheels 9'' wide w/ 235/45/17 they where too close to the fender liner.
i mite go w/ 18x9.5 +30 w/ a 15mm spacer. since +12 in the front and +30 in the rears will look funny due to the difference in concave. the wheels i want are lmgt4's and getting the better sizes are in japan which take too long and and a decent amount of $$. any tire size recommendation? so 18x9.5+30 w/ a 15mm spacer should be good. worst case ill go w/ a 17x9 +22(also size is only avail in jap) i dont like the non concave ones i have right now 18x8.5 +25 thats why i want to push it and put a 9.5 wide set here is a pic of my current set up ![]() thanks for the input guys
#7 | |
![]() Join Date: Apr 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 11 reviews
![]() u can run 9.5 0 w/ camber and it fits fine. Go with the lower offset. just don't forget to relocate ur wiring harness.
Watch speed channel 12/9 @7.30PM for drifting at HIN! ![]() [email protected] IF you bought stuff from me write me a review HERE ||VEXMOTORSPORTS || DMAX-USA || RPS CLUTCH || BAB AUTOBODY|| |
![]() Join Date: May 2005
im running a 9.5 +12, fits perfecto, even before i rolled my fenders if i remember correctly in the front. 225/40/18 tire, ive got decent clearance all around inside and outside
![]() parking lot pimpin... Seller Feedback here: http://www.zilvia.net/f/showthread.p...ight=pbcstylez |
Retired General
First off, get rid of your fender liner. Its useless. Plus, if you plan on going any lower you're going to have to get rid of it anyway. Also, i'd recommend relocating your wiring harness or atleast tucking it up higher.
Anyway, I have these wheels. 9.5 front and 10.5 rear. Run the + 12 if you can get it or just run the +30 with a 15mm spacer and run 225/40. 235/40/18s are too big for the front, but for the rear they're fine. FYI, the 9.5s all concave the same, its only the back pad that changes. |
