Busted Damper Knob
Basically a while back my damper knob broke off and because of school and shit, I never got around to worrying about it.
I was trying to adjust the damper and it felt seized, so I applied just a hair more pressure and the knob with about a half-inch to inch long shaft with the blue knob fell out of the bottom of the coilover. My question is, does anyone know of a way to manually adjust the damper without the knob? There's a small 8mm screw on the bottom of the coilover where the knob and shaft went inside of. That have anything to do with anything? I contacted KTS Overseas a while back, and they couldn't comprehend anything I said. Just called SPL Parts and they had no clue whatsoever. Here's the damper: ![]() ![]() Here's the knob: ![]() ![]() Really, any help, suggestions, who to talk to etc. is really appreciated. Thanks. |
![]() Join Date: Mar 2002
Screw emails, I don't understand why so many of you do that, you will not get a fast response, if any. Way too many emails go to people like kuah. Just call them see if they have replacement parts for the coilovers and get it sent out. If i had to guess they probably don't have them, its not something most people keep.
I know with STANCE you should be able to screw that thing out, and they have a few of those things, but i dont know if its going to be the same pitch.
PROCEED Grip Gambler |
I called a second time before sending the e-mail asking if I could send them over some pictures to see if that could possibly help them diagnose an alternative fix or way of manually adjusting it. They said they'd be glad to try to help but couldn't guarantee anything.
Chmercer, I was actually thinking that the small tiny nut may be a setting screw to hold that knob in place. But because of my lack of balls, I'm afraid to unscrew the nut (without complete reassurance that it is a setting screw) to try to put the knob back in due to fear of my car spontaneously bursting into flames. It's not an absolute demand to be able to have the damper be adjusted. I've been drifting just fine with the current setup, but it would be nice if I could adjust it at least once or twice before this next event to try out different settings and see what works best before I end up buying a set of Stance. |
From the looks of it you can take the knob off, did they come like that? That is how most knobs are, it just tightens to the original knob.
But once you take it off, you still wont be able to put it back in because it snapped. Double check with them on if you can just take a 10 or 8mm watever that nut is on the coilover and see if they have that part laying around. All that broke is the clicker from the looks of it.
