![]() Join Date: Mar 2004
Pilot bearing... do you need it?
I might have made a mistake...
I just rebuilt an S14 KA and attached my '90 S13 manual tranny on it... flywheel, clutch, throwout bearing, etc. all went on but I didn't think about the pilot bearing... I didn't even look... The S14 KA I rebuilt was from an Auto car... my '90 S13 is a manual... I already sold the KA24E so I don't have that to look at... To my understanding the pilot bearing pushes into the center of the crank where the flywheel goes on, right? What does the pilot bearing do? |
![]() Join Date: Dec 2002
Did you remove the auto pilot converter? It's possible to jam the input shaft into it, but you would have damaged something.
The pilot bushing simply keeps the input shaft from riding against the crank and wearing on both items, especially since they change in speed with clutch engagement. You don't have to have it, but you will wear both parts a lot quicker without it.
its better to keep a worn out p bushing as long as its not totalled, than to run none.
ps. its a bitch to get out if your a novice on the job.
Like Me on FaceBook ![]() |
Man w/ CTSV & a Car Seat
I always thought you cant attach the manual flywheel with the auto plate on? Anyways, like said, pull it out and put a pilot bearing in, will save you the hassle in the long run. I imagine the clutch will chatter alot without it.
the way I do it is by packing grease into the center hole where the pilotshaft rides. when you can't pack any more grease into it, insert a 6 inch long wooden dowel, the same size as the pilotshaft, into the hole and whack it with a hammer. the grease will force the bushing/bearing out. then all you have to do is wipe out the grease and install the new one.
also that removal tool helps... |
Guest
Posts: n/a
i remember using a dremel to cut mine out.
then i realized its made of SHIT, and can be cutout by simply hammering it out and deforming it. i mean, the pilot bearing is made of crap, it comes out easy. |
![]() Join Date: Dec 2004
Trader Rating: (58)
For those who don't have a puller: A simple screwdriver and hammer can work in a pinch...peen it over, and then pull it out....it's just copper.
I've also seen (maybe even on this forum) people actually threading (tapping) the bushing, making a homebrew slide hammer, and getting it out that way...
The auto pilot converter is not copper/brass its BEEFY most opt to cut if you can get a hold of it with puller.I just cut it with a dremel and then it collapses eventually its a pain though.
The manual pilot bushing is easy, first time I did it I took a chisel and chipped it away collapsed.(Those rent a pullers actually work and grease trick in manual pilot bushing.) |
![]() Join Date: Mar 2005
The rental pilot bearing puller usually won't fit the hole of the pilot bearing
The one I rented didn't Ended up using a coilover wrench (smaller of the 2), then putting a 3/8 extension in the hole of the wrench and yanking Came out no problem
![]() A SPEC PRODUCTS CORP AME Wheels, Advan, ARC, Gram Lights, Nardi, Personal, Recaro, Works Bell, Work Wheels, Volk Racing, 5Zigen, & more! 626.618.1100 x 103 / aim: aspectuan ![]() ![]() ![]() |
I didn't look to see if it was even in there when I attached the clutch/flywheel...
I'm wondering if that is why my car is engaged half way into gear when I let off the clutch... Time to drop the tranny and find out... damn... |
#13 | |
Guest
Posts: n/a
but, i removed the auto bushing.. still, its made of crap. comes out easy. |
#14 |
The auto one isnt copper thats for damn sure. I remember i use to burn 2 hrs pulling that shiet off auto SRs. I usually drill holes on opposite ends and then collapse the damn thing in with a hammer and chissel. Fucking hated them...
#15 |
i just dremeled mine out.. the puller tool didn't fit in the hole so i just started cutting that sht.. hey came out nice and easy its not like your gona use the same one again anyways lol.
#16 | |
![]() Join Date: Jul 2006
Trader Rating: (53)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 53 reviews
Basiclly the only thing that worked on mine was - I took a flathead screwdriver and chizeled it out! |
#17 |
what also works is spray freeze off onto the the sucker so it contracks, or whatever. gets smaller a little and slude it out with a file. thats what worked for me.
Parking lot pimping ![]() |
#18 | |
Guest
Posts: n/a
but uhm, yeah.. the freeze technique could work good.. make it small like a penis on a cold day, should come out with ease. |
#19 | |
i read it somewhere and it SOUNDED like a good idea... still would like to try it though, my guess is you didn't pakc it good enough?? |
#20 |
![]() Join Date: Jul 2005
yes you NEED it!!!!!!!
i contacted Exedy when i did the exact same move. they told me, to be frank, that it will fuck your clutch up bad. your clutch wouldnt be aligned because the input shaft isnt aligned, and in turn will damage it, your crank, and possibly your transmission. soon after hearing that, i purchased the needle bearing pilot bushing/bearing off a group buy on here, zilvia. less friction which in turn is much better than the copper bushing. do yourself a favor and suck it up. pull that trans and install the bushing. take a 15mm deep well and drive it in. good luck!!! |
#21 |
If you went all out on rebuilding a DOHC s14 motor, why didnt you buy a new clutch for it and change the pilot bearing then? Either way, yes you do need it. When i tried using the auto pilot bearing, my gears would lock up.
If you dont know SEARCH!!! ![]() |
#22 | |
Trader Rating: (53)
My auto bushing was really tight - like before - I had to chizel it out. I did another one w/ piolt bushing puller tool - and after 5 times it finnally came out - but that wont work on the 5 Speed bushing - it just keeps bending the ends and sliding back over it - Chizeling out the 5 speed bushing is the only way that has worked for me - so far. |
#23 | |
15sec on a grinder and you're good to go. |
