Old 06-25-2007, 06:50 AM   #1
kevtrinh
kevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond repute
SR Exhaust Manifold to Turbo Nuts
Stock Exhaust Manifold/Turbo
Exhaust manifold to turbo flange nuts.
The two closest to the firewall apparently got loose and fell out. They even had the tabs to prevent the nuts from falling out. So much help they were... Anyways does anyone know the specs for the nuts? I don't have much room to measure the threads. Any suggestions on keeping it threaded? Will lock-tite just melt from the extreme heat? Will I be able to tig weld it with the little clearance I have from the firewall to the turbo? Thanks.
kevtrinh is offline   Reply With Quote
Old 06-25-2007, 07:08 AM   #2
Slidin240Wayz
Slidin240Wayz's Avatar
I don't know the thread off the top of my head, but you should be able to at least MIG the nuts in place...just a spot, nothing crazy.
Carlos
Slidin240Wayz is offline   Reply With Quote
Old 06-25-2007, 07:15 AM   #3
kevtrinh
Thanks dude, see you at the next event
Old 06-25-2007, 07:17 AM   #4
ctm_motortrends
ctm_motortrends's Avatar
ctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfectionctm_motortrends is close to perfection
Phase 2 Motortrend sell them new good price they also sell the locking plates.
ctm_motortrends is offline   Reply With Quote
Old 06-25-2007, 07:26 AM   #5
TheWolf
TheWolf's Avatar
TheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant future
Stainless lock nuts have always worked for me. Even with a dab of antisieze
Eye on the Prize
TheWolf is offline   Reply With Quote
Old 06-25-2007, 01:18 PM   #6
opponheimer
opponheimer's Avatar
opponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond repute
Use stock locking tabs, new ones, they work fine
SR20 & RB20/25/26 in s13/s14 Wiring from $125 to $200.. Best prices EVER.
opponheimer is offline   Reply With Quote
Old 06-25-2007, 03:39 PM   #7
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
m8x1.25 i believe.. Same as 5 bolt outlet studs right?
-Bart
DJ_Sunrise is offline   Reply With Quote
Old 06-25-2007, 08:46 PM   #8
kevtrinh
I have confirmed that they are 8x1.25 Thanks for all the info!
Old 06-25-2007, 08:47 PM   #9
johngriff
johngriff's Avatar
do you have a downpipe to trans mount?
Weld a bracket between the two. No more problems.
[email protected]
Old 06-25-2007, 09:10 PM   #10
WilloW
WilloW's Avatar
WilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfectionWilloW is close to perfection
Send a message via AIM to WilloW Send a message via Yahoo to WilloW
I was recommended these not to long ago http://www.stage8.com/auto.htm
WilloW is offline   Reply With Quote
Old 06-26-2007, 01:39 AM   #11
drifter808
drifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of light
i had to replace those 4 times. i finally just tackwelded the nuts on.
drifter808 is offline   Reply With Quote
