Old 03-10-2007, 07:50 PM   #1
jafero
jafero is on the path to ruinjafero is on the path to ruin
TPS reading wierd ohm values.
I checked throttle position sensor.
According to FSM, TPS should have 2K ohms when gas pedal is released and 10k ohms when gas pedal was pressed completely.
When I tested, it was the other way around. When gas pedal was release TPS had 9.45k ohms and when gas pedal was pressed TPS had 1.16k ohms.
Why is this happening? Could this be due to incorrect install of the TPS?
Since the guy who sold me the engine installed the TPS, I have no way of knowing if TPS is installed upside down or not.
jafero is offline   Reply With Quote
Old 03-11-2007, 07:37 PM   #2
jafero
No one knows?
Old 08-06-2007, 08:14 AM   #3
Dream240
Dream240's Avatar
Dream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond repute
Reviving an old thread.
I'm having this same problem. Here's the wierd part, when I measure the ohms from pins 1 & 2, I get the backwards readings. But when I measure ohms from pins 2 & 3, I get the proper readings.
I'm thinking this aftermarket TPS that I bought has been miswired. Like the wires are in the wrong locations. Mind you I'm measuring these readings with the connector facing me -> 1 2 3 .
So anyone know if I'm on the right track? Do I need another TPS with good wiring?
Don't mess with my monkey...he's loaded.
Dream240 is offline   Reply With Quote
Old 08-06-2007, 09:28 AM   #4
drftmark
drftmark's Avatar
drftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura aboutdrftmark has a spectacular aura about
same problem, someone must have an answer...
drftmark is offline   Reply With Quote
Old 08-06-2007, 09:57 AM   #5
Slidin240Wayz
Slidin240Wayz's Avatar
Can you check it directly off the tps on the throttle body?
Slidin240Wayz is offline   Reply With Quote
Old 08-06-2007, 10:15 AM   #6
Dream240
Dream240's Avatar
you mean check the resistance at the TPS, where the wires come out of the TPS? Why should that matter?
I'm confused.
I'm starting to think it's that the TPS is miswired. But that would just be the beginning of my woes. I'm also thinking I've got a bad injector.
I think too much...
Old 08-06-2007, 06:37 PM   #7
Kaneda774
Kaneda774 is an unknown quantity at this point
Don't know if this helps but in working with Megasquirt, a DIY fuel injection computer, the TPS was wired as such
Pin 1 - 5 v ref
Pin 2 - Signal
Pin 3 - Ground
Should be pretty easy to isolate the problem, if you check for continuity between ground and one of the outer wires, the one with continuity is your ground, the other is Ref and the middle should always be signal. Take your reading with ground going to common on your multi-meter and signal going into the other lead. If it's still screwed up time for another TPS,
Check your wiring its probably just mixed up.
Kaneda774 is offline   Reply With Quote
