Old 10-03-2007, 10:35 AM   #1
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
is '89 s13 wiring harness the same as '92
i'm just wondering if its that same as a 92 or will i have to modify it.
i'm buying a new s13 and its a 89 will my 92 harness (SR modified) will be the same so it could be a quick swap.
i'm talking about the engine harness
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 10-03-2007, 10:49 AM   #2
Rayne
Rayne's Avatar
Rayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfectionRayne is close to perfection
Are you talking about the interior harness or the Engine harness?
Rayne is offline   Reply With Quote
Old 10-03-2007, 10:53 AM   #3
s13silvia123
my bad the engine harness
Old 10-03-2007, 11:40 AM   #4
mrmephistopheles
mrmephistopheles's Avatar
. no .
Originally Posted by PHLIP
Old 10-03-2007, 11:45 AM   #5
DJButton
DJButton's Avatar
DJButton is close to perfectionDJButton is close to perfectionDJButton is close to perfectionDJButton is close to perfectionDJButton is close to perfectionDJButton is close to perfectionDJButton is close to perfectionDJButton is close to perfectionDJButton is close to perfectionDJButton is close to perfectionDJButton is close to perfection
Send a message via AIM to DJButton
Originally Posted by mrmephistopheles View Post
. no .
Yeah, that pretty much sums it up. 89 SOHC harness stock and 92 DOHC harness = not the same.
DJButton is offline   Reply With Quote
Old 10-03-2007, 11:52 AM   #6
s13silvia123
what would i have to do to make the 92 to fit or should just redo the harness again for my SR
Old 10-03-2007, 12:02 PM   #7
Rayne
Rayne's Avatar
Your best bet is to redo the harness for the SR.
Old 10-03-2007, 12:04 PM   #8
s13silvia123
thanks guys for the help
Old 10-03-2007, 12:17 PM   #9
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
Let me get this right - you had your SR in an 89 chassis and now want to put it in a 92 chassis and are wondering if the SR harness will match up. From memory it should be nearly identical.
Old 10-03-2007, 01:44 PM   #10
projectRDM
projectRDM's Avatar
Only the dash plug is different. Any harness modified for an S13 chassis will plug in everywhere except the dash, which is just a few wires to repin anyway.
FORMERLY R240NA
Old 10-03-2007, 02:36 PM   #11
s13silvia123
what i meant is that i have a '92 and wondering 92 would fit to the 89 without any problems. but as what you guys as telling me. i might as well redo the 89 harness so that i can transfer the SR moded 92 to the 89
Old 10-04-2007, 07:05 AM   #12
Rayne
Rayne's Avatar
If you are willing to repin the F1 to M53 plug in the 89 harness to work in the 92 plugs....there is not much modification you need to do.
I said your best bet was to redo the harness because you end up knowing the condition of the wiring and its circuits prior to installing it.
