Project S14a rebuild – a comprehensive and detailed guide
I bought this car from a friend of mine 5 years ago and thought it would be a good idea to restore it. I have posted loads of info in the thread. If anyone has any suggestions, comment or questions, please feel free to fire away.
Thread is here http://www.sxoc.com/vbb/showthread.php?t=283826 I also made this vid of the car before I stripped it – right click save target as - 25MB http://media.sxoc.com/contributors/p.../2005_edit.mpg All comments and questions welcome ![]() |
![]() Join Date: Dec 2002
I'm only halfway into the read, but you're doing an AMAZING job with it, keep it up. +1 for you.
![]() Join Date: Nov 2006
![]() ![]() ![]() ![]() Feedback Score: 2 reviews
wow your crazy... but in no way is that a bad thing
nothing like restoring a mid 90's car lol, i'm supprised at how many things didnt break when you took them off |
wow +1 for sure. I know your pain. I am helping my dad restore a 61 corvette. Fiberglass body but 40 year old rust. The diff took hours to clean, as did the solid axle. But its well worth it, that gel you are using looks amazing i will be ordering that soon! Thanks! you rock and im only 1/4 of the way thru!
#9 | |
![]() Join Date: Jul 2005
Damn I wish I had the patience you have. Looks good.
#12 | ||
Thanks for the comments guys.
I would love to restore something really old like a badass corvette, like I said though I don’t have the facilities. I did quite a big write up on rust removal / prevention. I will dig it out for you. Thanks, I work in television so I have the use of some decent video kit. |
#13 | |
![]() First of all I have no experience with rust "killing" primers or paint on rust products. There are loads available – POR-15, Finnagans No.1 and Hammerite smooth are some that spring to mind. I also have very little experience with rust converters, these products are applied to rust and "stabilise" it ready for primer, Kurust is an example. The reason I have not tended to use these products is that you are relying on the product to stop the rust, if it doesn’t do the job due to it being a poor product or poor preparation / application then it’s all been a waste of time. When metal rusts, it goes porous and forms layers. One of my biggest concerns with these types of products is getting the product to penetrate to the very bottom of any pitting. If the product is quite thick then it will just form a skin on top. Oxygen is required for corrosion to occur so if a paint film is applied over the top, it will continue to corrode as oxygen will still be present. Another preparation concern is oil or grease, if there’s any of this evident then the product will not do its job. I have always gone for mechanical or chemical removal for these reasons. Shotblasting is the best way to remove rust, it’s quick but the only drawback is the blast media gets everywhere. Done right it will remove all rust and leave a very slightly pitted finish offering a good key for primer. Wire brushes also work well but what you must remember it can be difficult to get all the rust out of the pitting, softer brushes with thin bristles can be useful for this. Twisted knotted wire brushes used in angle grinders are to stiff. One drawback with wire brushes it that the brush gets contaminated with microscopic rust particles so you are spreading these particles over the area as you are working. I have only tried 1 brand of chemical rust remover – Deox from Bilt Hamber. They have 2 products, Deox C which makes up a solution for parts to be dipped and Deox Gel. The Gel can be used to spot treat areas underneath the shell or areas impossible to get to with a wire brush. It does however take time. Once applied it needs covering with cling film to prevent it drying out and ideally needs leaving 48 hours. It’s then got to be scrubbed with Scotchbright before being washed off and dried as quickly as possible. I have had to re apply it up to 3 times in certain circumstances. It does work though. What do I apply under the arches/floorpan? The best rule of thumb is to replicate manufacturer’s methods – Stonechip under the arches and wax in box sections. Bare shells are dipped in electrocoat at the factory, this is obviously not an option for DIY but the next best thing I have found to apply to bare metal is a zinc rich primer. Unlike conventional primers which are porous, a zinc primer will protect the steel from corrosion. This can be applied by brush or spray. For maximum protection 2 coats of 2K epoxy paint should be applied over the primer which again can be applied by brush or spray. Please be aware however that 2K products are hazardous and it’s essential to use a mask. As an alternative, a chassis black 1K product could be used. Stonechip should then be sprayed on top. I don’t recommend brushing it on but aerosols are available from your local bodyshop supplier. I don’t recommend spraying wax products over the top of stonechip, it will soften the stonechip reducing its effectiveness. Dirt and salt will also stick to it. My thoughts on Waxoyl Inside the sills is factory coated with a rustproofing wax. It’s a very thin coat and has a smooth finish. Any water that enters the cavity will naturally run down and out of the drain holes. The problem with applying Waxoyl is achieving this perfect finish inside the box section. What you typically end up with is a very rippled finish. I believe that this causes water to puddle in the Waxoyl. The problem being that this water evaporates and since there is very little or no ventilation inside the sills it has no where to go other than condense inside. I have also found that spraying Waxoyl on rust does not "kill" it, it just corrodes behind the Waxoyl. Hope this info is useful |
#17 | |
#20 |
Awesome thread, I read it last night when you posted the link in the pics thread..
Amazing attention to detail, I would like to know if you know of any other similiar rust removal gel's that would be more readily available in the US, because I tried to visit the Deox site and it wasnt functioning.. And Im not sure if it is available in the US... Also, I want your factory diff cooler.. haha, that thing is baller. I was reading and apparently not alot of the UK guys like/want them for some reason... you should tell one of them to hook it up ![]() |
#24 |
![]() I found an easy way to save the entire thread. First go to this link to view the thread in printable version (10 pages). Then save each page 1 by 1. I did it and it only took about 15 mins. I wouldn't mind e-mailing the results to you guys but the file size is 153mb in zipped format. |
#26 | |||
http://www.bilthamber.com/index.html I have contacted them and sent this link, should have some more info soon and I will post up. Quote:
No problem, I reckon it would take half the time with a ramp (lift) It’s now cold in the UK and nothing is drying. Quote:
Thanks for the kind words. The thread is usually updated daily but if there are any significant updates, I will post it up. |
#30 | |
![]() Join Date: Mar 2002
I think Naval Jelly is the closest thing the US has to Deox Gel.
