![]() Join Date: Apr 2007
whats an acceptable AFR for WOT on sr20det 8.5:1 CR on 93oct?
I've seen 11.5 - 11.7
My car's at 11.2 and at top end goes to 12.0, I'm going to lower the boost and try to error solve, a 12.0:1 afr at wot is bad correct?
SR20 & RB20/25/26 in s13/s14 Wiring from $125 to $200.. Best prices EVER. |
http://www.zilvia.net/f/showthread.php?t=134996
thanks man.. So does this mean in actuality my afr is safe under boost? gt2871r at 15psi. posi rep u btw
![]() Join Date: Sep 2005
your A/F ratio is ok. as least for your setup. Its a bit rich 11.5-11.7 is generally the spoot to tune for. Being a tad rich can be a good thing, adds a bit of saftey. I would be more do you have any timing control? and what for tuning?
You need to check that link out... 12 is a bit lean, not a bit rich.
A friend of mine who (inherently) tunes hondas says 12.0 is bad, but he deals with higher comp. motors turbocharged. I'd like to get some descent feedback from some more knowledgeable members on here. Thanks....... this is my DD Btw
![]() Join Date: Oct 2006
For a turbocharged car you want to be in the lower 11. area under wide open throttle. It provides for rich best torque! and the excess fuel also acts like a cooling method in the combustion chamber getting rid of hot spots on the pistons preventing pre-ignition or detonation. As for you having a lean condition in your upper rpm area try knocking back a few degrees of ignition timimng or did you ever wire your fuel pump to its own relay? If not it drops voltage causing that type of problem in the upper rpms! good luck
-mike- |
If your timing is not really really agressive you could be by at 12.0 AFR. Its not the safest.
I asked what was being used for tuning and other stuff, cause either it needs to be tuned richer up top(to be safer) or his fuel system is starting to run out of fuel up top. The cars I have street tuned have beed to 11.5-11.6 but they have been KA-Ts with decent size turbos running 20psi, differant then a SR yes, but same concept. and for low throttle 14.5.
![]() Join Date: Nov 2005
Listen to Bardabe and his thread. It's a good one.
Okay well, i was actually running 12.9 Air:Fuel and i just independently wired my fuel pump to its own fusible link and no difference. I'm on gt2871r 0.64 at 10lbs.. I'm surprised it would still do that at such low boost.
#14 |
I'd be afraid to run a 12.9 AFR in boost....
#15 |
ummm....tune that thing. You might be able to get away with that under medium loads, but WOT? I'd find a way to change that real fast.
Oh, and you should probably get a Walbro or something. EDIT: I was talking about 12.9 AFR
#16 |
who told you that
satan? 12.0 can be safe, anything leaner than that and I cringe. 11.8:1 is good for any gas. 11.5:1 is safe and good compromise tune depending on changes in gas quality over gradient. My car is tuned at about 11.5:1 to 12.0:1 on 91 octane. 12.0:1 rocking. Luke is also at 11.8-12.0:1 even though both the dyno plots we did were made at 11.2:1 (so theoretically were about 20hp more on the street at higher afrs (leaner)). the only thing different is oil squirters under the pistons.
Like Me on FaceBook ![]() |
#18 |
I think more important than the number is "where" you're measuring the AFR.
1. If your coming out the tailpipe using a sniffer (NOT RECOMMENDED) you're good at 12.0. This method of course is not recommended because of inherent inaccuracies but, some of us do it anyway. 2. If your measuring it, like you should, about 16" from the turbine using a wide-band then 11.5 is good. Like someone else mentioned, 12:0 is ideal. At WOT if you're at 12.5 you're heading for trouble. At that compression ratio 11.5-12 measured at the the second position should be perfect. Both SR20DETs and KA24DEs have piston oil squirter's.
Sick Swapp-eR |
#19 | |
but yeah de has them, it also has a dual timing chain which fails not a fan of KA
#20 | |
I'm 50/50 split between SR and KA but, AFRs are AFRs and some motors prefer it leaner and some rich. Abviously, it's not a good idea comparing the ka to an sr where AFRs are concerned. To add to the original question of the post, it would help on a KA to keep things a tad richer and top it off at 11.5 measured right after the turbine as I mentioned before.
Sick Swapp-eR |
#21 |
haha no every motor is theoretically different even sr vs. another sr. It usually has more to do with exact differences in set ups rather than engine design from factory to next engine design from x facotry. the notion that there is a wide margin of difference in teh AFR a engine likes to make power at is retarded. in fact AFR doesnt matter worth a shit once yoru between 11-12. Timing does.
#22 | |
I'm considering stock SR-DET to stock KA with turbo kit. Obviously different setups will determine what AFRs an engine will perform best/ more reliable at, NA, Turbo, NOS NA, NOS Turbo, gas type (octane, chemical composition like methanol, ethanol, diesel etc), internal components etc. But the idea of the original question was to get a "general" idea of what is best. The original poster's question was very general, sr20det 8.5 CR 93 oct, what is considered a good afr. Please don't take me the wrong way. But you obviously need to redeem yourself for the error you made before. On this humble note I would bow and give you the upper hand as you know more than me and I'm a complete idiot. Sorry for wasting your time.
Sick Swapp-eR Last edited by 50/50; 11-19-2007 at 04:28 PM.. |
#23 |
I'm measuring afrs at 36" from the turbine blade... Dropped boost down a little more and it goes to 12.6 afr.. its odd becasue up until 7k rpms its like 10.5-11.2 (stock ecu) then it jumps to 12.6 in the last 500rpm range.. very weird.
#24 | |
your a smart guy. lol dont be so down on yourself. compression ratio has more to do with timing not octane or richer/leaner. I mean NA high comp motor likes 13:1 with a good octane/ TUrbo likes 12:1 or just south of that etc. anyways this is all redundent , every car is diff, you need a dyno or exaust temp and 02 combo on the street to get the afr spot on and timing to make the power bla bla bla
