#1 | |
![]() Join Date: Aug 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
The AFR and Injector size Thread
Alright seems that alot of people have that "what AFR is Ideal" question in mind and search but don't search hard enough or are just too damn lazy. no worries I have taken time out of my so called :valuable life" to write my fellow zilvians the AFR sessentials, Injector size calculator, and come common injector sizes from other cars here we go
Air/Fuel Mixture 6.0 Rich Burn limit (fully warm engine) 9.0 Black Smoke Low Power 11.5 Aproximate rich best torque at WOT 12.2 SAfest best power at WOT 13.3 Aproximate Lean best torque 14.6 Stoichiometric AFR (chemically Ideal) 15.5 Lean Cruise 16.5 Usual Best Economy 18.0 Carburated Burn Limit 22+ EFI Burn Limit if you are further confused and don't know what to pick here are the answers 11.3 at WOT and full boost 14.6 at idle 12.2 cruise / low thorttle __________________________________________________ _______________ Injector Size Calculator Flow Rate = (HP x BSFCX10.5)/ (#injectors x Max Cylce) Flow rate = CC HP = at the flywheel BSFC = Brake specific fuel consumption (0.55 for turbo 0.45 for N/A) Example: 2.0 Litre SR20DET Flow= (500HP x 0.55X10.5) / (4 cylinder x 0.8) Flow = 902cc injectors required __________________________________________________ _______________ these are some INjectors Sizes I have found: Nissan RB26(DETT) 440cc, 550cc Nissan RB25(DET), SR20(DET), VH45 370cc ,VG30(DETT) 370cc Toyota 7MGE(T) 3SGE(T) (Light green) 315cc. (top feed) Toyota 7MGE(yellow), 22RTE(pink), 3SGE(Green): 295cc (Top Feed) 2ZZ 370cc Nissan VG30(DE), KA24(DE), SR20(DE), RB20(DET) 270cc (RB is top feed) Mitsubishi 2G DSM 450cc top feed. Quote:
I will add more as more information is aquired. enjoy! |
#2 | |
typing for extra length... |
#10 |
Lambda is just another expression for a/f mixture. It's based off the stoichiometric air/fuel ratio.
http://en.wikipedia.org/wiki/Oxygen_sensor http://en.wikipedia.org/wiki/Air-fuel_ratio http://www.hondata.com/techlambda.html Just some links to help this thread.
#11 | |
![]() Join Date: Sep 2007
Let's insert a scenario. Hypothetically, I want 350whp from my manual transmission RB20DET-powered 240sx. What size injectors will I need? Since our calculation doesn't account for drive train loss, we're going to need to see how much of this horsepower will be at the crank. Statistics say there is a 15-17% loss for manual trannys vs a 20-25% loss for automatics. This is not set in stone, of course. You can manipulate these numbers accordingly. We can look at this like our crank horsepower is really 15-17% LESS than what our actual horsepower is at the crank (BHP - WHP x (0.15 or 0.17)). ![]() ![]() Equation #2: Calculating BHP Manuals BHP = WHP / (0.83 to 0.85) Automatics BHP = WHP / (0.75 to 0.80) Continuing our Scenario: Let's plug in our numbers to calculate what our BHP would be if we had 350 at the wheel. BHP = 350whp / (0.83) BHP = 422bhp See? We need to be seeing 422hp at the crank in able to have 350hp at the wheel. Now we need to plug our BHP into our first equation to see how big of injectors we'll really need to get. [ 422bhp x 0.55 BSFC ] / [ 6 Injectors x 0.85 Duty Cycle ] = 45.51 lbs/min (45.51 lbs/min) x 10.50 = 477.85cc/min |
#12 |
![]() Join Date: Jan 2004
I can contribute this (not mine, lifted from NICO)
Top Feed Engine Style Size Impedance* Years / Models Nissan KA24E Top feed 260cc High S13 Nissan CA18DET Top feed 370cc Low S13 Nissan RB20DET Top feed 270cc High R32 Nissan RB26DETT Top feed 440cc Low R32/R33/R34 Mazda FC NA Top feed 460cc Low 86-87 Mazda FC NA Top feed 460cc High 88 Mazda FC NA Top feed 460cc High 89-91 Mazda FC turbo Top feed 550cc Low 86-87 Mazda FC turbo Top feed 550cc High 88 Mazda FC turbo Top feed 550cc High 89-91 Mazda FC NA Top feed 680cc Low 84-85 DSM 3000GT/Stealth turbo Top feed 360cc Low 91+ DSM Talon/Eclipse nonturbo Top feed 390cc Low 89-94 DSM Talon/Eclipse 1G Top feed 450cc Low 89-94 DSM Talon/Eclipse 2G Top feed 450cc Low 95-99 Mitsubishi Evo Top feed 510cc Low Evo 1-Evo 3 Mitsubishi Evo Top feed 560cc Low Evo 4+ Subaru WRX Top feed 420cc 02+ Subaru JDM STi Top feed 525cc 99+?? Toyota 3S-GE Top feed 295cc High Toyota 7M-GE Top feed 295cc High Cressida, Supra mk3 NA Toyota 2JZ-GE Top feed 315cc High Supra mk4 NA, SC/GS/IS300 Toyota 3S-GE Top feed 315cc High Toyota 7M-GE Top feed 315cc High Cressida, Supra mk3 NA Side Feed Engine Style Size Impedance* Years / Models Nissan KA24DE Side feed 270cc High S13/S14 Nissan SR20DET Side feed 370cc High S13/S14 Nissan SR20DET Side feed 480cc High S15 Nissan RB25DET Side feed 370cc High R33/R34 Nissan VG30DETT Side feed 370cc High Z32 Infiniti VH45DE Side feed 370cc High All Years NOTE: 90 - 94 Z32 uses a style of injector that is non-compatable with KA fuel rails (still sidefeed), while 95 - 96 uses the same injector as the RB25DET and SR20DET, etc. Mazda FD Side feed 550cc High 93-98 Mazda FD Side feed 850cc High 93-98 Mazda 20B Side feed 550cc High JDM Mazda Cosmo? Subaru JDM STi Side feed 550cc (565cc?) High pre 99 Subaru STi Side feed 565cc High 03+ Toyota 7M-GTE Side feed 430cc (440cc?) Low Supra mk3 turbo Toyota 2JZ-GTE Side feed 550cc Low Supra mk4 turbo Toyota 3S-GTE Side feed 430cc (440cc?) Low MR2, 91+ Toyota 4A-GZE Side feed? 365cc Low MR2, MK1 Toyota Celica GTS Side feed? 310cc High 2000+ Toyota JDM 1JZ-GTE Side feed 430cc Low Chaser, Supra mk3? Toyota JDM 2JZ-GTE Side feed 430cc High?* Supra mk4 turbo Toyota JDM 7M-GTE Side feed 430cc Low Supra mk3 turbo Ford Turbo Coupe ?? 30lb (~315cc) Low 86-89 Ford Turbo Coupe ?? 35lb (~365cc) Low ?? Honda Prelude (H22A) ?? 345cc Low 92-96 VTEC *Impedence Saturated = High Impedence Peak and Hold = Low Impedence
#13 |
The rceng website has an excellent calculator. Just scroll down to the end and plug in your information:
your estimated bhp # of injectors bfsc fuel pressure duty cycle and presto....the recommended injector size you need. Check it out: http://www.rceng.com/technical.aspx?...X17A7N0t2ePHOI
Sick Swapp-eR |
#14 |
![]() Join Date: Dec 2007
![]() Are the Mazda 93-98 FD3S Twin Turbo sidefeed injectors a drop in fit into the KA24DE and SR20DET OEM fuel rail?
For Sale threads: http://zilvia.net/f/sale-items/33286...tons-pics.html Review Thread: ![]() TRADER RATING: http://zilvia.net/f/traderratings.html?u=66301 |
#15 |
