![]() I just finished wiring up my button, and it doesn't work. It will crank the engine over and when it seems like it's started and i let go of the button it's seems to stall or something. When I use the key it starts normally, anyone have any ideas?
Mine is set up kind of like this: ![]() The only difference is that have the 12v power at both sides of the ignited switch coming from pin 30 on the relay. And of course the wire colors aren't right. |
![]() Join Date: Apr 2004
The ignition switch harness has 5 pins: 12V(+), Accessories, Ignition, and two (2), repeat, 2 starter pins.
1 starter pin goes to the starter while another goes to the ECU. I think you're missing the other wire to the ECU. That's why it's cranking but not starting. That wiring diagram is not correct for Nissan. If you're nice to me I can do a correct schematic for you. But first, you have to answer my questions: 1) What is the brand of the start switch? 2) How many pins does it have? 3) What does each pin do? 4) What is the maximum current (measured in Amps) can each pin handle? 5) What happens when the start button is pressed? Which pins are connected? If you don't know the answer, contact the vendor and maybe they can contact the manufacturer. If you can't get the answer, sell the switch and get another one from a reputable manufacturer. This is very basic information to wire up electronics and any manufacturer not willing to supply you with this info is shady. Last edited by g6civcx; 11-28-2007 at 09:26 PM.. |
I have the same switch as the picture, the relay is a 30 amp but also has the same pins.
1)The brand is Ignited and I had to buy the relay my self 2)The relay has 5 pins the switch itself has 4 3)My pins have the same numbers as the ones in the picture. Pin 87 and 87a Power whatever it is your wiring (i have 87 on my black with white stripe starter wire) Pin 86 goes to the switching means (I have it on my ignited switch) Pin 85 is ground (going straight to the body via a bold around the shifter) Pin 30 goes to fused power from battery (Not sure what that really means, but I have it going to black and yellow from my ignition switch which is powered only when the key is on) Now for the ignited unit (same numbers as the picture): 1 and 4 Supposed to get 12 volts when the ignition is on (I have them getting power from the same place as pin 30 on the relay could that be the problemÉ) 3 supposed to go to starter their crappy instructions say to use a relay but don`t use one in the diagram (mine is going to pin 86 on the relay) 2 ground (Mine goes to the black wire from my cigarette lighter) 4)The relay is 30 amps (recommended by ignited on their $&?t instructions) 5)When the button is pressed the starter works the engine tries to crank and when it sounds like it`s started and you release the button the engine dies. I noticed today when i try the button 3 times like 2 second wait between tries the engine will start but just barely. as for the schematic of the relay i`ll have to get you the schematic tomorrow, because the relay is in the car. Thank you for your help and any info you can give me. -Jon |
![]() Join Date: Sep 2006
are you leaving the key in when its being push button started? I think its either one of the wires is not getting power when your push button starting it(ACC wire more then likely) try this...turn the key to the ON(one click before START) and then push the button. DO you want to push button start it without the key in at all times? is there an immobilizer chip in the key?
![]() Join Date: Apr 2006
i had hte same exact problem with a homeade switch setup
Id push it for about 4 seconds release then go again and it woudl start but when i took it o ut, started up just fine
2015 Subaru Outback Overlander - Wagonofdoom |
Starter Black/White Ignition Switch Harness Ignition Black/Red Ignition Switch Harness Ignition 2 Black/Yellow (cold start Wire) Accessory Blue Ignition Switch Harness
all of those need power while starting i think |
The key is in the on position when i push the button. Acc is not supposed to be powered when you start the car, it goes off when the key is in the start position. I can still start it with the key. There is no immobilizer chip, i drive a 1990 240 sx.
![]() Join Date: Nov 2007
just so yuo know the wire colors do change at the ignition harness so dont fallow what people say make sure you test the wires. use a dvom, u dont have an airbag so you could use a test light.
check to see which one has 12v when the key is fully turned you will have two starter wires and you will have to send 12 volts to both of them |
#11 | |
Don't worry about the relay for now. It' just a standard 12V 5pin relay. Let's talk about the starter switch.
Can you answer this question for me? Quote:
Basically, how many amps can your starter switch handle? Because potentially this switch can see as much as 30A if you wire it to the ignition switch (the ignition switch has a 30A fusible link). The problem is if your starter switch is rated for less than 30A, you may have already fried it if you don't have a fuse in front of it. Can you find out the answer to this? If you know for sure it can take 30A max then I'll be more confident that the rest will work. |
This is correct. The Blue accessories wire gets no current when the key is turned to ST. This is to reduce current draw and to help send all the cranking power to the starter.
#13 | |
Well browsing their site I find a different set of instructions then the ones that came with my button, are all generic 5pin relays the same (as in which pins are which?), because the way they say to wire out the pins of the relay is not the same as what i did. The way i wired the relay is according to the instructions from the relay manufacturer,should i try the way on the ignited site? http://www.ignitedperformance.com/pushbutton.pdf They have pin 85(supposed to be ground) and pin 30(supposed to be fused power from battery) flip flopped. They also have pin 86(supposed to go to the switching means) and pin 87( supposed to go to whatever your powering starter in my case) flip flopped. I did notice that the wire i have giving power to the switch is not 12 gauge it's inferior could this be my problem? |
#14 | |
12V relays are pretty standard. 85-86 are control signal and ground. Doesn't matter which is which. 30 is current. 87 is load. Their instructions are completely wrong! This is the correct way. -4 to 12 volt source -3 to 85 or 86, the other one of 85 or 86 to ground 30 to 12 volt source 87 to starter wire It looks like 1 and 2 are for the illumination. These 2 pins are not important. This switch is a piece of junk. If you still want to use it, I would remove your starter switch and check for continuity between pin 3 and pin 4 with a multimeter when you press the button. This is the easiest way to hook it up, but this is assuming the switch can handle 30A. They recommend using a 40A relay but said nothing about the switch's rating. If the switch can handle 30A you don't need a separate relay. Pin 1 - for now don't connect this pin. Pin 2 - connect this pin to ground to be safe. Pin 3 - connect this pin to the Black/White and Black/Yellow wires on the ignition switch harness. Pin 4 - connect this pin to the White wire on the ignition switch harness. The wires you use on pins 3-4 should be the same gauge as the Black/White, Black/Yellow, and White wires. 12 gauge won't be enough for this setup. If they come back and say the switch can't handle 30A then we'll have to use a relay. The idea is to connect the White wire to the Black/White and Black/Yellow wire when you press the button. That's all the ignition switch does. Call them. Ask how many amps pin 2 and 4 can handle max. |
#15 | |
Shouldn't it be black/white and white on the same connector? and black/yellow on it's own since that's what I'm trying to send the power too? Thanks for all the help, i really appreciate it |
#16 | |
Like I said above, one is for the starter and one is for the ECU. The starter runs but it doesn't start which means the ECU isn't getting the start signal. But don't hook it up yet until you get the answer to my question. If the switch is a piece of junk you'll need to put a fuse in front of pin 4 and use a relay. |
#17 |
Ok so if that is the case then i have my wiring stuffed up. Shouldn't pin 30 be the white wire then the two 87 pins get black/white and black/yellow?
Whatever the case I need to find the wire that powers the ecu and get that attached in this circuit. |
#20 | |
The stock ignition switch cuts power to the accessories when you're cranking the starter. There's no easy way to do that with a push button without using a relay and making your wiring more complicated = more potential for problems. |
#21 |
The switch shouldnt matter, all the switch needs to do is activate the relay which in turn will produce the power to feed to the starter...
Here's how I would do it... Not sure if that would work, but that would be my first try. I've installed a couple alarms and have yet to blow myself up with the wiring ![]()
#22 |
![]() Join Date: Feb 2007
![]() ![]() ![]() Feedback Score: 4 reviews
the starter "push button" doesnt need to be relayed, just fused. its a momentary switch. just run it straight to the starter wire that originally went to the ignition tumbler
so you would still have to have the key in and turned to ON. and then press the button. |
#23 | |||
Are you sure you want to put power on 87 and load on 30? Quote:
OP, if you can get lazy ignited people to respond I'll do a correct wiring diagram for you. Until then I don't want to design a circuit for a component that I don't know the specs on. |
#25 | |
This is a better choice: http://www.longacreracing.com/catalo...=1380&catid=12 Their ignition switch is rated for 40A which means you don't need a fuse or a relay. They also have the push button individually for cheaper. Check their online catalogue. |
#26 | |
![]() Join Date: May 2007
<------ Grumpy Old Asshole MY REVIEW THREAD: Ltdnismoracer4=DOOK http://www.zilvia.net/f/showthread.p...ltdnismoracer4 |
#28 | |
I found this on 240s forums:
![]() Quote:
I'll try it out maybe today, seems almost the same as i have it, but i think 87 and 30 are switched not sure though all these diagrams are starting to confuse me. This is where i found it: http://www.240sxforums.com/forums/sh...9&postcount=16 |
#29 | |
1) You need a fuse in front of the kill switch, and another one in front of the push button if the push button is rated at a lower amperage than the kill switch. 2) There are 2 wires that need power during starting. One is the starter. The other one is the ECU. 3) I don't know what "ignition wire" means, but the way he's got it you can accidentally run the starter even with the key off. <Russ>People are stupid and know nothing about electronics and circuit design. </Russ> That's it. I'm going to do one for you tonight. Just sit tight and check tomorrow. |
#30 |
Equipment needed:
* 30A or higher 12V momentary switch * 12gauge or thicker wiring * 30A or higher 12V relay with 87a terminal * other equipment necessary to connect wires ![]() The stock ignition switch works as shown in the chart. Constant power is delivered to the ignition switch via the White wire. When the key is turned to the first position, power is delivered to the accessories. When the key is turned to the second position, power is delivered to the ignition system. When the key is turned to start, power to the accessories is temporarily cut, and power is diverted to the two wires for the starter and the ECU. ![]() I recommend removing pins 4 and 5 from the harness. By doing this, you will no longer be able to start the car with the ignition switch. It is not necessary to remove these pins but I cannot guarantee reliability of the ignition switch because you have current flowing backward through the ignition switch. If you happen to press the push button and turn the key to start at the same time, I cannot predict what will happen. As such, pins 4 and 5 can be cut and the portion coming from the harness should be insulated and tucked away. See below for how to wire the portion going to the components. I also prefer to cut the Blue accessories and use a relay to turn off accessories power when the push button is pressed. This step is also not necessary. If you elect not to do this, make absolutely sure you turn off all your accessories before attempting to start the car. A weak battery may not have enough cold cranking amps to start the motor and power the accessories at the same time. The Black/Red Stripe ignition wire will be tapped as well. ![]() Here you can see the circuit with pins 4 and 5 removed, as well as the open in the Blue wire and the tap in the Black/Red Stripe. ![]() This is pretty simple and self-explanatory. You don't need a fuse or a relay if the push button is rated for at least 30A or higher. I recommend http://www.longacreracing.com/ for push buttons as well as complete switch panels. |
