Old 12-03-2007, 02:01 PM   #1
i need tires
i need tires's Avatar
i need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to alli need tires is a name known to all
Send a message via AIM to i need tires
question for guys driving slammed s14s
i was wondering if anyone can show me a different option to relocating my harness in the drive side wheel well...
i keep rubbing thru it.. and i dont think my harness can take another event!
thank you!
JadeCantDrift Blogspot
i need tires is offline   Reply With Quote
Old 12-03-2007, 02:06 PM   #2
downshift_sideways
No Limit Soldier.
downshift_sideways's Avatar
downshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfection
Send a message via AIM to downshift_sideways
Take off your fender, Pull the harness up. Get some zipties to hold it tight.
bolt it back up...That what I did.
allntrlundrgrnd: "you never really appreciate your parents fridge until you look into your own and its full of condiments only"
downshift_sideways is offline   Reply With Quote
Old 12-03-2007, 02:13 PM   #3
i need tires
been there done that... doesnt work very well for me.. mainly my harness its gettin chewed up right next to the grommet.
Old 12-03-2007, 02:14 PM   #4
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
I am not that slammed but I still rubbed my harness. I moved the harness up and also made a metal plate to protect it.
Jung918 is offline   Reply With Quote
Old 12-03-2007, 02:15 PM   #5
downshift_sideways
No Limit Soldier.
You can always cut, solder and extend it. wire by wire, so it doesn't hit?
Old 12-03-2007, 02:17 PM   #6
!Zar!
!Zar!'s Avatar
Disconect it at the junction box and route it through your engine bay.
Old 12-03-2007, 02:20 PM   #7
Tearlessj
Tearlessj's Avatar
Be diffrent, Bluetooth harnesses!
Nagasaki Motors
Friends help you move. Real friends help you move bodies.
Tearlessj is offline   Reply With Quote
Old 12-03-2007, 02:23 PM   #8
i need tires
is that inside the car on the drive side?
Old 12-03-2007, 02:24 PM   #9
Slidin240Wayz
Slidin240Wayz's Avatar
A plate of sheetmetal will work wonders.
Old 12-03-2007, 02:24 PM   #10
i need tires
HAHAHAHAHAHAH
Old 12-03-2007, 02:24 PM   #11
bwake 5
bwake 5 has a spectacular aura aboutbwake 5 has a spectacular aura aboutbwake 5 has a spectacular aura aboutbwake 5 has a spectacular aura aboutbwake 5 has a spectacular aura aboutbwake 5 has a spectacular aura aboutbwake 5 has a spectacular aura about
i know that mine is a s13 but i figured it wouldnt hurt to try and help. even if it doesnt lol
thats my old set up. but then went throught he blue power wire.... the new location has it going from the engine through a hole i cut to the inner fender to where it is.......
whatever i dont make sense.......i tried lol
bwake 5 is offline   Reply With Quote
Old 12-03-2007, 02:29 PM   #12
i need tires
thx but its pretty different lol
Old 12-03-2007, 02:29 PM   #13
bwake 5
id imagine.........
Old 12-03-2007, 02:34 PM   #14
revat619
Retired General
revat619's Avatar
revat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfection
either run a plate of sheet metal or relocate it to run through your engine bay. I did the latter. Now i dont have to worry about it ever again. Best method IMO.
www.Jspec.com
www.SpeedAlliance.com
www.PoweredByMax.net
Instagram: @rjsladerade
revat619 is offline   Reply With Quote
Old 12-03-2007, 02:36 PM   #15
ms!3
hmm. well what size tires are you running? that could fix your problem.
ms!3 is offline   Reply With Quote
Old 12-03-2007, 02:40 PM   #16
Prok0
Prok0 will become famous soon enoughProk0 will become famous soon enoughProk0 will become famous soon enough
Send a message via AIM to Prok0
If you are rubbing near where the harness goes thru the firewall, dial in more caster to pull the wheel forward..
My s14 is pretty low, and all I did was tuck the harness and zip tie it up and run some more caster and I have no problems rubbing the harness.
Sales @ Enjuku
email:[email protected] phone:352-241-8399
Prok0 is offline   Reply With Quote
Old 12-03-2007, 02:47 PM   #17
i need tires
caster can fix it also
im running 225/45/17s i was thinkin about going to 215/40/17s that would get the height of the tires atleast an inch lower.
how do i adjust my caster?
Old 12-03-2007, 02:49 PM   #18
revat619
Retired General
revat619's Avatar
yeah 225/45/17 is tall. I'd run either a 215 or a 235/40 if you want more grip. Yes, 235/40/17 is shorter than 225/45/17
www.Jspec.com
Old 12-03-2007, 02:50 PM   #19
!Zar!
!Zar!'s Avatar
Personally I cut/lengthened/soldered every wire in my car.
As of now my s14 has 245/45/17's up front. With modded fender wells.
Don't forget moving the harness is just one part of dropping your car extremely low.
Old 12-03-2007, 02:52 PM   #20
i need tires
well this is my daily drifter... it would take too much time to cut and solder every wire.. no yea fun!
Old 12-03-2007, 02:53 PM   #21
Prok0
To adjust caster you need to have adjustable tension rods.
I run a 235/40/17 up front with 2.0 degrees camber, 8 degrees caster iirc, and 0 toe, on a 17x9 +17, and have no rubbing issues, heres a pic so you can get an idea of my ride height..
Sales @ Enjuku
Old 12-03-2007, 02:56 PM   #22
i need tires
mine sits just like yours except i have 17x9+15
Old 12-03-2007, 02:59 PM   #23
Prok0
I would just pull the fender off, tuck the harness up above the rail, and zip tie it down, and also try and pull it back towards the firewall and zip tie it there as well, and then just dial in a little more caster and you shouldnt rub.
And if you slide you will probably like the additional caster because it helps with wheel return.
Sales @ Enjuku
Old 12-03-2007, 03:04 PM   #24
projectRDM
projectRDM's Avatar
Take the fender off, there's a triangular piece of sheetmetal that sits at the joint between the apron and the Apillar. Cut it out completely, now you have room to pull the harness further back towards the firewall without stretching it up too much, increasing tire clearance considerably at the back edge. You'll see what I mean when you get into it.
FORMERLY R240NA
Old 12-03-2007, 10:58 PM   #25
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
^^^Thats what I did with my old S14. Cut up a notch on the triangular piece, wedged harness thru it. Gave me a bit more room to pull the harness further back away from the wheels.
CLICK HERE!!!
Old 12-03-2007, 11:12 PM   #26
xamraci
xamraci will become famous soon enoughxamraci will become famous soon enoughxamraci will become famous soon enoughxamraci will become famous soon enough
Besides un-hooking everything and re-routing your stuff...I am in the same boat and I just DRIVE my car every day...not hard in events...so I know how you feel...and I rock camber like its going out of style...
I have only bumbed my drivers harness 1-2 times so far...I have re-tied it each time I have broken the tie off
xamraci is offline   Reply With Quote
Old 12-03-2007, 11:29 PM   #27
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Mine is through the engine bay.
Bling bling
http://bhworld.wordpress.com/
Old 12-04-2007, 12:45 PM   #28
undesiredshoe
undesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of light
Send a message via AIM to undesiredshoe
Put nails up in the fender well so if you tire tries to mess with your harness, it will get owned.
undesiredshoe is offline   Reply With Quote
Old 12-04-2007, 02:37 PM   #29
CKAMC
CKAMC's Avatar
CKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfection
just yank the box and wire and relocate them both inside
jade
do one of these then stop bitching about how weak your shit is
CKAMC is offline   Reply With Quote
Old 12-04-2007, 02:39 PM   #30
i need tires
jade
wtf are you talking about box and wire?
