Old 11-28-2007, 07:23 AM   #1
.:JD240:.
.:JD240:. is an unknown quantity at this point
Question Ignited Push button start into S13 troubles
I just finished wiring up my button, and it doesn't work. It will crank the engine over and when it seems like it's started and i let go of the button it's seems to stall or something. When I use the key it starts normally, anyone have any ideas?
Mine is set up kind of like this:
The only difference is that have the 12v power at both sides of the ignited switch coming from pin 30 on the relay. And of course the wire colors aren't right.
.:JD240:. is offline   Reply With Quote
Old 11-28-2007, 05:48 PM   #2
g6civcx
g6civcx's Avatar
The ignition switch harness has 5 pins: 12V(+), Accessories, Ignition, and two (2), repeat, 2 starter pins.
1 starter pin goes to the starter while another goes to the ECU. I think you're missing the other wire to the ECU. That's why it's cranking but not starting.
That wiring diagram is not correct for Nissan. If you're nice to me I can do a correct schematic for you. But first, you have to answer my questions:
1) What is the brand of the start switch?
2) How many pins does it have?
3) What does each pin do?
4) What is the maximum current (measured in Amps) can each pin handle?
5) What happens when the start button is pressed? Which pins are connected?
If you don't know the answer, contact the vendor and maybe they can contact the manufacturer.
If you can't get the answer, sell the switch and get another one from a reputable manufacturer. This is very basic information to wire up electronics and any manufacturer not willing to supply you with this info is shady.
Old 11-28-2007, 09:55 PM   #3
.:JD240:.
I have the same switch as the picture, the relay is a 30 amp but also has the same pins.
1)The brand is Ignited and I had to buy the relay my self
2)The relay has 5 pins the switch itself has 4
3)My pins have the same numbers as the ones in the picture.
Pin 87 and 87a Power whatever it is your wiring (i have 87 on my black with white stripe starter wire)
Pin 86 goes to the switching means (I have it on my ignited switch)
Pin 85 is ground (going straight to the body via a bold around the shifter)
Pin 30 goes to fused power from battery (Not sure what that really means, but I have it going to black and yellow from my ignition switch which is powered only when the key is on)
Now for the ignited unit (same numbers as the picture):
1 and 4 Supposed to get 12 volts when the ignition is on (I have them getting power from the same place as pin 30 on the relay could that be the problemÉ)
3 supposed to go to starter their crappy instructions say to use a relay but don`t use one in the diagram (mine is going to pin 86 on the relay)
2 ground (Mine goes to the black wire from my cigarette lighter)
4)The relay is 30 amps (recommended by ignited on their $&?t instructions)
5)When the button is pressed the starter works the engine tries to crank and when it sounds like it`s started and you release the button the engine dies. I noticed today when i try the button 3 times like 2 second wait between tries the engine will start but just barely. as for the schematic of the relay i`ll have to get you the schematic tomorrow, because the relay is in the car.
Thank you for your help and any info you can give me.
-Jon
Old 11-28-2007, 10:01 PM   #4
onesicklambo
onesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant futureonesicklambo has a brilliant future
are you leaving the key in when its being push button started? I think its either one of the wires is not getting power when your push button starting it(ACC wire more then likely) try this...turn the key to the ON(one click before START) and then push the button. DO you want to push button start it without the key in at all times? is there an immobilizer chip in the key?
onesicklambo is offline   Reply With Quote
Old 11-28-2007, 10:01 PM   #5
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
just turn the key lazy bastard
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 11-28-2007, 10:01 PM   #6
yokotas13
yokotas13's Avatar
i had hte same exact problem with a homeade switch setup
Id push it for about 4 seconds
release
then go again and it woudl start
but when i took it o ut, started up just fine
yokotas13 is offline   Reply With Quote
Old 11-28-2007, 10:04 PM   #7
onesicklambo
Starter Black/White Ignition Switch Harness Ignition Black/Red Ignition Switch Harness Ignition 2 Black/Yellow (cold start Wire) Accessory Blue Ignition Switch Harness
all of those need power while starting i think
Old 11-28-2007, 10:08 PM   #8
.:JD240:.
The key is in the on position when i push the button. Acc is not supposed to be powered when you start the car, it goes off when the key is in the start position. I can still start it with the key. There is no immobilizer chip, i drive a 1990 240 sx.
Old 11-28-2007, 10:49 PM   #9
deesz
deesz is making a name for him/her selfdeesz is making a name for him/her self
just so yuo know the wire colors do change at the ignition harness so dont fallow what people say make sure you test the wires. use a dvom, u dont have an airbag so you could use a test light.
check to see which one has 12v when the key is fully turned
you will have two starter wires and you will have to send 12 volts to both of them
deesz is offline   Reply With Quote
Old 11-28-2007, 10:57 PM   #10
.:JD240:.
Yea i know the colors are wrong, but the 2 12v wires for ignitionÉ, i only had one light up with my test light when i was in the start position
Old 11-29-2007, 06:22 AM   #11
g6civcx
g6civcx's Avatar
Don't worry about the relay for now. It' just a standard 12V 5pin relay. Let's talk about the starter switch.
Can you answer this question for me?
How much curren can pins 1 and 4 handle? You can connect these pins to your ignition switch but you have to be careful that you use the right gauge wire and, if necessary, put a fuse in front of them.
Basically, how many amps can your starter switch handle? Because potentially this switch can see as much as 30A if you wire it to the ignition switch (the ignition switch has a 30A fusible link).
The problem is if your starter switch is rated for less than 30A, you may have already fried it if you don't have a fuse in front of it.
Can you find out the answer to this? If you know for sure it can take 30A max then I'll be more confident that the rest will work.
Old 11-29-2007, 06:23 AM   #12
g6civcx
g6civcx's Avatar
This is correct. The Blue accessories wire gets no current when the key is turned to ST. This is to reduce current draw and to help send all the cranking power to the starter.
Old 11-29-2007, 08:46 AM   #13
.:JD240:.
I sent an e-mail to ignited asking them how much current the switch can handle hopefully they get back to me.
Well browsing their site I find a different set of instructions then the ones that came with my button, are all generic 5pin relays the same (as in which pins are which?), because the way they say to wire out the pins of the relay is not the same as what i did. The way i wired the relay is according to the instructions from the relay manufacturer,should i try the way on the ignited site?
http://www.ignitedperformance.com/pushbutton.pdf
They have pin 85(supposed to be ground) and pin 30(supposed to be fused power from battery) flip flopped.
They also have pin 86(supposed to go to the switching means) and pin 87( supposed to go to whatever your powering starter in my case) flip flopped.
I did notice that the wire i have giving power to the switch is not 12 gauge it's inferior could this be my problem?
Old 11-29-2007, 08:40 PM   #14
g6civcx
g6civcx's Avatar
Alright, right now my recommendation is to get rid of this switch. Their wiring instructions are wrong!
12V relays are pretty standard. 85-86 are control signal and ground. Doesn't matter which is which. 30 is current. 87 is load.
Their instructions are completely wrong!
This is the correct way.
-4 to 12 volt source
-3 to 85 or 86, the other one of 85 or 86 to ground
30 to 12 volt source
87 to starter wire
It looks like 1 and 2 are for the illumination. These 2 pins are not important.
This switch is a piece of junk.
If you still want to use it, I would remove your starter switch and check for continuity between pin 3 and pin 4 with a multimeter when you press the button.
This is the easiest way to hook it up, but this is assuming the switch can handle 30A. They recommend using a 40A relay but said nothing about the switch's rating. If the switch can handle 30A you don't need a separate relay.
Pin 1 - for now don't connect this pin.
Pin 2 - connect this pin to ground to be safe.
Pin 3 - connect this pin to the Black/White and Black/Yellow wires on the ignition switch harness.
Pin 4 - connect this pin to the White wire on the ignition switch harness.
The wires you use on pins 3-4 should be the same gauge as the Black/White, Black/Yellow, and White wires. 12 gauge won't be enough for this setup.
If they come back and say the switch can't handle 30A then we'll have to use a relay.
The idea is to connect the White wire to the Black/White and Black/Yellow wire when you press the button. That's all the ignition switch does.
Call them. Ask how many amps pin 2 and 4 can handle max.
Old 11-29-2007, 09:22 PM   #15
.:JD240:.
Ok i'll try this tomarrow, but if black and whit and black and yellow are connected won't the car crank anytime the key is in the on position?
Shouldn't it be black/white and white on the same connector? and black/yellow on it's own since that's what I'm trying to send the power too?
Thanks for all the help, i really appreciate it
Old 11-30-2007, 05:56 AM   #16
g6civcx
g6civcx's Avatar
No. Power comes from the White wire. Black/White and Black/Yellow gets connected to White when you turn the key to ST. Read the EL section of the FSM.
Like I said above, one is for the starter and one is for the ECU. The starter runs but it doesn't start which means the ECU isn't getting the start signal.
But don't hook it up yet until you get the answer to my question. If the switch is a piece of junk you'll need to put a fuse in front of pin 4 and use a relay.
Old 11-30-2007, 07:33 AM   #17
.:JD240:.
Ok so if that is the case then i have my wiring stuffed up. Shouldn't pin 30 be the white wire then the two 87 pins get black/white and black/yellow?
Whatever the case I need to find the wire that powers the ecu and get that attached in this circuit.
Old 11-30-2007, 07:36 AM   #18
g6civcx
g6civcx's Avatar
There is usually only 1 87 pin. If you mean 87a then that's not the right pin. 87a is the reverse of 87.
Old 12-04-2007, 04:18 PM   #19
.:JD240:.
I don't think ignited is going to get back to me. it's been a few days.
Old 12-05-2007, 06:45 AM   #20
g6civcx
g6civcx's Avatar
Sell that switch on ebay.
The stock ignition switch cuts power to the accessories when you're cranking the starter. There's no easy way to do that with a push button without using a relay and making your wiring more complicated = more potential for problems.
Old 12-05-2007, 09:12 AM   #21
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
The switch shouldnt matter, all the switch needs to do is activate the relay which in turn will produce the power to feed to the starter...
Here's how I would do it...
Not sure if that would work, but that would be my first try. I've installed a couple alarms and have yet to blow myself up with the wiring
Old 12-05-2007, 12:17 PM   #22
chaseSR86
chaseSR86 is making a name for him/her selfchaseSR86 is making a name for him/her selfchaseSR86 is making a name for him/her self
the starter "push button" doesnt need to be relayed, just fused. its a momentary switch. just run it straight to the starter wire that originally went to the ignition tumbler
so you would still have to have the key in and turned to ON. and then press the button.
chaseSR86 is offline   Reply With Quote
Old 12-05-2007, 04:28 PM   #23
g6civcx
g6civcx's Avatar
Good try, but that's not going to work well. 87a should not be grounded. Leave that disconnected.
Are you sure you want to put power on 87 and load on 30?
This is correct provided the ignition switch is rated for at least 30A. If the switch is rated for less than 30A you will need a relay.
Make sure you power off all the accessories because the ignition switch will not kill power to the accessories like the stock ignition switch.
OP, if you can get lazy ignited people to respond I'll do a correct wiring diagram for you. Until then I don't want to design a circuit for a component that I don't know the specs on.
Old 12-05-2007, 07:48 PM   #24
.:JD240:.
When I push the button the acc poower is cut, I know because my cd player goes off when i press the button.
Old 12-06-2007, 06:42 AM   #25
g6civcx
g6civcx's Avatar
That's not good. Either you have a short in the wiring or the battery is being drained by the starter.
This is a better choice: http://www.longacreracing.com/catalo...=1380&catid=12
Their ignition switch is rated for 40A which means you don't need a fuse or a relay. They also have the push button individually for cheaper. Check their online catalogue.
Old 12-06-2007, 06:51 AM   #26
DOOK
DOOK's Avatar
I'm confused, I thought your accessories were supposed to power down on startup
<------ Grumpy Old Asshole
DOOK is offline   Reply With Quote
Old 12-06-2007, 07:56 AM   #27
g6civcx
g6civcx's Avatar
That's the way the stock ignition switch works. He hasn't touched his accessory wire but his push button turns off the accessories, which means there's a problem somewhere.
Old 12-10-2007, 07:40 AM   #28
.:JD240:.
I found this on 240s forums:
The ignition wire is the black/white wire and the starter wire is the black/green wire. (In my pictures, it's black/yellow. Either I'm color-blind or my camera is messing it up.) For the 12v supply, I just used the headlight button harness.
It looks like i need to tap the Black/Green
I'll try it out maybe today, seems almost the same as i have it, but i think 87 and 30 are switched not sure though all these diagrams are starting to confuse me.
This is where i found it:
http://www.240sxforums.com/forums/sh...9&postcount=16
Old 12-10-2007, 10:10 AM   #29
g6civcx
g6civcx's Avatar
There are several things wrong with that schematic:
1) You need a fuse in front of the kill switch, and another one in front of the push button if the push button is rated at a lower amperage than the kill switch.
2) There are 2 wires that need power during starting. One is the starter. The other one is the ECU.
3) I don't know what "ignition wire" means, but the way he's got it you can accidentally run the starter even with the key off.
<Russ>People are stupid and know nothing about electronics and circuit design. </Russ>
That's it. I'm going to do one for you tonight. Just sit tight and check tomorrow.
Old 12-10-2007, 10:54 PM   #30
g6civcx
g6civcx's Avatar
Equipment needed:
* 30A or higher 12V momentary switch
* 12gauge or thicker wiring
* 30A or higher 12V relay with 87a terminal
* other equipment necessary to connect wires
The stock ignition switch works as shown in the chart. Constant power is delivered to the ignition switch via the White wire. When the key is turned to the first position, power is delivered to the accessories. When the key is turned to the second position, power is delivered to the ignition system. When the key is turned to start, power to the accessories is temporarily cut, and power is diverted to the two wires for the starter and the ECU.
I recommend removing pins 4 and 5 from the harness. By doing this, you will no longer be able to start the car with the ignition switch. It is not necessary to remove these pins but I cannot guarantee reliability of the ignition switch because you have current flowing backward through the ignition switch. If you happen to press the push button and turn the key to start at the same time, I cannot predict what will happen.
As such, pins 4 and 5 can be cut and the portion coming from the harness should be insulated and tucked away. See below for how to wire the portion going to the components.
I also prefer to cut the Blue accessories and use a relay to turn off accessories power when the push button is pressed. This step is also not necessary. If you elect not to do this, make absolutely sure you turn off all your accessories before attempting to start the car. A weak battery may not have enough cold cranking amps to start the motor and power the accessories at the same time.
The Black/Red Stripe ignition wire will be tapped as well.
Here you can see the circuit with pins 4 and 5 removed, as well as the open in the Blue wire and the tap in the Black/Red Stripe.
This is pretty simple and self-explanatory. You don't need a fuse or a relay if the push button is rated for at least 30A or higher.
I recommend http://www.longacreracing.com/ for push buttons as well as complete switch panels.
