Old 12-07-2007, 10:58 AM   #31
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
They were 70 bucks each from kragen after the core swap.
parking lot pimpin...
Seller Feedback here:
http://www.zilvia.net/f/showthread.p...ight=pbcstylez
pbcstylez is offline   Reply With Quote
Old 12-07-2007, 11:51 AM   #32
motorsnail
motorsnail's Avatar
motorsnail is a name known to allmotorsnail is a name known to allmotorsnail is a name known to allmotorsnail is a name known to allmotorsnail is a name known to allmotorsnail is a name known to allmotorsnail is a name known to allmotorsnail is a name known to allmotorsnail is a name known to allmotorsnail is a name known to allmotorsnail is a name known to all
Originally Posted by THEMkris View Post
backwards??? as in the shims facing the rotor?? well noo..
but putting them the other way wouldnt work either. the hawk pads have two "studs" on the back of two pads. they wouldnt let me install them backwards cause the caliper wouldnt go on all the way. so there was basically only one way to put them
not shims facing dude as in the brake pads thats closest to you should be on the far side. And you can put them on backwards I just went and looked. Go feel your rotor dude just to make sure, if its rough feeling you got to buy some new pads and rotors. Im not saying this to make you feel stupid trying to save you some headache.
:Edit: Try and explain it easiest way I can sence im not a teacher you might have to read this a couple times. A brake pad is like sharks skin rub with the rotor one way stops it smooth. Go the other way rubbing the pad on the rotor its like sand papper. So if you put them on the wrong sides (just because the shim is facing the right way doesnt mean its on right sorry) they will distroy each other. Go get a brake pad and a rotor then you will see what im talking about.
motorsnail is offline   Reply With Quote
Old 12-08-2007, 12:39 AM   #33
THEMkris
THEMkris has a spectacular aura aboutTHEMkris has a spectacular aura aboutTHEMkris has a spectacular aura aboutTHEMkris has a spectacular aura aboutTHEMkris has a spectacular aura aboutTHEMkris has a spectacular aura about
^^ can anyone else vouche for this?
i need to pin down the problem..
1. brakes have a lil "drag" (hear brakes dragging on rotor)
2. stepping on brake or pulling ebrake makes sound louder.
3. ebrake is weak. does not lock wheels at all.
4. piston on rear caliper is ripped. no leaks.
5. improper wear on brakes (not fully using entire brake pad surface)
what can be my problems?
the only thing i can think of is that my piston is bad. the caliper isnt retracting all the way, isnt pressing the brake pad sufficiently, and pushing in the brake pad crookedly.
any other reasons that i should keep in mind?
THE HAPPY E-BRAKE MONKEYS!
THEMkris is offline   Reply With Quote
Old 12-08-2007, 01:01 AM   #34
S14DB
AFC #1
S14DB's Avatar
You turn the piston to set it inside the caliper or did you push it like the front?
Old 12-08-2007, 01:09 AM   #35
THEMkris
turned clockwise .. but how difficult should it be to turn it back in? it was pretty hard to turn it back in. almost striped the tool used to turn the piston in.
Old 12-08-2007, 07:31 AM   #36
chuy
chuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura aboutchuy has a spectacular aura about
I changed from HPS to the lower level of Hawks. If you didnt use some lube or brake them in nice and good they will make noise even after they will. Ive got my e-brake tightened so much that I cant go no more and I still cant lock em up.
Slide Happy
chuy is offline   Reply With Quote
Old 12-08-2007, 07:49 AM   #37
Tearlessj
Tearlessj's Avatar
Originally Posted by Dousan_PG View Post
tighten up the cable then
thts usually it
with a stock rear caliper
after using fancy rears for ebrake
i went back to stock pads cheapies from autozone
they dont need any heat to lock and lock up fast and easy
Good advice Aaron. Im ganna go try some Autozone pads now. My e-brake only lock up when I pull as hard as I freaking can. Its even hard to do in the rain with wal-mart tires.
Nagasaki Motors
Friends help you move. Real friends help you move bodies.
Tearlessj is offline   Reply With Quote
Old 12-08-2007, 08:53 AM   #38
frankist
frankist has a spectacular aura aboutfrankist has a spectacular aura aboutfrankist has a spectacular aura aboutfrankist has a spectacular aura aboutfrankist has a spectacular aura aboutfrankist has a spectacular aura about
are you screwing in the piston while pushing it in, and lining up the piston with the pad? if not it'll create that uneven'ness.
frankist is offline   Reply With Quote
Old 12-08-2007, 08:57 AM   #39
frankist
whoops, just read 2 post above, but it still needs to be lined up with the piston, thats the only other reason i can see the uneven wearing of the pad to the rotor, ive seen this once where this happened and they cross threaded the caliper bolts. so check it out, make sure the pad fits on there correctly.
cheers yo.
Old 12-08-2007, 11:04 AM   #40
aznpoopy
aznpoopy's Avatar
#1 you probably need to screw in the piston more
#2 yes its going to be hard. you are fighting old ass brakes, not to mention the hydraulic pressure in the system.
#3 the boot would worry me. i would personally replace it. next time make sure the boot doesnt crimp when you are screwing in the piston. yes its a pita
#4 take out the pad. if it has little stubs on the backside, you'll need to line them up with a 'gap' in the face of the piston for it to sit flat and not at an angle.
Old 12-08-2007, 11:09 AM   #41
motorsnail
motorsnail's Avatar
1. The brake pads shouldnt be grinding. Thats what brake fluid is for.
2. Your rotors are getting eatin away.
3. Ive seen this happen more then once.
4. Its really easy to put them on wrong.
5.Can nobody read my post or somthing his rotor is fubared.
Old 12-08-2007, 11:11 AM   #42
THEMkris
aznpoopy- .. can you elaborate more on that? i'll check that out tonight.
and everyone else saying they're ebrake isnt catching.. what in the world? with hawk hps, shouldnt it lock up really hard??
Old 12-08-2007, 12:55 PM   #43
THEMkris
and can anyone vouche for motorsnail??
Old 12-08-2007, 01:01 PM   #44
karl wasabi
karl wasabi's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
I have a similar problem with my Hawk pads. I had project mu pads before, and they locked up no problem. I guess it's just the pad material.
I think you just need to break them in more. =)
karl wasabi is offline   Reply With Quote
Old 12-08-2007, 01:14 PM   #45
THEMkris
i think i've done all the breaking in i should do.
but anyways, i just checked my rotor.. its starting to etch onto the inner portion of the rotor..
Old 12-08-2007, 01:49 PM   #46
Turtle
Turtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymore
Sorry to highjack the thread but, I got a similar problem my E-Brake isn't grabbing right with new pads installed either. I went to put gas on my car when I got off my car to the gas station my rear smelled like brakes really bad... What could be wrong?
Turtle is offline   Reply With Quote
Old 12-08-2007, 01:54 PM   #47
THEMkris
how long ago did you install them? did you break them in?
Old 12-08-2007, 01:58 PM   #48
Turtle
Installed about 2 weeks ago, I set my car aside so I can fix it but, haven't gotten around to it since I've been reading on what could be wrong... Its been driven for about 2 hours... Pads are half gone.
Old 12-08-2007, 02:00 PM   #49
THEMkris
wait your new pads are half gone already? what pds did you get?
Old 12-08-2007, 02:04 PM   #50
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
Give us pics guys. It'll help us help you.
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 12-08-2007, 02:08 PM   #51
Turtle
35$ dollar pads off of autozone... My bro used it and my rotor needed like 1/8 inch to reach the other side...
Old 12-08-2007, 02:09 PM   #52
Turtle
I changed the rotors to drilled and slotted...
Old 12-08-2007, 02:23 PM   #53
THEMkris
well im buying new calipers and bleeding my whole system on monday morning.. i'll take pictures then.. until then, i just read that my brake lines may be bad. if i open up the bleeder and the fluid just rushes out, the something is wrong with my lines.. i'll be sure to check that on monday too..
does anyone else have any more input??
Old 12-08-2007, 02:31 PM   #54
MrChow
MrChow's Avatar
Go download the FSM...
Old 12-08-2007, 02:40 PM   #55
cloudstrife930
cloudstrife930 is on the path to ruincloudstrife930 is on the path to ruin
I the same problem with my new rear pads, I know this may sound silly, but I couldnt get my rear calipers in, the guy i bought the car from told me, there was no more pads left. The pistons came all the way out. I took the pistons all the way out til the brake fluid came spraying all out to relieve pressure. Then they went back in easy, all the way in. I got autozone pads as well. After turning them all the way in. There is a little bump on the pads. You have to make sure that the space on the caliper is corresponding with the piston. Also I dont know how, but i may have bent the backing plate a lil. Stuck a screw driver in it and made sure it wasent hitting rotor, then i was good. Of course i had to bleed the brakes afterwerds
Drift until you cum!
cloudstrife930 is offline   Reply With Quote
Old 12-08-2007, 02:57 PM   #56
THEMkris
can you elaborate more on this?
hmmm.. trying to make sense of what you just said.. tonight i'll check it out. it was pretty tight putting the caliper on .. i'll try it once more but making sure i push the piston ALL the way in.
Old 12-08-2007, 03:02 PM   #57
Turtle
So, should we push the piston all the way in and bleed the system? I didn't bleed my brakes when I changed the brakes and calipers could that be it? What has me stumped is that the rear brakes are always grabbing but the E-brake doesn't lock up.
Old 12-08-2007, 03:10 PM   #58
THEMkris
grabbing? as in???
Old 12-08-2007, 03:12 PM   #59
Turtle
Always braking... This sucks I need my car to work.
Old 12-08-2007, 03:15 PM   #60
THEMkris
always braking or dragging? as in it slows down your car?
