New pads, weak ebrake?
okay so i just got done installing new hawk hps on my s14. had to replace the rear rotors in the process. i worn in the breaks for a good hour or so as well. but still the ebrake is not catching nor locking up the rear wheels. what could be wrong?
**EDIT** i need to pin down the problem.. 1. brakes have a lil "drag" (hear brakes dragging on rotor) 2. stepping on brake or pulling ebrake makes sound louder. 3. ebrake is weak. does not lock wheels at all. 4. piston on rear caliper is ripped. no leaks. 5. improper wear on brakes (not fully using entire brake pad surface) what can be my problems? the only thing i can think of is that my piston is bad. the caliper isnt retracting all the way, isnt pressing the brake pad sufficiently, and pushing in the brake pad crookedly. any other reasons that i should keep in mind?
THE HAPPY E-BRAKE MONKEYS! Last edited by THEMkris; 12-08-2007 at 12:40 AM.. |
![]() Join Date: May 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 23 reviews
u trying to do it for drifting?
with those type of pads i usually do a lap or two w/ the ebrake up a bit heat the pads up first get them in the right spot then they'll grab like crazy had to do it a lot when did the touge drift drive into the mounts w/ the ebrake up enough to cause some good friction then it worked great |
well i tried breaking them w/ some ebraking. i know damn well the pads are heated up so i try to at least do a lil 180 and the rear brakes will not grab at all.
THE HAPPY E-BRAKE MONKEYS! |
tighten up the cable then
thts usually it with a stock rear caliper after using fancy rears for ebrake i went back to stock pads cheapies from autozone they dont need any heat to lock and lock up fast and easy |
#5 |
![]() Join Date: Feb 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
Good advice Aaron. Im ganna go try some Autozone pads now. My e-brake only lock up when I pull as hard as I freaking can. Its even hard to do in the rain with wal-mart tires.
![]() ![]() Friends help you move. Real friends help you move bodies. |
#6 | |
![]() Join Date: Nov 2007
I would appreciate your input.
DREW SLIDE TO SIDE WORLD WIDE Feedback!! http://www.zilvia.net/f/showthread.php?t=182673 661 sliders Gymkhana @ buttonwillow http://zilvia.net/f/south-western-st...-sessions.html >> Bakersfield Hook up thread << |
#7 | |
didnt care. only cost mattered hahaha |
#8 |
also, when im just driving, with the windows up and the radio off, i can hear the rear brakes "rubbing?". is that normal for new pads?
#14 |
please help. i torqued them down to 20 and the brakes are still "rubbing". i just got back from under my car again and with the rear lifted, if i spin the wheel i hear the same noise.. what the hell is going on. please help.
#17 |
![]() Join Date: Mar 2003
shims = little metal clips. that won't come with your brake pads. they keep the pads from rattling.
as for the noise you hear, its a floating caliper assembly. the pads may touch the rotor a little while not driving. it's not a problem unless they are actually dragging - i.e. braking while you are not braking. if that is the case i would guess you did not reset the piston sufficiently during the install. either that or the caliper is seized. |
#18 |
okay, the dust boot on my piston is ripped. that seized my brakes last night after drifting and hitting some dirt.
i think they're seized. what exactly happens when they're seized?
#20 |
![]() Join Date: May 2005
oem rebuilt ones are like 70 bucks, either get a replacement or go z32
![]() parking lot pimpin... Seller Feedback here: http://www.zilvia.net/f/showthread.p...ight=pbcstylez |
#22 |
you don't have to. just go to your local pepboys/autozone/kragens/napa
they can order you already rebuilt calipers then you swap em out and give them your old cores to get a little money back |
#24 |
well both really. the passenger side is the worst. where in so cal are you?
does any one know how to rebuild the rear calipers? i just bought two kits from auto zone.
#25 |
dammit, i just looked at the kit and it doesnt come with springs, washers, etc. just rubber seals. i might as well just buy rebuilt ones from autozone.. thanks aznpoopy....
#26 |
#28 |
i got my S13 rears from autozone for i think about $300 and got $100 back for the cores, so it came out to just about $200 total. that was for completely loaded ones, they had pads/clips/everything. just bolt up and go. but oh yea. if you go that route. make sure you keep your banjo bolt from your old calipers. the new ones dont have those. we had to make 2 trips back to autozone becuase of that shit lol.
#30 |
no doubt the bolt that holds the brake line to the caliper
honestly i don't remember it being a banjo bolt, but i haven't touched my rear brake lines in at least a year |
