#61 |
![]() Join Date: Jul 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
It slows my car down really fast for the e-brake to be doing that. My rear lights aren't on so I know it can be the front brakes also, since I didn't mess with that.
#63 | |
![]() Join Date: Nov 2007
I would appreciate your input.
DREW SLIDE TO SIDE WORLD WIDE Feedback!! http://www.zilvia.net/f/showthread.php?t=182673 661 sliders Gymkhana @ buttonwillow http://zilvia.net/f/south-western-st...-sessions.html >> Bakersfield Hook up thread << |
#65 |
Well out in the cold I tried to fix it... Whenever I tighten down the 14mm bolts the rear brakes don't move... So I tried pushing the piston in more... I couldn't how do I do it? Do I have to open the nipple it has and take out the brake fluid?
#66 |
well you might as well jst take out the whole caliper since you're probably gonna have to do a brake flush also. either that or yea, release some pressure so that it's easier to push in the piston more..
you just gotta make sure your piston is in good shape.
THE HAPPY E-BRAKE MONKEYS! |
#67 |
How can you tell your piston is in good shape? Before my bro drove my car my ebrake worked well I could lock the rear tires easily. I find it hard to believe that the piston would go bad after a brake change.
#68 |
well depends on how you put it back in. mines in bad shape since the boot has been torn for a while.
one thing someone else told me was to tighten up the ebrake cable. they tend to stretch after a while. either that or bleed your lines.. open up the bleeder without stepping on the brake and if the brake fluid gushes out then you have bad break hoses. the fluid should just dribble out.
#69 |
![]() Join Date: May 2005
why dont u start with a new rear caliper? you stated that the boot is torn, either way you are going to have to replace it unless you're goign z32 rears. As i had mentioned above its like 70 bucks for the caliper if you have a core swap. This is a good place to start
![]() parking lot pimpin... Seller Feedback here: http://www.zilvia.net/f/showthread.p...ight=pbcstylez |
#70 |
on the rear calipers you cant just simply push in, you have to get a tool to rotate the piston back in, and while doing it to be careful of the boot. The tool is $10 at your local vatozone.
#72 |
needle nose pliers works just fine, just spread them far enough for the tips to fit into the grooves, then turn.
#73 |
AFC #1
![]() Join Date: Oct 2003
The tool is sooo much easier, I got the master kit at Harbor fright. I think the C-caliper and wood block is still the best in the front. But the Tool is 10x faster on the rear and easier on your hands.
#74 | |
![]() Join Date: May 2002
didnt care. only cost mattered hahaha |
#76 |
than go organic pad in the rear as cheap as they get iirc
#77 |
i run pbr/axxis ultimates all way aorund and i can lock the rear up fine on track and off for drifting... alot of people love how my ebrake feels (most tech guys comment on it) i blew one caliper at the track and replaced it no problems so far. id like to put my spl rear lines on but they wont come undone and i dont feel like replacing twisted brakes lines trying so they can wait lol
