Old 12-10-2007, 06:51 PM   #1
breakingsociety
breakingsociety is on the path to ruinbreakingsociety is on the path to ruinbreakingsociety is on the path to ruin
Send a message via AIM to breakingsociety
Crank Angle Sensor location
Alright fellas, I have searched for this information, but i do not find specific enough info to work with.
I really need to know how to get to the Crank Angle sensor, where it is located ( on tranny bell housing? But where on the bell housing)
I have an s14 ka. Please let me know what i must do. thank you.
breakingsociety is offline   Reply With Quote
Old 12-10-2007, 07:00 PM   #2
MavericStephenc
MavericStephenc's Avatar
MavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfection
Send a message via AIM to MavericStephenc
the crank angle sensor is located in the distributer. It's a 360degree tooth wheel
edit: I had a blonde moment
That kind of attitude is SHIT. People with that kind of complacent outlook on law and government are the bane of this country's existence. -Thesquidd
Boycott Berkeley and code pink
MavericStephenc is offline   Reply With Quote
Old 12-10-2007, 07:00 PM   #3
diomedes
diomedes is a splendid one to beholddiomedes is a splendid one to beholddiomedes is a splendid one to beholddiomedes is a splendid one to beholddiomedes is a splendid one to beholddiomedes is a splendid one to beholddiomedes is a splendid one to beholddiomedes is a splendid one to beholddiomedes is a splendid one to beholddiomedes is a splendid one to beholddiomedes is a splendid one to behold
You got it right. It is on top of the tranny bell housing.
diomedes is offline   Reply With Quote
Old 12-10-2007, 07:02 PM   #4
MavericStephenc
nvm I guess I'm wrong
Old 12-10-2007, 07:07 PM   #5
projectRDM
projectRDM's Avatar
Camshaft position sensor is located within the distributor.
Crankshaft position sensor sits in the bellhousing, top side, just below the EGR pipe. Accessible from the exhaust side with a short socket and wobble extension, or a stubby wrench.
FORMERLY R240NA
Old 12-11-2007, 10:13 AM   #6
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
yr wrong, thats the cam angle sensor.. it isnt a 32 tooth.. but rather a rotor..
crank angle is on the tranny bellhousing...
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 12-11-2007, 06:51 PM   #7
breakingsociety
thanks for the information guys. you really helped me out
Old 12-11-2007, 06:57 PM   #8
Pank
Pank's Avatar
Pank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfection
you can also drill a hole in the floorpan to halfass get to it
Pank is offline   Reply With Quote
Old 12-11-2007, 08:23 PM   #9
projectRDM
projectRDM's Avatar
?? The firewall maybe, behind the heater core. Unless your bellhousing is at the other end of the transmission.
FORMERLY R240NA
Old 12-12-2007, 04:43 AM   #10
smelly240
smelly240's Avatar
wow - its silly to cut a hole in ur car - just do it the right way
i cant really picture where u'd cut - anyway??? I dont have a KA to look at, but i imagine its easier to drop a tranny than remove everything from the dash, inward.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
smelly240 is offline   Reply With Quote
Old 12-13-2007, 07:33 PM   #11
breakingsociety
hey guys, well i havent got round to replacing the crank shaft sensor, but i did however replace the crank angle sensor and came across a bad problem. The car will not start! I put in the newer angle sensor from a 96 ka24, and i connected the wiring to it and tried to start, but it wouldnt fire up. I would just get the noise proving that my starter is working but seems like the distributor wasnt firing.
SO, i replaced the sensor to hopefully "UNDO" what i am having a problem with and replaced the original sensor. However, still nothing. the car woudlnt start.
I THINK that in the process i messed up the distributor. Could this be an issue? does the distributor have to have the same angle it was in before (if you understand wat im saying)? please let me know what i possibly could have done and what i need to do next....
thanks zilvia for your help!
Old 12-13-2007, 09:46 PM   #12
projectRDM
projectRDM's Avatar
You're kidding right? Do you even know what a distributor does?
Ignition timing. Imagine you're at 10 degrees BTDC, you take the distributor out and rotate it half way around. Now where are you? I'll give you a hint, it's not at 10 degrees anymore.
FORMERLY R240NA
