Old 12-12-2007, 06:10 PM   #1
NemeGuero
No more nissan.
NemeGuero's Avatar
s14 5-pt harness mounting locations
Wussup yall. This is the rickety rick..
No, its not really.
But who has pictures of where they mounted their 5 pt harness stuff in an s14?
There is no convenient spot for the 5th point, is there?
-Evan
(NemeGuero)*Fuckin' Kevin.
Old 12-12-2007, 06:58 PM   #2
wonkuuzenki
wonkuuzenki's Avatar
wonkuuzenki is making his/her stupidity well-knownwonkuuzenki is making his/her stupidity well-knownwonkuuzenki is making his/her stupidity well-knownwonkuuzenki is making his/her stupidity well-knownwonkuuzenki is making his/her stupidity well-known
I would do it one of two ways, either get a half cage with a proper harness mounting bar or get a workshop that makes cages to weld a bar in between the rear strut towers and mount the harness on that.
My theory is that if you ever need the harness then you need to to be absolutely right, if you can't be sure that it's absolutely right I'd stick to the factory 3 point which has gone through extensive testing.
looking for a pic i know i have one.
Function. Form.
Step Up Drift Club/Upper Limit!
wonkuuzenki is offline   Reply With Quote
Old 12-12-2007, 08:48 PM   #3
S13Boosts
S13Boosts's Avatar
S13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfection
is it a bolt in harness?
S13Boosts is offline   Reply With Quote
Old 12-12-2007, 09:09 PM   #4
shift_drift
shift_drift is an unknown quantity at this point
I think he is talking about the submarine(nut) belt.
shift_drift is offline   Reply With Quote
Old 12-13-2007, 12:16 PM   #5
NemeGuero
No more nissan.
NemeGuero's Avatar
Yah, the nut belt..
well and the bolt for the inside lap belt..
and the shoulder belts require a bar, i get that.
Old 12-13-2007, 12:29 PM   #6
tknbkthrsdy4anfg
tknbkthrsdy4anfg's Avatar
tknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfection
Send a message via AIM to tknbkthrsdy4anfg
Drill a hole in the floor and use some washers edited.
Originally Posted by Brian
well I suppose you can imagine it like a parking space that you think "gosh, I’ll never fit in there" But then you fold in the side view mirrors and what do you know, your in.
$pending dead pre$ident$ J@CK@TT@CK!
tknbkthrsdy4anfg is offline   Reply With Quote
Old 12-13-2007, 12:31 PM   #7
vvtisupra
vvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond repute
Send a message via AIM to vvtisupra
weld a bar between the 2 seat brackets and drill a hole in the center and put an eye- bolt in there and clip it in. FYI 5th point is fazed out. They ahve the 6 point now where each leg gets an individual strap.
http://www.fuckdrama.com/
vvtisupra is offline   Reply With Quote
Old 12-13-2007, 12:38 PM   #8
s14_mike
s14_mike will become famous soon enoughs14_mike will become famous soon enoughs14_mike will become famous soon enoughs14_mike will become famous soon enoughs14_mike will become famous soon enough
your probably going to have to have a bracket welded in if you don't want to drill through the floor. Just my two cents?
s14_mike is offline   Reply With Quote
Old 12-13-2007, 12:42 PM   #9
Nikeboy355
Nikeboy355's Avatar
Nikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond repute
Or why not but the 6 point attachment and anchor off the front seat bracket bolts?...
5th point scares me for obvious reasons... I'd keep it looser than the rest of the harness when you strap up...
Nikeboy355 is offline   Reply With Quote
Old 12-13-2007, 01:34 PM   #10
vvtisupra
that 5th belt will hurt you more if you left it loose. The whole point of the anti submarine belt is so you don';t come shooting out of your seat, or sliding down the seat and having your 4 point rip up at your ribs. If you leave it loose that will give your body more room to build momentum crushing your nuts even more. I heard that the subaru that crashed on streets of willow that caused a big hooplah like a year ago had a passenger chick that had a 4 point on but after the crash she was stuffed under the dash cuz she didn;t have the anti submarine belt. Having your seat raked back at an angle (like its suppose to be) kinda stops that, but its always nice to have a back up. With that said i should do less talking and more dooing cuz I haven't put my 5th point in either = )
Old 12-14-2007, 12:22 AM   #11
NemeGuero
No more nissan.
NemeGuero's Avatar
My buckle is 5 point.
I still don' tknow where people have the lap belt restraints mounted. I know the outside one can be bolted to the OG seatbelt mounting spot...
Where do you bolt the inside belt? to the seat rail? Its a Bride type LH. Should I remove one of the bolts on the 90 degree plate attaching to the rail and slip the belt connector under there?
Old 12-14-2007, 02:48 PM   #12
NemeGuero
No more nissan.
NemeGuero's Avatar
muther fuck, none of you s14 fucks have fucking pics of where you fucking mounted your fucking harness?
hhahaha
shit.
Outside lap belt uses OG seatbelt mount. K.
For 5th point I need to either weld a bar or drill a hole. K.
shoulder straps need a bar across the back. K.
Inside lap belt?
Old 12-14-2007, 03:15 PM   #13
89singlecamnoob
89singlecamnoob's Avatar
89singlecamnoob has much to be proud of89singlecamnoob has much to be proud of89singlecamnoob has much to be proud of89singlecamnoob has much to be proud of89singlecamnoob has much to be proud of89singlecamnoob has much to be proud of89singlecamnoob has much to be proud of89singlecamnoob has much to be proud of89singlecamnoob has much to be proud of89singlecamnoob has much to be proud of89singlecamnoob has much to be proud of
Send a message via AIM to 89singlecamnoob Send a message via Yahoo to 89singlecamnoob
you have a pic of your seat/rail assembly? i've got an idea but i need to see a pic to make sure it would work.
"Alfa Romeo builds cars to be as good as a car can be...briefly." -Clarkson
89singlecamnoob is offline   Reply With Quote
Old 12-14-2007, 03:20 PM   #14
Slidin240Wayz
Slidin240Wayz's Avatar
I used the seat rail itself.
There is a bracket on there with a hole.
Old 12-14-2007, 06:01 PM   #15
tt99ol
tt99ol's Avatar
tt99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond reputett99ol has a reputation beyond repute
Send a message via AIM to tt99ol
bolt it to where the oem seatbelt buckle bolts up, right on the bracket
tt99ol is offline   Reply With Quote
Old 12-14-2007, 06:49 PM   #16
NemeGuero
No more nissan.
NemeGuero's Avatar
god damnit you people
there is no spot on my Bride bucket where the OEM seat belt connector bolts to.
Old 12-14-2007, 07:11 PM   #17
89singlecamnoob
couldn't you just fab up something (like the first pic) and weld it to where i've circled (second pic)?seems like you'd be able to mount your harness like that. (idk, i've never done it, just an idea)
Old 12-14-2007, 07:43 PM   #18
vvtisupra
or bust out the stock stud where the seat mounts and use a longer bolt and bolt it where the seat mounts, just sammmich it
Old 12-14-2007, 07:48 PM   #19
hitman
hitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfection
Send a message via AIM to hitman
the side belts you just drill a whole and use a big washer too. use eye bolts or whatever. thats what i did
driftparty.com
hitman is offline   Reply With Quote
Old 12-14-2007, 07:56 PM   #20
tknbkthrsdy4anfg
Use the seat rail mount hole on the firewall, it will line the belt up perfecly with the hole in the seat wont it?
Old 12-14-2007, 08:03 PM   #21
EJ253
EJ253's Avatar
EJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfectionEJ253 is close to perfection
Send a message via AIM to EJ253 Send a message via MSN to EJ253
mark where you want it mounted.
take off seat.
weld a 4x4" plate in.
weld a nut on it.
screw in eye bolt.
done.
...its called an eye bolt right?
The gap between MORE and ENOUGH never closes.
DriftUtah | UtahNissans | MySpace | I <3 Drifting. Keep it Real.
Secret Society
EJ253 is offline   Reply With Quote
Old 12-14-2007, 08:08 PM   #22
gprb25
gprb25's Avatar
gprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of light
What up rickety rick...haha
Just a suggestion from what i've seen elsewhere...
Ever thought of mounting it to the seat bottom?
http://members.cox.net/mazdatrinity/harness/
I know it's a miata, but it has pics.
gprb25 is offline   Reply With Quote
Old 12-14-2007, 08:14 PM   #23
EJ253
EJ253's Avatar
or you could just mount it to your pants.
the seatbelt should be mounted to the chassis IMO
but i havent looked into it really. just seems like common sense, i might be wrong
Secret Society
Old 12-14-2007, 08:43 PM   #24
NemeGuero
No more nissan.
NemeGuero's Avatar
My penis will keep me safe in the event of a high speed collision. haha
I was thinking of using the tunnel bolt, just wondering if there was a different way.
Thanks guys, I guess. haha
Old 12-14-2007, 08:54 PM   #25
hitman
drill a hole in the floor, then use a big washer on both sides and use an eye bolt. thats the "scca" way. like 1.5 or 2 inch washer, maybe 1/8 inch thick
driftparty.com
Old 12-14-2007, 09:07 PM   #26
NemeGuero
No more nissan.
NemeGuero's Avatar
Serious? Fawk..
Old 12-14-2007, 09:11 PM   #27
hitman
or you could drill it in the tranny tunnel. it seriously doesnt matter though. as long as its strong
for my stock seatbelt in case i drive on the street its just a thing welded like someone suggested. super easy.
driftparty.com
Old 12-15-2007, 12:23 PM   #28
Wiisass
Wiisass's Avatar
Wiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond repute
Send a message via AIM to Wiisass
Holes in the floor with eyebolts and big fender washers or a plate welded to the floor is the way to go for the lap belt mounting. Same as with the sub belt.
You don't want the belts mounted to the seat or the seat rails because if the seat or rails break in the event of a crash, you don't want to go flying out with the seat. You want the harness bolted to the chassis as solidly as possible, so it will keep you there in case anything goes wrong.
TIP Engineering
R/T Tuning
Drift and RWD Sport
DriftAssNation
Wiisass is offline   Reply With Quote
Old 12-15-2007, 12:40 PM   #29
darius_tii
darius_tii's Avatar
darius_tii has a spectacular aura aboutdarius_tii has a spectacular aura aboutdarius_tii has a spectacular aura aboutdarius_tii has a spectacular aura aboutdarius_tii has a spectacular aura aboutdarius_tii has a spectacular aura about
Send a message via AIM to darius_tii
yea whats they said..
I have a 5pt in my s14 ..
ill be at thunderhill so i guess yuo could take a look at it then
for the sides just side the stcok seatbelt locations...idk my bride rail had something on it..
Later
Darius
http://wolfreign.wordpress.com
Darius
darius_tii is offline   Reply With Quote
